Author Topic: KeyWiz Help Needed  (Read 2057 times)
digitalmonkeyman
  • Last login:July 31, 2023, 09:44:26 pm
    • Free Temporary Email
KeyWiz Help Needed
« on: November 30, 2007, 03:13:21 am »
I have the KeyWiz Eco, and am running MAME32 front end.  I have my 40-pin IDE cable ready to rock and roll, but am confused about the hookups.  I want to use the defaults.
I have a single joystick and buttons for
Player 1
Player 2
Action button 1
Action button 2
Action button 3
Thats it.    on the Keywiz, I hookup my joystick to 'J1' , starting from the right;
Shazamm
Ground
Up
Down
Left
Right
Then I get lost,  :-\ where are the player 1 and player 2 buttons?
L Ctrl and L Alt?
Thanks for the help
bfauska
Re: KeyWiz Help Needed
« Reply #1 on: November 30, 2007, 04:22:19 am »
If you start a game and press the TAB key it will get you into the menu that shows how the key assignments are set up.  That's the easiest way to see the default setup.
digitalmonkeyman
« Reply #2 on: December 01, 2007, 12:39:13 am »
Thanks, but I really need detailed help.  I am lost.  I need a step by step of this wire goes to this plug..... etc.
Sorry, I just can't get my arms around this one.... :dizzy:
EwJ
  • Last login:October 12, 2022, 10:16:06 pm
« Reply #3 on: December 01, 2007, 01:13:42 am »
Try the documentation on the groovygamegear website.  Scroll to the bottom of the page for the KeyWiz Eco.  You may find what you are looking for at the bottom of the Installation Documentation Sheet (pdf)., and/or the Advanced Wiring TEchniques.
If this doesn't help, email or pm Randy - he's sure to have a reference sheet of pinouts to outputs, etc.
digitalmonkeyman
« Reply #4 on: December 02, 2007, 12:26:56 am »
digitalmonkeyman
« Reply #5 on: December 03, 2007, 02:26:39 am »
I think I have it figured out, but the instructions call for me to map KeyWiz terminal J to player 2 start.
On the KeyWiz default key map (included with the KeyWiz Eco), for J1 there is no map to key J.
Can someone help? :banghead:
digitalmonkeyman
« Reply #6 on: December 03, 2007, 02:55:31 am »
OK,
a fresh pot of coffee and a fresh perspective.....
All I need to know now is the way the KeyMap is laid out, are the J2 controls actually on the right side of the 40 pin, and the J1 controls are on the left side of the 40 pin, when your +5 and -5 volts are on the left?
Thanks :o
digitalmonkeyman
« Reply #7 on: December 03, 2007, 04:51:59 pm »
Is this how to wire it?
I think this is!
« Last Edit: December 04, 2007, 12:34:46 am by digitalmonkeyman »
  • Last login:January 25, 2026, 10:26:13 pm
« Reply #8 on: December 07, 2007, 10:07:25 am »
Check ou tthis thread, posted by maxmix
Keywiz thread
« Reply #9 on: December 07, 2007, 10:12:12 am »
BTW, I dont think the way you have it drawn up is correct.
On a 40 wire IDE cable, the wires alternate from side to side.
Wire 1, which is 5 volts, is pin one on left side, wire two is pin one on right side, etc.
digitalmonkeyman
« Reply #10 on: December 07, 2007, 10:45:21 am »
Yeah,
your'e right!  Thanks.  I think I got it figured now.
Thanks again
digitalmonkeyman
« Reply #11 on: December 15, 2007, 02:39:13 am »
Almost everything is working.  The only two buttons that are not are for coin 1 and coin 2.  Do these need to be wired differently?  Am I missing something?
I have he correct wires hooked up per the keymap linked to above by DaOldMan (thanks again for that awesome help MaxMix)
Any ideas?
digitalmonkeyman
« Reply #12 on: December 15, 2007, 04:19:15 pm »
In the KeyWiz menu, they buttons work, and are wired to 5 and 6 respectively, but when I go into a MAME game, they are looking for 3 and 4 as inputs for the coins.  Am I running an old version and this has been changed?
