Author Topic: Are chassis' interchangable?  (Read 2231 times)
gatordad
  • Trade Count: (+11)
  • Last login:Yesterday at 11:13:05 am
« on: February 14, 2008, 02:53:19 pm »
My monitor died, at least I think it did. It's a Hantarex 28in.
It appears that there is no longer any high voltage on the chassis, and I don't have the knowledge or schematics to troubleshoot.
What makes a monitor cga vga xvga (15, 25, 31)etc. is it just the chassis or does the physical monitor matter as well?
I was thinking of replacing the chassis, would one be able to upgrade a monitor with the purchase of a different chassis?
and where should I look?
GD
grantspain
Re: Are chassis' interchangable?
« Reply #1 on: February 14, 2008, 03:44:25 pm »
hantarex are pretty easy to fix and the schems are readily available for download,if you want to go ahead and replace it then i know alva amusements do a chassis that fits
if you want to fix it i am at present working on a monitor repair log on another forum which states the majority of known problems with hantarex polo monitors,its most likely to be a bad solder joint or a bad cap but all depends on the symptoms
Ken Layton
  • Guru
  • Technician
« Reply #2 on: February 14, 2008, 06:04:29 pm »
In the USA, the R.H. Belam company in New York is the official Hantarex parts & service center.
www.belamny.com
You can ship the chassis to them for repair or to some of the other folks here like texashotshot and arcadecup.
gatordad
« Reply #3 on: February 14, 2008, 07:21:10 pm »
My monitor is a mgg eq 2 or 3 or something (not sure which one), Can you Identify it?
here is a picture of the back of the panel if it helps
What is the other forum you speak of I would like to read it?
gatordad
« Reply #4 on: February 14, 2008, 07:30:02 pm »
www.belamny.com
Thanks much for the info Ken. Greatly apprieciated, half of the frustration is not knowing where to look sometimes.
If you gentlemen were in my position, would you look to fix this, buy a replacement chassis, or go with a new penta-sync monitor (don't tell my wife how much it is) from billabs ( aka Wei-ya)
grantspain
« Reply #5 on: February 15, 2008, 04:35:23 pm »
its a mgc eq/3,i have never worked on one but most of the usual hantarex problems would apply i expect
depends on what you want to do,if you have some monitor knowledge fix it,if not send it for repair
