Author Topic: LED brightness ratings (MCD)  (Read 1867 times)
Cornchip
  • Last login:December 27, 2023, 10:23:11 am
  • Thinking up more crap....
« on: October 04, 2007, 08:11:14 pm »
 Just looking for some input on MCD (brightness) of LED's needed for button illumination. Is there a recommended rating I should start with? I'm guessing better than 5000mcd is a good start. I used GGG's button blasters on my last build. They had no ratings...so I have nothing to go by.
 Cornchip.
spacies
Re: LED brightness ratings (MCD)
« Reply #1 on: October 04, 2007, 08:23:20 pm »
I used some 16000mcds on my last illuminated panel.
Probably could have guided planes in if they were outside. Very bright but all good under the buttons.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #2 on: October 04, 2007, 09:06:45 pm »
I think you also need to look at the angle at which the light is spread.
Cornchip
« Reply #3 on: October 04, 2007, 09:31:06 pm »
  I'll definitely worry about the viewing angle of the LED as you mentioned. Thanks for the heads up.
