Author Topic: Wiring Arcade Steering Wheel  (Read 1685 times)
jerschwab
  • Last login:May 28, 2011, 11:44:27 am
  • I think my project will be done soon... ???
    • Free Bertuzzi!
« on: November 22, 2007, 12:58:06 am »
I finally bought a steering wheel for my cab.  I went with a 360 degree with a wheel encoder.
Does anyone know where this wheel comes from?  I bought it from a pinball shop in Vancouver, they didn't seem to know.
Anyhow, is this the type of board I could just wire up like my spinner?  I have an Oscar controls vortex spinner that came with a PCB and wires to USB.  Can I get a USB cable and solder it to this board, or do I need a PCB from a mouse?
I'll be installing this on an Ultimate Arcade II cabinet as a switchable control panel.  Perhaps I can share the PCB from the spinner with this???
I had trouble finding posts of people using an arcade wheel, most seem to be using the Logitech, or Thrustmaster, etc.
Thanks a lot!
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
Re: Wiring Arcade Steering Wheel
« Reply #1 on: November 22, 2007, 02:09:32 am »
That should be fairly easy to interface.  You will need to use either an optipac, an optiwiz , or a mouse hack to interface.   The pcb on the wheel shows you which wires are which, just match those up with the corresponding connections on the optiwiz or optipac.
