Author Topic: Adobe Illustrator help requested ( trouble with Saint's control panel Templates)  (Read 1769 times)
gatordad
  • Trade Count: (+11)
  • Last login:November 06, 2025, 10:15:06 am
I am now trying to create a layed cp in illistrator and I tried to use the templates from Saint's book but they do not size correctly, Does anyone have a fix for this?
I know I'm doing something stupid and it's probally a simple fix, but I am new to illistrator and now want to pull my hair out as I don't know what to do.
Thanks.
« Last Edit: October 24, 2007, 09:31:30 pm by gatordad »
superbigjay
  • Last login:October 22, 2023, 02:50:03 pm
  • I'll always be a kid...
    • superbigjay website
when you resize the templates, you can hol dthe SHIFT key.
This will force to keep the height/width ratio.
I hope this is what you're looking for...
Jay  :cheers:
gatordad
Jay  :cheers:
Thanks Jay that helps,
Is there any other way to resize Saint's templates so when they import into illustrator they are imported at the correct proportions / measurements or  is Jay's method the only one?
zorg
import the template without worrying about the size.
select all (ctrl-A)
then 2 ways of doing the stuff. 1 precise, the other not :D
1) hit shift F8 (this will open the transform window)
you can select the size you want precisely, if you click on the litte chain, the modification will be forced to height/width ratio
2) either select in the object menu the submenu transform and then scalling (not sure of the names) see pic attached it is french but menus are locate the same way :D
it will open a window that allows you to resize the selection by the % you want.
hope it helps
I'm on the planning stage
gatordad
Thanks guys that helped, for those who run across this thread while searching here are some links to vector controls
http://localarcade.com/arcade_art/r217.search.htm
http://rototron.info/
and another thread that was helpful
http://forum.arcadecontrols.com/index.php?topic=50376.0
Regards
Gatordad
