Author Topic: Automatically Restarting a Front End  (Read 2346 times)
Bill Mote
  • Last login:May 29, 2010, 11:04:28 pm
  • Focus on making things better not bigger.
    • Things That Make Me Mad and How To Fix Them
« on: April 21, 2008, 02:09:52 pm »
Does anyone know how to monitor the Front End and restart it if it stops?  I know "firedaemon" can do this if you launch your FE as a process and I've come up with a simple .bat file that launches mamewah:
:RUNFE
CD C:\MAMEWAH
@CALL MAMEWAH.EXE
GOTO RUNFE
This launches MAMEWah and returns control to the batch file if mamewah exits.  It relaunches mamewah automatically, but this feels more like a hack than anything respectable ;)  Firedaemon costs $40 for home use.  I'm not that ashamed of my batch file.  Just curious if anyone knows of a better and/or more sophisticated way to do this.
dot
fjl
  • Pixels Rule!
Re: Automatically Restarting a Front End
« Reply #1 on: April 21, 2008, 03:17:12 pm »
I'm by no means a coding pro. Everything I know I learned on my own. This is one thing I learned from playing around with DOS...
@echo off
:relaunch
start /wait Frontend.exe
goto :relaunch
Basically what it does is open a program and waits for it to close. If it closes it loops back to the command that opens it and again waits for it to close. It repeats this indefinitely until someone closes the DOS Batch Window. Which is the only problem, a DOS Window pops up when this is inserted into a batch file. But I suppose you can add it to a previous batch file or something.
« Last Edit: April 21, 2008, 03:21:45 pm by efjayel »
gonzo90017
« Reply #2 on: April 21, 2008, 04:22:04 pm »
You know how the old saying goes. If it works....
Bill Mote
« Reply #3 on: April 21, 2008, 04:23:01 pm »
If it works tweak it?  :P
dot
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #4 on: April 21, 2008, 04:51:00 pm »
Not sure how well FE's would work as a service, but you could try getting one of those "run app as a service" programs and set it to run your FE as a service. Then go into the services "properties" dialog and set it to interact with desktop (otherwise you will never see the FE). Finally you can tell it to restart if the process terminates in that same dialog.
This is assuming you're using XP.
Bill Mote
« Reply #5 on: April 21, 2008, 04:53:30 pm »
M$ provides the SRVANY and I've used it many times in the past.  I guess I could give that a try ...
dot
Havok
« Reply #6 on: April 21, 2008, 08:45:53 pm »
I think the bigger question is why? Does it crash? My frontend always runs and I don't have to resort to that...
fjl
  • Pixels Rule!
« Reply #7 on: April 22, 2008, 03:59:08 am »
So my DOS batch file doesn't cut it?  ??? :'(
Why not?
protokatie
« Reply #8 on: April 22, 2008, 04:09:54 am »
You hit it where the sun dont shine. I was thinking "These are cool ways to make sure a program always runs" then I was like "Wait a minute, why do I need this?"
If your front end and or mame is failing regularly enough that you need an autorestart then you have more serious problems than scripting and batch files...
(Still interesting tho)
protokatie
« Reply #9 on: April 22, 2008, 04:20:12 am »
Another double post... By me.
Yes it works, but it shouldnt be needed. Also "So my DOS batch file doesn't cut it?" should be made to be your title by Saint. ;)
BTW, when I was an Amiga fan, I was big on AREXX, so I feel your pain.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #10 on: April 22, 2008, 08:15:57 am »
this would've been nice to know when mamewah was always crashing me on, but I found the bug and squashed it.
Still, it's a good temporary fix.
Better than nothing.
Here's my question: Say I load a game in MAME that doesn't work and freezes when I load it (there are a few). Is there a way to set a program to automatically close if it's not responding? (Using FastMAME .84)
Bill Mote
« Reply #11 on: April 22, 2008, 10:38:19 am »
Why you ask?  :)  I have lots of kids using my cab.  They *always* hit the EXIT button too many times and end up at a blank black screen because MAMEWah is my OS shell.  Then I either have to open the coin door and pull out the keyboard or I have to VNC into the cab.  Both ruin the magic for those standing around ;)
MAMEWah has never crashed on my cab that I'm aware of.  It's just kids aged 3-14 that are causing the exits!  LOL
dot
TheShanMan
« Reply #12 on: April 22, 2008, 11:20:57 am »
Surely you can disable exiting via the keyboard in mamewah? You can in mala, so for me that is a non-issue.
Stub
  • Last login:July 08, 2024, 10:48:14 am
  • Sensory Overload
« Reply #13 on: April 22, 2008, 11:45:58 am »
GameEx works nicely. I can configure what it allows. I can set up no exit, and power down only with a confirmation.
Ginsu Victim
« Reply #14 on: April 22, 2008, 11:52:56 am »
You can easily remap MAMEWAH to exit with a different method. I use a shifted button, which takes me to the options menu. I exit to windows from there.
The only other exit method I have is a hidden button on top of the cabinet that shuts down everything.
fjl
  • Pixels Rule!
« Reply #15 on: April 23, 2008, 03:11:20 am »
I completely disabled the "Exit Frontend" option.
No wait, let me rephrase that. It's remapped so it can only be done with the keyboard. Pressing Escape only has an effect on the current game being played which displays the Exit confirmation screen. On the Frontend, its not mapped so it does nothing. To exit they'd have to access the keyboard which only I can.
Bill Mote
« Reply #16 on: April 23, 2008, 07:24:03 am »
Thanks for the suggestions.  I'll look at my config and adjust ;)
dot
Havok
« Reply #17 on: April 23, 2008, 08:08:07 am »
There you go - it's always good to ask why. Now you will have a better setup, avoid the kludge!
(+_+)
  • Let me splain.
  • Last login:July 27, 2012, 09:00:32 pm
  • For I am ]{eyser Soze
« Reply #18 on: April 23, 2008, 01:59:32 pm »
The easy way, although not always evident, is the best way. Leading down the track you were going with firedaemon, you would have to ask what's going to watch firedaemon to make sure it doesn't crash and so on...
This plan is so perfect, it's retarded. -- Peter Family Guy
