Author Topic: side panels... if i don't want to paint, what are my options?  (Read 1286 times)
coltchillin
  • Last login:February 06, 2010, 05:28:43 am
    • My Midway replica project Flickr
i'd like the outside of my side panels to be as smooth and clean as possible.
so if i don't want to paint, what are my options? like veneer etc.
they're going to be cut from mdf.
thanks.
TOK
  • The Game Always Wins
Re: side panels... if i don't want to paint, what are my options?
« Reply #1 on: May 09, 2008, 12:09:20 pm »
Laminate. Not cheap to do, though.
coltchillin
« Reply #2 on: May 09, 2008, 02:35:39 pm »
a (rough) estimate?
for two side panels, outsides only.
thanks.
jban4us
  • Last login:July 08, 2013, 12:06:49 pm
« Reply #3 on: May 09, 2008, 08:04:39 pm »
I've been looking at this too for my first cab and what I've found is that there are basically 3 options: contact paper, Happ vinyl laminate, and formica. The contact paper is way cheaper, but I can't find any big enough that would cover a cab without seams. Formica and Happ vinyl are about the same price. The formica will be harder to put on the front and back because of the way you have to cut it (roughly with sheers and then route it), but it is probably much more durable.
I'm sure there are other places to get laminate too besides Happ, but I can't seem to find them online.
edit:
To get an idea of cost, here is the Happ vinyl page:
http://www.happcontrols.com/vending/acesor/49057200.htm
Formica:
http://www.lowes.com/lowes/lkn?action=productDetail&productId=136583-76323-136583&lpage=none
Contact paper:
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100388912&N=10000003+90276
« Last Edit: May 09, 2008, 08:09:35 pm by jban4us »
northerngames
  • Trade Count: (+18)
« Reply #4 on: May 09, 2008, 08:21:19 pm »
formica countertop laminate would run around $100-$120 for 2 sheets
coltchillin
« Reply #5 on: May 10, 2008, 04:29:57 am »
thanks guys!  8)
gatordad
  • Trade Count: (+11)
  • Last login:Yesterday at 11:58:07 am
« Reply #6 on: May 10, 2008, 10:15:24 am »
check out this thread as it has some self adhesive vinal sources
http://forums.klov.com/ubbthreads/showflat.php?Cat=0&Number=755587&page=0&fpart=1&vc=1
coltchillin
« Reply #7 on: May 10, 2008, 12:05:34 pm »
thanks sir!
Franco B
« Reply #8 on: May 10, 2008, 12:45:12 pm »
Im using 75 micron self adhesive vinyl for the panels of my cab that don't have graphics on. I bought somewhere in the region of 10 square meters of matte black, royal blue and carbon fiber effect and it came to around £25 ($50ish). I bought way too much so I can experiment with a few things, you could get away with buying much less.
Obviously this type of vinyl wont be a hard wearing as laminate but it should do for my needs.
If you do use vinyl contact your local sign writers/sign writer suppliers and go have a look at there vinyl.
As laminate is thicker you could get away with not having a perfectly even surface. As sign vinyl is so thin you would have to make sure your surface is completely smooth otherwise it will easily show any defects.
