Author Topic: Visio Diagram of Control Panel  (Read 1784 times)
Lucky S.O.B.
  • Last login:June 02, 2021, 03:02:50 pm
  • Mmmmm.... Donuts!
« on: May 06, 2003, 07:19:46 pm »
I was going to use visio to create my layout of my CP, and I made the image the correct size so I can print it out on a plotter and use it for cutting etc...
My question is:
Is this the best way to do this? If not what do you suggest?
I know the mounting info for buttons and controllers, but where can I find the measurements for happs trackball, oscar spinners, etc.
If anyone has already done this could you send me the visio so I can cut and paste stuff?
derrickjudge@intuit.com
-Derrick
TheTick
  • Last login:December 21, 2009, 12:24:27 pm
  • I.P. Daley
Re:Visio Diagram of Control Panel
« Reply #1 on: May 06, 2003, 07:41:45 pm »
Happs has the measurements under the expoded views and mounting views.
Oscar also has measurements to the left of the detailed view pages.
I'll send you over a ZIP of one of my Visio files. It has a template with a few buttons and I think Universial controllers (the ones that don't need mounting plates). The scale is 1:1.
The spinner and trackball aren't on the template, yet. I was going to use the actual mounting plates, so I just use a square to reserve the space. The Happs 3" trackball mounting plate is 6.5"x6.5".
Mucal invader, is there no end to your oozing?!
Lucky S.O.B.
  • Mmmmm.... Donuts!
« Reply #2 on: May 06, 2003, 07:50:39 pm »
Thanks, this will keep me busy for a few days  ;D
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« Reply #3 on: May 06, 2003, 08:57:31 pm »
look under the downloads section of this site - there are a ton of visio files.
TheTick
  • I.P. Daley
« Reply #4 on: May 06, 2003, 09:27:05 pm »
Those are generally 2:1, which isn't a problem. I did my template as 1:1, and just changed the scale of the paper.
Email bounced back as undeliverable, so you're gonna have D/L the ones from the website.
derrickjudge@intuit.com on Tue, 6 May 2003 16:27:28 -0700
    The recipient name is not recognized
   The MTS-ID of the original message is: c=us;a=
;p=intuit;l=EXBH020305062327JQPGR4LB
    MSEXCH:IMS:Intuit:BridgeHead-SD:EXBH02 0 (000C05A6) Unknown Recipient
