Author Topic: Is this enough to emulate??  (Read 1456 times)
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
« on: January 01, 2008, 12:39:17 pm »
Do you guys think you can emulate NES, SNES and N64 without any problems?
http://www.logicsupply.com/products/vb7001g
BobA
  • What Me Worry?
Re: Is this enough to emulate??
« Reply #1 on: January 01, 2008, 12:49:44 pm »
C7s tend to be slower then the same speed intel chip.   Here is a sbc that is half the price with basically the same setup.  Don't know how the emulators will run as I have not used any of them.
GOS board
Grasshopper
  • Last login:March 04, 2025, 07:13:36 pm
« Reply #2 on: January 01, 2008, 01:06:18 pm »
If you avoid using Vista then the answer is almost certainly yes. It's easy to forget just how damn fast a 1.5ghz processor is, even the ones made by VIA. It's not that long ago that I used to comfortably run MAME on a computer fitted with only a 350mhz processor.
If you decide to use Vista, which in my experience is extremely resource hungry, then I'll downgrade my answer to probably.
BORIStheBLADE
« Reply #3 on: January 01, 2008, 01:13:36 pm »
Most likely I would be running tiny Xp.
GOS board
I would like s-video or composite, I'm looking for one with built in S-vid or composite so I can keep it small.
« Last Edit: January 01, 2008, 01:17:08 pm by BORIStheBLADE »
