Author Topic: Some plans and directions for a 1 player CP  (Read 61049 times)
bfauska
« on: October 08, 2007, 05:07:16 am »
From time to time there is a request on the forum for some 1 player desktop CP plans.  I have decided to share some plans for a slight modification of my DorkStick project I did a while back, and have made up some plans with a few modifications for anybody that is interested.
These plans are for a 1 player CP that uses buttons designed for a 1-1/8" hole, joysticks with a hole pattern similar to many wico, happ, omni-sticks, and u-360s.  There is 2-1/4" between the CP lid and the bottom of the box.  I think the ideal joystick for this box is the U-360 because of it's versatility and ability to connect the buttons w/o an encoder.
To make the original I used a table saw, a router, a drill press, and a brad nailer.  The directions assume that you have access to similar tools and the knowledge of how to safely use them.  Always use appropriate safety equipment and follow all power tool directions.
The parts required to make this box are 4' of 1"x4" lumber (I used pine, but a piece of hardwood may be a nicer choice), 2 square feet of 1/4" MDF, 1 square foot of 1/4" acrylic sheet, and 2 brass ball catches.
Here is a rendering of the finished product. It is shown w/o art but it is designed to fit an 8"x10" graphic of your choice under the acrylic sheet, the size of the art allows you to have it printed at a photo store or even right from your home ink-jet printer.
Here are some samples of the drawings, the full versions are attached as PDFs bellow (please do not build from the .jpg images they are not to scale). For slightly better views of these images right click and choose "view image"
The first page is an exploded view of the box.
Second is 3 views of the box with dimensions, a parts list, and a full scale detail view of the box sides profile.
The 3rd and final page is a full size template for the button and joystick holes.
In the next post I will detail my recommendation of a construction process.  I hope some of you find this useful and ask that if you build a box from these plans that you post a picture in this thread.
Here are the plans (print them with no scaling to fit the page, if you allow the printer or your PDF viewer to scale the image it will not be the proper scale.) :
With thanks to Shardian, I now have a single file containing all three drawings.  I will keep the separate attachments also in-case anybody just wants one page, say the button layout for example.
Here's all 3 pages in one PDF.
« Last Edit: October 10, 2007, 11:16:02 am by bfauska »
bfauska
Re: Some plans and directions for a 1 player CP
« Reply #1 on: October 08, 2007, 05:07:47 am »
OK, here's the directions for the construction and assembly process I recommend.
Step 1, machine the perimeter boards.
Starting with a 4' length of 1"x4" board (really 3/4" x 3-1/2") rip the board down to 3-1/16" (changing the dimension here will allow you to use a deeper joystick or make a more compact CP if you do some careful planning, but this measurement will allow for an omni-stick or  a U360 and maybe others. Changing this dimension also changes the distances in the upcoming directions so you will have to adapt on your own.)
Now that the board is ripped to the correct width it is time to put in the rabbet and dado.  In the following instructions I will include a drawing of what the board should look like from the end once the step is complete.  I recommend using a test piece to check your blade depth and other saw settings as you progress.  Alternative techniques for the rabbet and dado would be to use a dado blade in the table saw or to use a router, but I think that either choice would require more setup than it is worth for a project this size.
Set your blade depth on the table saw to 1/4" and set the fence at 2-3/4" and run the board through leaving a slot in the underside of it like this:
Now bump your fence over about 1/16" further and run the board again, making the slot a little wider and working your way towards the edge of the board:
Repeat the last step until you have made a complete rabbet to the edge of the board that looks like this:
Next we will make the dado for the CP top to slide into.  Turn the board around so that the side that was just against the fence is out by the blade like this:
Set the fence so that the space between it and the blade is 2-9/16" and leave the depth set to 1/4" and make another pass with the board:
Now move the fence so that the distance from it to the far side of the blade is 2-13/16" and make a pass, this may leave a little feather of wood between the last 2 cuts, if it does then bump the fence back toward the blade a little more than 1/16" and do another run, you should end up with a piece that looks like this:
The next step can either be done now or once the box is assembled, but in all my drawings it makes it look like it was done at this point so that's what I'll show.  Using a 1/4" round-over bit in a router soften the edge of the board:
Step one is complete, you should now have a board that looks something like this:
Step two is to cut the boards to length.  For this step I used a chop saw, but you could use a radial arm saw, a miter box, or even do this with a crosscut set-up on a table saw with the blade tilted.  Because there are so many ways to make these cuts and all of them will basically work the same I'll just say this... Cut the 4 sides of the box to length with a 45 degree miter at the ends.
