Author Topic: hydraulic driving game  (Read 2594 times)
G1zm0
  • Last login:October 05, 2020, 06:57:58 am
  • cute by day, devil by night
« on: April 25, 2008, 07:54:46 am »
hi im goin to mame a driving game, got chance of  ridge racer or gti club sitdown if mamed would the hydraulics work within mame or would it not move? does it use a percific  logic board for this?  also if its not a 360 wheel on it will all games work ok with the wheel? does this involve alot of work to get it going? and lastly is it worth it?
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: hydraulic driving game
« Reply #1 on: April 25, 2008, 07:59:11 am »
No
Yes ??? (percific?)
Not really
Depends
Maybe
EDIT: To be less obnoxious -- nope, the hydraulics won't work by default -- you will need to do some special work there. If you don't have a 360 wheel, then you will have some trouble playing games designed for a 360 wheel. The other two I can't answer without more details.
« Last Edit: April 25, 2008, 08:02:54 am by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
G1zm0
« Reply #2 on: April 25, 2008, 08:17:34 am »
i thought the hydraulics wouldnt work, anyway it would go through more electric, there aint alot of 360games out so wont be playing sprint, ironman and apb,i want a driving cab that i can play good driving games but how easy is it to get it all working 100% (controlls i mean) i know some games like daytona use 1234 gear and games like outrun have high low and chase hq have turbo button, would the 1234 combo work with hi/low games or should i get cab with high low switch or paddels and just put buttons on cab for 3 and 4 gear and turbo, this part is quite confusin, help appreciated
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
« Reply #3 on: April 25, 2008, 08:32:19 am »
I think he means specific logic board.
I've been contemplating doing some racing controls and here's the situation.  Games like pole position have the stick either at high or at low.  Some games use a spring type lever to change gears.  Also think of afterburner as a high/low type of stick.  Some have a turbo button like you said as well.  I'm not 100 percent sure, but i think a 1234 shifter would work for your high/low.
shardian
  • Trade Count: (+23)
« Reply #4 on: April 25, 2008, 08:43:10 am »
I've seen more than a few dedicated arcade driving cabs and the general consensus is this: the creators are NEVER satisfied with the results. Your best bet is to pick just a few games that you know will play nice together.
G1zm0
« Reply #5 on: April 25, 2008, 09:04:25 am »
yup so many control methods, might get a standard hi low cAB OR one with paddles like monaco gp, and hopefully get the stearing to work in mame and the peddles to, the gears that use more than 2 i will install a few buttons and a turbo button, just means i hit 1,2 will be mapped hi low, and 3 4 will be mapped to buttons as well as turbo, i think its only solution unless i pick up a daytona 1234 and hopefully 1 2 will be high low and a button for turbo unless i can drill and install a button on thr side or top of the gearshirt, does this sound logical?is the wheel easy to set up in mame
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« Reply #6 on: April 25, 2008, 11:24:02 am »
I just finished up my racing setup for the third time last night, I started to go with mame for racing but its to many problems & too few games.  So I went another route using a pc &  a playstation 3 w/ a 40" 1080P lcd.  I hit a switch to switch back & forth between the systems.  I will be posting pics this weekend
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
Xiaou2
  • Last login:Today at 05:30:28 am
  • NOM NOM NOM
« Reply #7 on: April 25, 2008, 11:42:34 am »
FYI
 I dont think there are any motion arcade machines that use Hydraulics.  As they are
too slow, and require too much maintenance.
 All the onces Ive seen and worked on were electric motor driven.
divemaster127
« Reply #8 on: April 25, 2008, 11:45:03 am »
I am using a logitech Z5500 sound sytem, plus the lcd speakers this helps to really feel in the game nascar 8 on the playstation 3 is awesome in 1080P
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #9 on: April 25, 2008, 12:30:42 pm »
Yes.  Once you get the wheel working in windows.  (hint: apac2 = easy wiring analog to windows.)
Robin
Knowledge is Power
SavannahLion
« Reply #10 on: April 26, 2008, 11:39:15 am »
Out Run:dunno
Fozzy The Bear
  • Handbags at dawn in here!!!
« Reply #11 on: April 26, 2008, 01:36:56 pm »
Out Run:dunno
NO!! electric motor via a gearbox with a large rubber wheel on it that drives on the bottom of the seat section.
It was I think the first arcade driving motion simulator to be released.
SEGA still use the same method to drive the new cabs like Afterburner Climax.
Best Regards,
Julian (Fozzy The Bear)
Xiaou2
  • NOM NOM NOM
« Reply #12 on: April 26, 2008, 02:09:16 pm »
 Actually,  in  Afterburners case you are correct Fozzy.
 In Out Runs case, its slightly different.   It a motor that drives a (2ft?) huge worm drive.
As the worm drive turns,  a piece of metal rides on it back and forth, and that pushed the
cabinet from left to right on its pivot.  (as far as I can tell from the pictures)
SavannahLion
« Reply #13 on: April 26, 2008, 03:01:36 pm »
Out Run:dunno
You did notice this little dude; :dunno, right? After you're done biting my head off, can you do me a favor and clean it up, comb the hair and give it back to me? Thank you.
Fozzy The Bear
« Reply #14 on: April 27, 2008, 02:42:29 pm »
Geezzzzz!!!! Touchy or what!!! I wasn't biting your head off. I really don't know why I bother sometimes. Are you just having a bad day or something??
If I'd been biting your head off you'd have known about it..... Well you would have done for all of the 20 seconds it takes a human brain to black out after being removed from somebodys neck.  ;)
Best Regards,
« Last Edit: April 27, 2008, 02:45:07 pm by Fozzy The Bear »
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #15 on: April 27, 2008, 03:45:11 pm »
The "NO!!" looked a tad aggressive to me too.
