Author Topic: Lcd Topgun Driver Problem  (Read 1684 times)
kingdomkz
  • Last login:April 25, 2008, 08:58:39 pm
« on: April 09, 2008, 01:12:34 am »
No matter what I do to attempt to delete Smog's Guncon2PC xp suite driver, it won't go away. I mean that whenever I connect an EMS LCD Topgun the computer ALWAYS reads it as a "Guncon2" device then begins looking for the files to install smog's Guncon2PC driver and will not even see any other driver. If I install the EMS LCD Topgun Drivers and then plug in the topgun, the comp won't even see that driver, but only smog's driver, and then continue to attempt to find Smog's driver. Please, how do I fix this problem?
kingdomkz
Re: Lcd Topgun Driver Problem
« Reply #1 on: April 09, 2008, 01:18:23 am »
and yes I did uninstall Smog's driver prior to attempting to use the EMS driver installation.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #2 on: April 09, 2008, 02:46:21 am »
Smogs driver leaves a lot of crap in the registry when you uninstall it. I've had the same problem. In the end the only way I found to get rid of it all completely was to do a system re-install. Maybe somebody else has a better solution.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
kingdomkz
« Reply #3 on: April 09, 2008, 09:08:44 pm »
After i typed this out that was exactly what I had thought of, tg I have a registry cleaner :D
I'm going to find out today because i let my registry cleaner run all night on a full scan to eliminate any possible traces, I will report when I complete another attempt at setting up the LCD Topgun.
kingdomkz
« Reply #4 on: April 09, 2008, 10:49:34 pm »
I found out my problem was much simpler and that besides the fact that i totally cleaned out the registry (412 problems) that didn't fix the usb port. But i discovered this lcd topgun was installed with the EMS drivers already on the bottom usb port, so prob solved. I guess this means that when it is already installed on another port it will not work on another port when attempting to reinstall.
