Author Topic: Do the tokens work in normal quarter coin slots?  (Read 6013 times)
TheShanMan
    • My Arcade (updated 1/30/13)
« on: January 19, 2008, 01:05:58 pm »
Maybe I'm blind, but I couldn't find anything saying whether or not I can use the byoac tokens in my stock centipede coin slots that currently take quarters. Do you have to have special token coin slots?
kegger
  • Last login:April 10, 2011, 10:59:14 am
  • There are no unsingable songs....
Re: Do the tokens work in normal quarter coin slots?
« Reply #1 on: January 19, 2008, 01:31:59 pm »
I never tried a token but A real coin mech. is designed to take real money and reject fake coins.  I think you would need a token mech. for it to work.
I could be wrong though.
http://www.happcontrols.com/coindoors/42303900.htm
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« Reply #2 on: January 19, 2008, 01:40:54 pm »
you can definitely put a token in a coin slot...
the coin mechanism though needs to be appropriately used for tokens though in order for the token to not be rejected...
using tokens...?
use the appropriate token mechanism...
using quarters...?
use a quarter coin mechanism...
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« Reply #3 on: January 19, 2008, 02:01:45 pm »
happ sells the token slots I have these if you need
tks
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
TheShanMan
« Reply #4 on: January 19, 2008, 02:06:13 pm »
Thanks guys. I thought perhaps these tokens were weighted to match a quarter. Oh well.
MaximRecoil
« Reply #5 on: January 19, 2008, 07:03:16 pm »
That would probably be illegal. People could then use tokens in any coin-operated machine, e.g. the soda machine at work, or the washing machines at the laundromat.
TheShanMan
« Reply #6 on: January 19, 2008, 07:24:39 pm »
 :o Good point! Didn't think of that!
pacmandude
  • Last login:April 17, 2008, 01:45:05 pm
« Reply #7 on: January 19, 2008, 09:45:16 pm »
Tokens would not respond the same to the magnet in the coin mechanism due to the different metallic properties between the two coins either.
klippoth
  • Last login:September 19, 2008, 11:11:21 am
« Reply #8 on: January 19, 2008, 11:07:04 pm »
Actually, I'm no expert, but I have been researching this exact thing, and from what i've learned, almost every single coin mechanism out there can be configured to accept either. It's just a matter of figuring out how yours switches between the two. Some have a simple switch on the back, some actually have a spot to place an example coin, and i'm sure there are other ways. See if you can obtain the original documenation for the coin mechanisms or the game it originally came in for specifics. Or just poke around on the coin mechanisms for a switch.
carnid
  • Last login:September 17, 2012, 10:29:53 pm
« Reply #9 on: January 20, 2008, 04:51:00 pm »
On a similar note I own the Happ 40-0008-00 http://www.happcontrols.com/coindoors/40000800.htm which accepts and registers quarters fine - I was wondering if there is a way to adjust this to accept the MAME/BYOAC tokens as I just bought some and can't figure out what I need to adjust.  The mechs shown in this forum and on arcadereplay don't match this one.  Any advice would be greatly appreciated :)
pacmandude
« Reply #10 on: January 20, 2008, 05:55:33 pm »
I'm a newbie, but here's my take from what I understand. Technically, if the door has a slot for the type of coin to accept it is a comparitor.
You would have to adjust the entry slot restrictor to accept the new thickness (if it has changed). Reconfigure the cradle to accept a different weight coin via the counterweight. Calibrate the magnet to the new magnetic properties of the token. If the token is not magnetic, then the magnet will not slow the coin enough to let it fall into the accept chute. If it is magnetic, then the magnet will need to be repositioned closer/further via a setscrew. It seems like an awful lot of work when you can grab an inexpensive token mech. Of course, you could just bypass the mech and send the coin straight to the microswitch if you want the coin door to accept anything. Hopefully somebody that knows exactly what they're talking about can chime in. I've been known to talk out of my arse from time to time.  :blah:
carnid
« Reply #11 on: January 20, 2008, 09:28:25 pm »
Thanks for the detailed explanation - you know much more than this newbie ;)  I think I will stick to quarters for the meanwhile.
Santoro
  • Santoro
  • Trade Count: (+32)
  • Last login:July 14, 2025, 03:43:29 pm
  • Boycott Quarters!!!
    • ArcadeReplay!
« Reply #12 on: January 22, 2008, 05:53:21 pm »
TheShanMan
« Reply #13 on: January 22, 2008, 07:29:21 pm »
Thanks all! I will definitely investigate. Those BYOAC tokens are cool, even if a tad pricey (but then again, I have $20 tied up in quarters for my cab right now!).
carnid
« Reply #14 on: January 23, 2008, 12:49:07 pm »
Thanks Santoro,
I checked this out but my mechanism doesn't have the plastic screw illustrated.  I will continue to research and if I find anything will post here.
shardian
  • Trade Count: (+23)
« Reply #15 on: January 23, 2008, 02:35:26 pm »
Not all coin mechs are "moddable". The coin controls mechs are fairly easily modded for byoac tokens, but it can be finicky. For instance, your machine has to be pretty close to level, or the coins will jump the bottom diverter. The really neat thing about this mod is that you can still use quarters too. Most plastic ones are factory calibrated, and have no way to adjust.
carnid
« Reply #16 on: January 24, 2008, 07:56:38 am »
I don't think my coin mech is moddable - the Happ 40-0008-00, however I may buy a different mechanism in the future.  Thanks again for all the advice on this thread!