Step 3 is to cut the MDF for the bottom of the box and the CP top.  Both pieces are the same size 8-1/2"x10".  Again cut these however you want, just cut them the right size and cut them with square corners and you'll be good to go.
Step 4 is building the bottom of the box.  Take the 2 short box sides and one long side and the MDF bottom piece and assemble as shown.  I would use brads and glue for this step, but if you wanted to get fancy you could biscuit the corners.
Step 5 is to dril (or notch) the cable hole, and mount the ball catches to the sides.  If your choice of encoder allows you to feed the cable through a little hole then you can simply drill a hole in the back side of the box and soften the edges to keep the cable from wearing.  I had to use a USB cable that wouldn't fit through the hole so I drilled a hole and then made cuts connecting it to the bottom of the box.  The ball catches can be tough to properly align, but be patient, having these fit nicely is what makes it very hard to tell how the box was assembled, the catch should be placed so that it holds the back on tight and aligned.  The catches should be oriented toward each-other like this:
Here's the back about to snap onto the main part of the box with the catches and the hole:
Step 6 is to drill the remaining piece of MDF for the buttons and the joystick.  Using the template provided and either a spade bit, hole saw, or forstener bit drill the 1-1/8" holes and using a 3/16" or 1/4" twist drill bit drill the mounting holes.  Once the joystick mounting holes are drilled countersink them so that you can use flat-head bolts to mount the joystick and hide them behind the art and acrylic:
Step 7 is mounting the recently drilled CP top to the back board of the box.  With the board and the MDF carefully aligned, glue and brad the board into the slot.  I would shoot the brads through the MDF into the board at a sharp angle down, toe-nailing it.  You could also skip this step, my DorkStick CP doesn't have the top attached to the back because the top is acrylic and I couldn't use brads, and it works fine.
Step 8 is quite simple... slide the back and lid into the main part of the box.  This is also a good time to use the round-over bit to soften the four corners of the sides:
Step 9 is one that worries many people and causes much grief.  I have always had access to table saws with sharp blades and rarely have a problem cutting acrylic with them, some people use other techniques, but the table saw is my recommendation.  Cut the acrylic to size, 8"x10".  My renderings show the acrylic with the paper removed for clarity, but I suggest leaving it on until you are ready to start final assembly of your CP.
Step 10 is another tricky one.  To cut the holes into the acrylic the cleanest and most trouble-free approach is to us a router.  In order to use a flush cutting router bit on this project you will need some starter holes in the acrylic, I suggest clamping the acrylic to a piece of wood and using a slightly dull drill bit (or ideally an acrylic cutting bit) at a high speed in a drill press.  Some people advocate using drills in reverse but I've never needed to.  After drilling some holes that are big enough for the flush trim router bit to go through put the acrylic into the box top.  Using some double-stick tape or carefully placed clamps put the acrylic into the top of the box.  Now with the depth of the router set so that the bearing rides on the MDF CP lid route each hole for the buttons and the shaft of the joystick.  Do not drill the joystick mounting holes through the acrylic, they won't be needed to hold the acrylic down and it will look nicer to not have the bolt heads showing.  Here is an interesting read about the best practices when drilling acrylic.
