Author Topic: Which front-end for these requirements?  (Read 1537 times)
LeedsFan
« on: December 08, 2007, 08:28:20 pm »
I've been a bit out of the loop for the last couple of years since my Mame cab build. Lots of new hardware and software has been developed for this hobby in that time.
I'm about to make a 2-player control panel using Ultimarc 360 joysticks, so i definitely want to use a FE which allows "on the fly" selection of the correct map for each game. Also, I also want to be able to keep my existing Highscore.dat files which are working in my current Mame.V.88.
Having been reading loads this evening... on this forum and on FE websites I have found out some info, but would like to see if I've missed anything. The FE's I've found that support Ultimarc 360 mapping are MaLa and GameEx. But I'm not sure if I need to be using a new version of Mame for the plugins to work. I'm using Mame .88 remember which is quite old now.
Also I think I read that the last version of Mame to support Highscore.dat was .99. But is this enough to be able to utilise the 360 plugins? Or will any version of Mame work for them?
Also if I have missed any other FE that supports the 360 mapping then I will certainly check it out if you point me in the right direction.  :D
DaveMMR
Re: Which front-end for these requirements?
« Reply #1 on: December 08, 2007, 09:09:22 pm »
I use .99, .84 and .116 with Mala and have never had any problems.  Unless I'm wrong, Mala will work with any Mame version.  If I am wrong, it will work with .88 and .99.  (And I am also using the ultrastick plugin without issue).
By the way, you can recompile later Mames to include hiscore.dat support if need be.
« Last Edit: December 08, 2007, 09:34:02 pm by DaveMMR »
loadman
    • MaLa
« Reply #2 on: December 08, 2007, 10:39:51 pm »
YEP.... ;)
Early version can be used too. Look Here:
http://wiki.arcadecontrols.com/wiki/MaLa_FAQ#I_am_using_version_am_mame_version_.84_or_lower._Mala_seems_to_go_through_it.27s_process_of_generating_the_list_of_games_but_nothing_shows_up..3F.3F.3F.3F.3F
headkaze
  • 0x2b|~0x2b?
« Reply #3 on: December 09, 2007, 04:30:37 am »
You can use Mame Compiler to add hiscore.dat support to the newer versions of Mame.
