Author Topic: Mamemarquees.com Ultimate marquee option:Please explain  (Read 1810 times)
Stub
  • Last login:July 08, 2024, 10:48:14 am
  • Sensory Overload
« on: April 11, 2008, 08:41:28 pm »
Their explaination is quite fuzzy. "The new ULTIMATE Marquee is for people who want it all! They are printed on the same type of backlight material that you would find on today’s arcades and then laminated with a luster laminate for a great finish."
Now I dont mind spending the $10 for a better quality print. But can someone who has seen them help explain the difference?
Ginsu Victim
  • Comanche, OK -- USA
Re: Mamemarquees.com Ultimate marquee option:Please explain
« Reply #1 on: April 11, 2008, 09:30:41 pm »
laminate or no laminate
Games001
  • Last login:January 13, 2024, 12:44:04 am
« Reply #2 on: April 12, 2008, 12:05:07 am »
Laminate or not...  that's it?
That sounds really.. umm.. intense.  :dunno
ivwshane
    • My first mame cab! (WIP)
« Reply #3 on: April 12, 2008, 01:42:40 am »
What exactly does having it laminated do?
Stub
  • Sensory Overload
« Reply #4 on: April 12, 2008, 09:42:40 am »
As it is covered with plexiglass I don't think that Laminate would change the way it looks. Or is the idea if you have it laminated you don't put plexi over the top? Maybe just a diffuser behind it is enough to make it stiff?
Ginsu Victim
« Reply #5 on: April 12, 2008, 10:07:29 am »
Laminate with, I believe, UV protection to keep it from fading, and to protect it from being as easily damaged.
You still want to put plexiglass over it. It's just high quality photo paper.
FrizzleFried
    • Idaho Garagecade
« Reply #6 on: April 12, 2008, 10:45:49 am »
I have both styles.  Get the ultimate.  Standard = high quality photo paper essentially.  Ultimate = much more rugged,  much more durable...like the material used in CPO's.
scottp
  • Last login:August 23, 2016, 08:52:04 pm
    • Mame marquees and Side Art
« Reply #7 on: April 12, 2008, 12:06:16 pm »
It is totally different materials: the standard is a high quality photo paper that backlits well.  and the Ultimate is a backlit film that is front printed and then overlaminated to protect the front, gives it the same mylar feel and it also makes it stiffer.
http://www.gameongrafix.com
10% off Coupon for BYOAC members, just type in BYOAC at checkout
Ginsu Victim
« Reply #8 on: April 13, 2008, 10:54:54 am »
Thanks for coming in and straightening things out, Scott. Perhaps a rewording on the site is in order? This question tends to come up a lot.
Minwah
    • MAMEWAH
« Reply #9 on: April 14, 2008, 05:59:32 am »
Wot he said  :)
