Author Topic: What size hole saw needed to drill for cp buttons?  (Read 3264 times)
nick-g
  • Last login:August 07, 2020, 04:54:23 pm
« on: April 25, 2008, 07:07:29 pm »
I am looking to add a piece of plexi over my control panel.  What size hole saw will I need to drill the holes for normal arcade  buttons?  How about for joysticks?
In game room: Donkey Kong, DK-DKjr-MB combo machine, Mame
Current projects: Ms Pac Man restore, Galaga cocktail restore and conversion to 39 in 1 arcade classics machine.
In garage: Galaga, SF2, Space Invaders, Sega Candy Cabinet, Sky Shark - All awaiting some work.  Will be a busy summer!
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: What size hole saw needed to drill for cp buttons?
« Reply #1 on: April 25, 2008, 07:22:35 pm »
1 1/8"
Depending on if you bottom mounted, routed bottom mount, or top mount: 1 1/4", depends on how much you routed, and 1 1/8", respectively.  (Assuming normal throw happs like joystick; other sticks might need more or less.)
Robin
Knowledge is Power
The_Tyler_Black
  • Last login:March 19, 2010, 03:01:13 pm
  • Mario on shrooms!
« Reply #2 on: April 25, 2008, 08:19:41 pm »
I perfer to use a 1/8th paddle bit. it makes it easier if your doing alot of holes!
solderguy1
  • Last login:November 19, 2016, 01:29:27 am
« Reply #3 on: April 25, 2008, 08:36:25 pm »
And start by drilling the backside out 1/3 of the way or so, then switch to the front and finish.  It keeps the hole smoother.
Vash
  • Last login:November 22, 2016, 03:31:09 pm
« Reply #4 on: April 25, 2008, 09:36:12 pm »
How do you make sure that it lines up on both sides?
RoninEditor
  • Last login:April 14, 2009, 02:46:58 am
« Reply #5 on: April 25, 2008, 09:45:28 pm »
I guess using a pilot hole all the way through...?  It seems like it could get mess if they holes don't perfectly line up though, then the button will be all over the place.
Honestly, just drill sloooooooowly and use a Forstner bit (highly recommended).  I did some practice ones on scrap, before the real ones, and it made a huge difference, the speed you use.  Slow and steady and it's super clean.  Fast and forced makes chunks fall out the back and WILL split your Plexi or Lexan, which you really, really don't wanna do.
gatordad
  • Trade Count: (+11)
  • Last login:November 06, 2025, 10:15:06 am
« Reply #6 on: April 25, 2008, 09:51:20 pm »
See here for all your hole size questions
http://forum.arcadecontrols.com/index.php?topic=71031.0
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #7 on: April 26, 2008, 08:44:37 am »
Working: Not Enough
Projects: Too Many
Progress: None
Franco B
« Reply #8 on: April 26, 2008, 01:14:39 pm »
if you lay your CP on top of a scrap piece of MDF etc it will give you a clean finish when you drill through with no need to drill from either side. I would 2nd the Forster bits. If you have *access* to a drill press all the better.
Edited for spelling, i have aces spelling me!  ;D
« Last Edit: April 26, 2008, 01:17:11 pm by Franco B »
Fozzy The Bear
  • Handbags at dawn in here!!!
« Reply #9 on: April 26, 2008, 01:29:51 pm »
Don't try to drill the Plexi at all!!! It has a habit of cracking if you do.
Use a forstner bit on the wood.... way better than a hole saw or a spade bit.  Then when you have your plexi ove the top of it, use a flush triming bit in the router to cut the holes in the plexi. The flush trimmer is the straight bit with the bearing on the end. Let the bearing run round the inside edge of the hole in the wood and the flush trimmer wil cut the plexi to exactly match the holes you drilled through the wood in the first place.
Best Regards,
Julian (Fozzy The Bear)
