Author Topic: Built my own high resolution (500 CPR) spinner!  (Read 2675 times)
Major Rock Hardy
  • Last login:April 29, 2013, 06:51:45 pm
  • xybots rocks!
« on: October 06, 2007, 12:21:39 am »
See pictures below.  Machined out of 2" square aluminum tube, brass, and stainless for the shaft (1/4").  Yes I did the machining.
Sensor is a Avago AEDB-9140-A06 with matched 500 CPR codewheel.  Just hooked it up last night to my Opti-PAC and it works great!  Gotta give credit to Whammoed for the 2" aluminum square stock idea (http://www.nicemite.com/Gyramite/images/02Prototype.JPG) - although I kinda reversed the design.
Here is a link to the sensor's homepage in case you want more info:
http://www.avagotech.com/products/motion_control_solutions/encoder_and_codewheel_bundle/aedb-9140-a06/
Sensors run off 5V (supplied by OptiPAC), just require a couple 2.7 K resistors as pull-ups.  Only tricky thing to watch out for is that the encoder wheel is VERY delicate and soldering .050" spaced contacts sucks.  Ok, here's your pics:
Re: Built my own high resolution (500 CPR) spinner!
« Reply #1 on: October 06, 2007, 01:08:19 am »
Sweet!
Good work...
What did the sensor cost? I dont see a price anywhere on the website.
Major Rock Hardy
  • xybots rocks!
« Reply #2 on: October 06, 2007, 01:19:06 am »
Sweet!
Good work...
Thanks for the compliment!
I was actually able to get samples (free).  This was over a year ago so I don't know the current status of sample-getting.
Also, if anyone's interested, I will post the blueprints.  I am working on rev2 right now because the spacing between the grooves on the shaft allows a bit too much vertical slop.  The codewheel stays within the gap of the sensor module but just barely.
bfauska
« Reply #3 on: October 06, 2007, 01:48:27 am »
Looks really clean.  Nice work, I've though about doing something similar, but with just a mouse hack.  Maybe your work will help get me inspired.  Thanks for sharing and I bet that the plans would be appreciated by somebody, if not now than sometime down the road.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #4 on: October 06, 2007, 01:54:27 am »
 :applaud: :notworthy: :applaud:
Zeppo
  • Last login:February 14, 2024, 10:26:44 am
  • Greetings Program!
« Reply #5 on: October 25, 2007, 12:09:05 am »
That's very cool.
I'd be interested in blueprints or any other measurements or tips.
Do you think it could be modified to be a push/pull like the Blackhawk?
I've been thinking about building one of those for a while.
http://www.apachecontrols.com/
Z
