Author Topic: Quick degaussing question.  (Read 1112 times)
Joystick Jerk
  • Last login:June 26, 2024, 05:10:33 pm
  • Slave to the stick.
« on: September 18, 2007, 01:56:12 am »
I just received my degaussing coil, and had a question about it's power. The instructions do say that the coil can erase magnetic media, so is it safe to use this on the monitor when my PC with hard-drive is 2 feet below it? Should I remove the PC from the cab first and then degauss?
fjl
  • Pixels Rule!
Re: Quick degaussing question.
« Reply #1 on: September 18, 2007, 03:09:51 am »
I'm 98% sure it will be safe to degauss. By the way, you can also degauss with a simple magnet by simply spinning it while moving close to the magnetically damaged area of the screen.
Teebor
  • Last login:June 04, 2009, 12:39:06 pm
  • What does this button do??
« Reply #2 on: September 18, 2007, 06:45:06 am »
It is probably safe but if the Hard Drive is not inside a metal case (i.e. Normal PC Chassis) I would remove it just in case as HDD are a lot easier to mess up then people give them credit for.
Its just a peace of mind thing really.
How was your french toast dear?
Smelly and ungrateful
-American Dad
Joystick Jerk
« Reply #3 on: September 19, 2007, 02:14:19 am »
Well, I tried it with the PC still in the cab, and all went well.
Thanks for the info, guys!
