Author Topic: DeLuSioNaL's Ultra Arcade complete (with new Video of cab!)  (Read 47900 times)
Re: DeLuSioNaL's Ultra Arcade complete (with new Video of cab!)
« Reply #80 on: November 18, 2009, 01:43:27 am »
Do you have to do the licensing to get rid of the MA logo screen pictured below? I don't see it in your videos. I've purchased MA but I don't see a way to change that logo.
Sorry for the late reply, I've been busy as of late and I had wanted to check my actual machine to be sure that the answer I give you is correct.
The screenshot that you posted is of the Preferences screen, which does indeed have the Maximus Arcade logo on it (even on mine, but I never show it in any videos).  There is no way to change that logo, unless you have the guy who wrote the program make a special licensed version for you or your company.
Perhaps what you are referring to is the opening logo when the front end starts?  In my videos, I bypass the opening logo completely.  This can be turned on or off in the preferences. (options tab; skip logo splash screen).  However, there is no way to change the graphic.  But you can get around it if you make your "chosen graphic" into a video file.  I'm sure you could edit something together that has it up for 5 seconds or so with a sound effect or something.  Then you can simply disable the logo and have your newly created video boot up in it's place.
Maximus boots up as follows:
Show import splash screen (you can also disable this)
Intro Video (if any)
Maximus logo splash screen (you can disable this)
Front end menu appears.
Mine is set to:
Intro Video (my custom one I made)
I am currently working on a generic Maximus Arcade intro video for all to use that will match the Blue Lightning theme of the skin.  ETA is Christmas.
DeLuSioNaL29
« Last Edit: November 19, 2009, 12:21:12 am by DeLuSioNal29 »
Encryptor
  • Trade Count: (+34)
« Reply #81 on: November 18, 2009, 05:20:07 am »
Excellent! That's what I was wondering. If you were somehow bypassing it with the intro video. Thanks for the reply and the info.
Encryptor
« Reply #82 on: November 19, 2009, 12:21:47 am »
To clarify... You don't need an intro video to bypass it.  You can simply disable it in the options.
« Reply #83 on: November 24, 2014, 01:55:15 pm »
Not too shabby, but if it was me, I wouldn't have angled P3 and P4 joysticks. :cheers:
mvolke1
  • Last login:August 27, 2020, 09:48:24 am
    • My Pi-Powered Galaga-Thmed Bartop
« Reply #84 on: November 24, 2014, 02:04:13 pm »
That is an epic control panel.  :burgerking:
I'm with stupid.
« Reply #85 on: November 24, 2014, 02:44:31 pm »
I corrected that AGES ago.  It was an easy fix, I had plenty of room to rotate and remount the stick from underneath.  I was a noob back then!   :P
D
  • Last login:Today at 03:34:59 am
« Reply #86 on: November 24, 2014, 03:49:12 pm »
D
You're actually rebuilding this CP if I'm not mistaken, aren't you?
« Reply #87 on: November 24, 2014, 08:36:31 pm »
It's debatable. I began parting it out recently and planning to downsize to a 2 player CP. But now I don't really have the time (and the weather is cold) to pursue the project until Spring rolls around. I plan to make a custom build and also change the artwork.
I did however begin experimenting with the four $5 Kade controllers that I bought. Indoor stuff like that will have to do.
