Author Topic: Can't use my controls with MALA -- figured it out  (Read 2670 times)
Dizzle
  • Last login:August 09, 2014, 05:28:04 pm
« on: April 19, 2008, 01:53:03 pm »
I downloaded MaLa last night and started playing around with it to see if I could get it to work with two monitors.  Well, I've just about got that figured out, but I'm having other problems.
I've got a cab with a HotRod SE and not only can I not control MaLa with it, if I use the keyboard to press "OK" and finally get into the game, the game no longer recognizes most of my control inputs (the exception are a couple of buttons).  If I launch the same game through MAME32 (v1.04), everything is fine.  I hooked up an X-arcade and I'm getting the same problem.
Anyone know what could be the problem?  Is it because I'm using MAME32 and not a command line version of MAME even though everything else seems to work fine with it?
« Last Edit: April 20, 2008, 12:30:36 pm by Dizzle »
Dizzle
Re: Can't use my controls with MALA -- figured it out
« Reply #1 on: April 20, 2008, 12:32:17 pm »
Figured it out -- was pretty simple...
MaLa was looking for mame.ini but Mame32 uses the file mame32.ini.
Just copied the mame32 file, renamed it mame.ini, and everything works fine now.
loadman
  • Moderator
    • MaLa
« Reply #2 on: April 20, 2008, 07:58:08 pm »
Most here would discourage you using mame32 with a FE.
Occasionaly you can strike issues.
Dizzle
« Reply #3 on: April 20, 2008, 09:28:40 pm »
I guess I'll go hunt down the command line version of 1.04 then.
Thanks for the advice  :cheers:
