Author Topic: is this the wrong hinge?  (Read 3283 times)
clickhea
  • Last login:August 09, 2019, 07:33:40 am
« on: March 14, 2008, 11:33:29 am »
i tried hanging the front door on my arcade. i have hinges that look like this from home depot
the problem is, when the door is mounted, it opens half way and then it binds on it self stopping it from fully opening.
also i want to add my door is recessed into the cabinet 3/4"   meaning its not flush with the edges of the cabinet.
if so is there anyway around it?
if not which hinge do i need ?
Re: is this the wrong hinge?
« Reply #1 on: March 14, 2008, 11:36:53 am »
You need to leave about 1/16" space on the sides of the door, I think, in order to allow it to fully swing open.  Try beveling the interior edge too... THIS is what I did...   :cheers:
clickhea
« Reply #2 on: March 14, 2008, 12:32:08 pm »
so i need to try off 1/16 on each side to start?
pmc
  • Last login:February 07, 2026, 12:21:50 pm
    • website
« Reply #3 on: March 14, 2008, 02:28:22 pm »
I think those are the same hinges I used on my cabinet and I couldn't get it to work right (I only opened halfway). It all depends on the way your door is hung. I think that javeryh used the correct hinges for my cab. They work properly because they are recessed.
Do some googling on (kitchen) cabinet hinges to learn how they work and which to get.
BTW, I removed some material and beveled the edge too. It didn't matter alot since the hinges were still incorrect. But if you get it working, please post some pics.
-pmc
clickhea
« Reply #4 on: March 14, 2008, 08:20:30 pm »
what a pain in the butt
ArcadEd
  • Last login:March 04, 2012, 01:25:15 am
  • Arcade-In-A-Box , Relive Your Childhood
    • Arcade-In-A-Box
« Reply #5 on: March 15, 2008, 12:13:06 am »
Looking at the picture it doesn't look like the door is lined up with the edge of the frame.  It's set off to the side the width of the wood.
Is that how you mounted it?  I'm guessing that is how the hinge is build so you wouldn't have much a choice, but thought I would ask :).  If that how yours is setup, it could be the hinge is designed for 1/2" wood and you are using 3/4" or something to that effect.
pmc
    • website
« Reply #6 on: March 15, 2008, 04:31:52 pm »
Yeah... that's why I left it the way it was since it worked well enough anyway (I only need to get in that door occasionally, and otherwise I have full access from the back).
Maybe the hinge is right but the installation is incorrect. That's why I'd like to hear how you eventually resolve it -- so I can copy you! :)
-pmc
clickhea
« Reply #7 on: March 15, 2008, 08:17:14 pm »
i used a slightly different hinge and got it to work perfectly i'll provide pics asap
mountain
    • Mountain Jukeboxes
« Reply #8 on: March 15, 2008, 09:12:13 pm »
Make sure you get the type of European hinge that is designed for the door to be inset. Look here for some more info and you should be able to pick the type that will work for you.
clickhea
« Reply #9 on: March 16, 2008, 11:10:18 am »
yep thats what i ended up using heres 2 pics.
pmc
    • website
« Reply #10 on: March 17, 2008, 09:33:18 pm »
Looks great! I see you had to use an extra strip of MDF to mount to. I'll remount my door the same way but I have a couple of questions first:
1) Where'd you get the hinge? Every time I'm in home depot I get all confused looking at a dozen hinges. Does it have a model number or something? :)
2) Did you have to route a recess on the door side? It looks flush.
3) how much space did you leave between the door and sidewall (the gap) on the hinge side.
4) The mounting strip is 3/4 thick"?
5) What's that white bracket for?
Thanks in advance,
-pmc
clickhea
« Reply #11 on: March 17, 2008, 09:47:02 pm »
1) home depot i dont have a model # cause i threw the bag out but its this hinge
2) yes the door has to be routed out a bit for the hinge
3) the hinges come with a template which you use to line up exactly where the hinges need to be.
4) yes 3/4 i just added it so the hinges sit exactly flush with the door.
5) the bracket is used to hold up the sidewalls of my arcade.. a bit of overkill but i had them lying around so why not.
BobtheAddict
  • Last login:October 29, 2010, 12:00:22 am
  • Icy Cold Beverages
« Reply #12 on: March 18, 2008, 11:46:42 pm »
Here is the model number for the hinge " P5105-04" European Cabinet hinge Full Overlay
BobTheAddict
pmc
    • website
« Reply #13 on: March 19, 2008, 12:00:18 pm »
Thank you guys. I think I initially avoided that particular hinge because it required routing and I didn't think routing was necessarily necessary (if that makes any sense).
You'll probably be better off. I used cleats - mostly 1". There are no diagonal structures. As a result, the cabinet can rack slightly to the left or right while playing it. I play with a light touch so it's not generally a big deal, but for some arcade games and some players, more rigidity would be much better.
-pmc
clickhea
« Reply #14 on: March 19, 2008, 01:25:40 pm »
go to home depot and pickup the brackets with your hinges u can always add the brackets to make ur walls stronger
krisbee
  • Last login:May 27, 2015, 04:55:07 pm
« Reply #15 on: March 19, 2008, 07:46:02 pm »
It's funny, I bought the same hinge, and have the same problem... the clue is the cabinet door is recessed in... so is mine.  I broke two of these hinges trying to get the door open.  I decided that not having the door open fully would be fine for me.  I also removed the springs (the little silver bullet thing) which helped getting the door open about 75 degrees.  These hinges are meant to be on the edge, so I would do like clickhea has, and put a board down the side on the inside where the hinges go to make it more like what it is supposed to open like.
clickhea
« Reply #16 on: March 19, 2008, 08:06:59 pm »
go with the second hinge that i used pictured above