Step 11 (or twelve by my rendering titles) is fairly basic, now that you have the holes drilled remove the tape or clamps that are holding the acrylic to the rest of the CP.  Mount the joystick base to the MDF and then use the buttons to hold the acrylic to the MDF.  Finish assembling your joystick and your ready for wiring up:
Finally your finished.  Of course at this stage you could pull the whole thing back apart and fill the brad holes, sand and finish the wood, but then you'd have to wait to play.  You can also print up some custom artwork on your printer or at a photo shop and put it between the acrylic and the MDF.  There are obviously a lot of ways you could take this project at this point, but that's the fun Building Your Own Arcade Controls.  Make them personalized, and be proud of what you've built:
Again, if you build a box from my plans, or a variation of them, please post some pics here, I'd love to see what people do with this.  Also, if the directions aren't enough to give you the confidence to build a CP yourself or you don't have the tools, shoot me a PM and I'll see if I can crank on out for you.  I'd probably build the first one of these for the cost of the materials alone so that I'd have some actual photos for the thread and I could work out any bugs.
« Last Edit: October 09, 2007, 01:31:15 am by bfauska »
fjl
  • Pixels Rule!
« Reply #2 on: October 08, 2007, 01:41:45 pm »
Shouldn't it be slanted for ergonomics and comfort? Did you read my thread on the wire strain relief to prevent the wire from being pulled and bent too much? Does yours include one?
I like the simple design though.
I'm currently building my own 1 Player CP. Still going through the design phase though.
« Last Edit: October 08, 2007, 05:06:41 pm by efjayel »
bfauska
« Reply #3 on: October 08, 2007, 03:26:45 pm »
I haven't found my current model to be uncomfortable, and the slant adds several steps to the process of this box.  Part of my goal with this design was to create an easy enough project that beginners could do it and still have a finished product that was clean and well built.  The process I recommend for the building of this box is simple enough that even novice builders should be able to end up with something they could be proud of.
My thinking was that the stain relief is basically a knot on the cable that passes through a softened hole.  It's not the MOST fail safe idea but it works on projects like this all the time.  Even Timoe's drop-dead-sexy boxes use this system.
Thanks for checking it out.  I hope to get the rest of the write-up done today.
gonzo90017
« Reply #4 on: October 08, 2007, 04:23:16 pm »
Thank you. Really appreciate it.  :cheers:
bfauska
« Reply #5 on: October 08, 2007, 09:59:31 pm »
I just got a correction via PM (thank you for not pointing it out in front of everybody, now I can  ;) )  I will have to update the page 2 PDF tonight to reflect it, but the 2 pieces of MDF should be 10-1/2"x 8-1/2"  NOT 11"x9"  OOPS.
<EDIT>
The current PDF "1player CP pg2.PDF" is corrected, if you downloaded the plans before this edit you can either make note of the correction described above or re-download the PDF.
</EDIT>
« Last Edit: October 08, 2007, 11:01:47 pm by bfauska »
brock.sampson
  • Last login:May 31, 2018, 10:11:41 pm
« Reply #6 on: October 09, 2007, 01:12:47 pm »
Does page 3 the hole template need to be updated as well?
DOC! YOU HAVE A TABLE OVER THERE WITH A SIGN THAT SAYS, "LASER DEATH RAY BARGAIN BIN!"
bfauska
« Reply #7 on: October 09, 2007, 02:19:00 pm »
Oh, so now you call me out in public eh?  ;)  Yep it sure does, too bad that drawing is only on my home PC.  I'll have to fix that tonight, it is only the text that is wrong.
FIXT
« Last Edit: October 09, 2007, 11:45:54 pm by bfauska »
shardian
  • Trade Count: (+23)
« Reply #8 on: October 10, 2007, 10:30:16 am »
I merged your pdf pages into 1 file. Easier to download and manage.
bfauska
« Reply #9 on: October 10, 2007, 11:12:26 am »
Thanks, I'll add it to the first post.  I was using a freeware PDF print driver so I couldn't figure an easy way to make it one file.
bfauska
« Reply #10 on: April 19, 2015, 11:53:53 pm »
Kind of an old thread but since it's in my signature and I'm doing a project based on it I thought I'd bump it with an image of the versatility that's possible with these boxes.
The project in this picture is with 9 boxes based on some very specific control layouts, from Q-bert to Tron, there are several nice setups here. The project is for another forum member so I'll leave it to him to post further details once he gets the boxes and adds the controls and art.
