Author Topic: You have convinced me to buy a spinner! (Now with added bling spinner goodness!)  (Read 13827 times)
Gyruss and Time Pilot
I own a Gyruss and it has a joystick... not sure about Time Pilot..
I was going to say something. . .   I guess (and hope) he was joking about that, because both Gyruss and Time Pilot are definitely 8-way stick games.  But they're both the sort of games you can look at and say, "hmm, maybe this should have been made for a spinner, it might have been good that way".
If Tempest 2000 can be good with a thumb pad, maybe Gyruss could be good with a spinner.   :dunno
Thing is, both Gyruss and Time Pilot should be played with a spinner. I think it would make the game much more playable.
I'm planning on building a spinner based cabinet and it'll have both Time Pilot and Gyruss on it.
Question regarding Typhoon and Tempest 2k - those are 4:3 games only or can they be played on a vertical setup?
Zobeid
  • Last login:April 21, 2021, 10:36:32 pm
Can you really make that work?  Both of those games were programmed to accept 8-way stick input, I'm not sure whether MAME can translate spinner input into that kind of stick input in a useful way.  I'm guessing it might require a pretty serious hack.
It's a neat idea, but I'm not optimistic about getting it to work in a satisfying way.
They are 4:3 horizontal games.  T2K is an Atari Jaguar game of course, so it was designed strictly for a TV set.
Typhoon 2001 has some options to adjust the aspect ratio which "can prove useful if you play the game on an 16:9 TV or something like that", according to the website.  I have some doubts about whether you can get it to actually rotate the display 90 degrees for a vertical monitor though.  It's just not made for that.
I hadn't given it a thought myself, since I'm building a rotating-monitor cabinet anyhow.   8)
ADDENDUM: I just realized Typhoon 2001 also requires a joystick to move you up and down, only for the bonus stages.  Which is no problem. . .  It's just a little peculiarity that it inherited from T2K, where everything was done with the thumb pad.
« Last Edit: April 27, 2008, 12:56:38 pm by Zobeid »
Well then... be watching for my project announcement in the next couple weeks.
_Iz-
  • Last login:Yesterday at 03:47:45 pm
  • Time to coin up!
If memory serves, Dave Widel (www.widel.com) did a version of mame that converted gyruss (and some others) to spinner input.
ahofle
    • Arcade Ambience Project
Care to share here for those of us that don't monitor the project announcements?
psychotech
    • psychotech
 :dizzy: :laugh2: :dunno :laugh2: :dizzy: :laugh2: :dunno :laugh2: :dizzy: :laugh2: :dunno
ahofle
I meant the trick to playing Time Pilot with a spinner, not his project obviously.  ::)
« Last Edit: April 28, 2008, 06:41:29 pm by ahofle »
I used to love Championship Sprint, Super Sprint and Iron Man's OffRoad in the Arcade.  I remember spinning the wheel to turn corners and then quickly grabbing it to go straight again.  The spinner works exactly the same way.  All of these games mentioned here in this posting work fantastic with the spinner.
~ DeLuSioNaL
Minwah
    • MAMEWAH
I like the joystick control of Gyruss...kindof a unique feel to it, and it works well.
Out of curiosity, I too would be interested in how you might get it to work well with a spinner tho...
PS Xiaou/Shan: you are both right. Technically spinner is the closer control. But in practice using a trackball is nearer to operating the original controller. Use whatever you prefer.
TOK
  • The Game Always Wins
Since Gyruss and Time Pilot have hard coded turn speeds, I think they would be rather frustrating with a spinner.
Regardless of how fast you spin, they will keep turning/moving at the same rate... Every true spinner game I can think of translates spinner speed to character movement speed.
lcddream
  • Last login:December 04, 2024, 03:59:31 pm
  • Say goodbye to gravity...
If you are getting a TT2 and are installing 1 at each opposite vertical side of your cabe, make sure you get a long enough connector for one of them, the stock one is only 12". Or get two masters each with a pcb.
