November 21, 2025, 09:02:35 am
How do I get the side art off.. I tried a putty knife and also tried a razor blade.. neither will get the side art to come off. ..I plan on painting the cab black.. if I prime it first will 3 or 4 coats of black completely over the sticker or will you still be able to tell it is there?
ok.. I just ordered my T-molding today... hopefully that won't take long. got my order from Ultimarc (only took two days from London to Texas WOW). I have routed the top mount on the joysticks.. the only question I have is how do you keep the screws from sticking up.
Quote from: Kronos on January 11, 2008, 07:40:08 pmok.. I just ordered my T-molding today... hopefully that won't take long. got my order from Ultimarc (only took two days from London to Texas WOW). I have routed the top mount on the joysticks.. the only question I have is how do you keep the screws from sticking up.Well personally I would use counter sunk machine screws to bolt it in. Very carefully use an oversize drill bit to make a bevelled hole the screw can "sit" into. Practice on a scrap piece first though to see what size bit is best suited for a flush finish.
