Author Topic: Key Switch  (Read 2651 times)
QuarterJunkie
  • Last login:August 19, 2020, 11:01:27 am
Key Switch
« on: February 15, 2008, 11:22:25 am »
I want to incorporate a key switch on my cab to switch from credit button/coin door to coin credit only. Does anyone have any recommendations as to a good source for this type of switch? I would prefer a tube type switch that will mount in my 3/4" mdf.
somunny
  • Is it hot in here?
Re: Key Switch
« Reply #1 on: February 15, 2008, 11:55:02 am »
I have one that I believe is made by Allen Bradley.  It's BIG.  I'll post a pic of it when I get home.
brock.sampson
  • Last login:May 31, 2018, 10:11:41 pm
Re: Key Switch
« Reply #2 on: February 15, 2008, 02:12:34 pm »
I would think this should work.  http://www.amazon.com/Key-Switch-with-2-Keys/dp/B0002BA3PE.  I have some toggle switches mounted inside the coin door where the test switches were originally to do the same thing.
« Last Edit: February 15, 2008, 04:41:37 pm by brock.sampson »
DOC! YOU HAVE A TABLE OVER THERE WITH A SIGN THAT SAYS, "LASER DEATH RAY BARGAIN BIN!"
mountain
  • Last login:January 29, 2025, 08:31:47 am
    • Mountain Jukeboxes
Re: Key Switch
« Reply #3 on: February 15, 2008, 03:45:01 pm »
I would think this should work.  http://www.amazon.com/Key-Switch-with-2-Keys/dp/B0002BA3PE.  I have some toggle switches mounted inside the coin door where the test switches were orginally to do the same thing.
I have this exact switch. It will work but it will not fit in a 3/4" hole. You might be able to modify a button and drop it in the button casing.
shardian
  • Trade Count: (+23)
Re: Key Switch
« Reply #4 on: February 15, 2008, 03:46:42 pm »
You can pick up a cheap keyed ignition switch at Autozone/Advance Auto.
Your coin door already has a keyed entry though, so just put a toggle inside there.
brock.sampson
Re: Key Switch
« Reply #5 on: February 15, 2008, 04:41:11 pm »
I thought he was going through 3/4" mdf not a 3/4" hole, am I not reading the original correctly?
somunny
Re: Key Switch
« Reply #6 on: February 15, 2008, 06:53:13 pm »
Well, here it is:
It's kind of a beast.  Momentary, two position switch.   Won't work on a 3/4" deep surface, though.  1/2", maybe 5/8".
QuarterJunkie
Re: Key Switch
« Reply #7 on: February 15, 2008, 07:14:45 pm »
After reading the posts about already having key access from the coin door, a switch mounted inside does seem the more logical choice. Thanks!!
mountain
Re: Key Switch
« Reply #8 on: February 15, 2008, 07:20:05 pm »
No, I misread it.
Good call.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Key Switch
« Reply #9 on: February 15, 2008, 08:07:41 pm »
I've not got much experience with these types of switches.
Could one of these be used in theory to replicate the key-turn switches that replaced start buttons on cabinets like Outrunners?
I'm about to start work on a driving cabinet and this would be a nice touch.
mountain
Re: Key Switch
« Reply #10 on: February 15, 2008, 08:10:03 pm »
I'm not too sure how those work. The one I have is a momentary swith but you can also get them in the latched variety (on/off)
Turnarcades
    • Turnarcades
Re: Key Switch
« Reply #11 on: February 15, 2008, 08:15:14 pm »
I think momentary would be needed as it would have to replicate the microswitch connection of a regular start button.
  • Last login:February 01, 2026, 05:25:13 pm
Re: Key Switch
« Reply #12 on: February 15, 2008, 08:26:54 pm »
I wired a spst toggle switch on the inside of the coin door:
Link to the writeup.
