Author Topic: printed marquee thickness...?  (Read 1182 times)
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« on: November 18, 2007, 05:55:16 pm »
i plan on sandwiching a printed off marquee from scott between two pieces of 1/4" plexiglass...
what would the thickness of the printed marquee be...?
1/16"...?
1/32"...?
other...?
thanks...!
  • Last login:Today at 04:57:25 pm
Re: printed marquee thickness...?
« Reply #1 on: November 18, 2007, 07:57:14 pm »
Somewhere between 1/32" and 1/64" - it's negligible.
EDIT: Well, maybe it's closer to 1/32" now that I think about it.  It shouldn't matter though because you install the L-brackets/marquee retainer after making the sandwich so if you measure using just the thickness of the plexiglass theentire thing will stick out the thickness of the marquee which I hope wouldn't make that big of a difference whether it's 1/16" or smaller...
« Last Edit: November 18, 2007, 08:12:43 pm by javeryh »
