Author Topic: [Fixed] Galaga - Painting - which color ?  (Read 3612 times)
Darth Nuno
  • Last login:May 08, 2024, 04:26:02 pm
  • Namco is God !
    • Arcade Lifestyle / Dragon's Lair Fans
« on: December 02, 2007, 02:43:39 pm »
Hi all,
I would like to know which paint do I have to use to refresh my Galaga cab ?
I need to paint these areas :
And also the kickplate / front :
WHat was the original Galaga color for these partss ?
- Black Satin ? Bright ?
- What it the best method ?
THx  :cheers:
« Last Edit: February 10, 2008, 08:05:12 am by Darth Nuno »
fjl
  • Pixels Rule!
Re: Galaga - Painting - which color ?
« Reply #1 on: December 02, 2007, 04:40:07 pm »
I looks like a regular eggshell black. Why not go to your local hardware department and take a few of those small square paint samples so you can compare. Unless you want to chip off a small piece of the paint and take that with you to the hardware store.-
Darth Nuno
  • Namco is God !
« Reply #2 on: December 02, 2007, 04:48:31 pm »
In fact, these areas were already be painted in the past, and I'm sure it not the orginial paint. If you see on the picutres, it looks too matt... So that is the reason why I need to know what is the original paint for these areas ?  :P
fjl
  • Pixels Rule!
« Reply #3 on: December 02, 2007, 09:00:17 pm »
This might be some sort of help...
http://www.klov.com/game_detail.php?game_id=7881
Darth Nuno
  • Namco is God !
« Reply #4 on: December 09, 2007, 04:17:57 am »
Any Galaga owners who can confirm what is the *original* colors for these areas ?
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« Reply #5 on: December 09, 2007, 10:41:17 am »
hey nuno...
it might be better to post this in the main forum...i bet you'd get some responses from original galaga owners there...
Wade
  • Last login:August 18, 2025, 08:14:20 am
  • 80's Child
    • Wade's Gameroom
« Reply #6 on: December 26, 2007, 10:23:36 pm »
Originally it was fairly glossy, kindof a semi-gloss.  I used Rustoleum Satin Black to refurb one of these and it was a very good match for those areas.  I would recommend going with that.
http://usergallery.myhomegameroom.com/gallery/album188
The pictures above show before and after painting.  The sides of the game and the front were laminated though so their sheen is not true to the original.  However you can see how the original paint is fairly glossy, as are the inside areas after being repainted carefuly with Rustoleum Satin Black.
Wade
« Last Edit: December 26, 2007, 10:25:52 pm by Wade »
Darth Nuno
  • Namco is God !
« Reply #7 on: February 10, 2008, 08:04:23 am »
Ok, for archive... and because the project is done, I can tell "Black Satin" like Wade said previously.
Have a look right here  8)
