Author Topic: Does USB work in a Win98 Dos window?  (Read 1199 times)
ddoyle1996
  • Last login:July 18, 2003, 04:00:31 pm
« on: May 06, 2003, 11:05:18 am »
I have an Optipac that I would like to connect to my computer through USB.  But, I am running the dos version of AdvanceMame in Windows 98.  I HAVE to use the dos version since I can't program my video card using the windows version.  Is it possible to use the Optipac through USB with AdvanceMame running in a dos window of Windows 98, or will I need to connect it through the serial port?
Cue-Ball
  • Last login:August 28, 2006, 07:43:02 pm
  • Discs of Tron > *
    • Grant's Game Grid
Re:Does USB work in a Win98 Dos window?
« Reply #1 on: May 06, 2003, 01:12:24 pm »
The USB will work fine in a DOS window, just as long as you don't reboot into "DOS Mode".  As long as Windows is running in the background the USB driver stack is loaded and working.
