Author Topic: Old adhesive on a metal CP  (Read 2407 times)
Stobe
« on: August 23, 2007, 10:41:21 pm »
Hello,
I'm putting a new CPO (adhesive vinyl) on a metal CP.  I ripped the old CPO off, and it left most of its adhesive on the metal.  Should I take the time to remove the old adhesive (if so, how).  Or should I just stick the new CPO on the already sticky metal?
The metal is pretty much all covered with the sticky residue.
Thanks for any input!
-Stobe
BrentRadio
  • Last login:March 11, 2021, 06:26:04 am
  • Stop by for a game and a beer!
    • Jack Daniel's Barcade!
Re: Old adhesive on a metal CP
« Reply #1 on: August 23, 2007, 10:44:46 pm »
That stuff is a ---smurfette--- to get off. I finally had to sand blast it off.
None of the removers that I tried really did anything.
Hawk Daddy
  • Last login:June 15, 2025, 03:10:44 pm
  • Only True Pimps Have Arcade Machines!!!
« Reply #2 on: August 23, 2007, 10:45:17 pm »
Definitely remove it.  I used a metal grinder and it worked fine.  And then i painted it black so that anywhere that didn't get covered up wouldn't show threw.
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
Steel Talons 2 player helicopter game
Stobe
« Reply #3 on: August 23, 2007, 10:57:14 pm »
Hmm.  I'll have to admit.  That's not what I wanted to hear.  :)
« Last Edit: August 23, 2007, 11:05:37 pm by Stobe »
Mamiac
  • Last login:October 18, 2007, 10:47:21 am
  • Game NOT over! (Until I pass out)
    • My mame project page
« Reply #4 on: August 23, 2007, 11:01:12 pm »
Yeah, your new overlay wont stick worth a darn if you dont clean the CP up first.  I used WD40 and a scraper (like you use to get the inspection sticker out of your car window) and scraped it off, sanded it, scraped it and so on until it came clean.  It takes a little work but the results are nice!  I'm sure there are better solvents to use than WD40, but thats all I had readily available.  Heres a good example of the difference it makes:
spacies
« Reply #5 on: August 24, 2007, 03:48:56 am »
Use an Automotive tar/grease remover.
It will strip that stuff off in no time.
Very little effort required.
Guaranos
« Reply #6 on: August 24, 2007, 07:50:00 am »
Yeah, I used an automotive grease remover too.  Then I primed and painted it before installing the overlay.  It worked great.
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
« Reply #7 on: August 24, 2007, 09:54:11 am »
Spray a little goo-gone and let it sit for a few, then wipe off.
Kronos
  • Last login:January 11, 2025, 02:00:32 pm
« Reply #8 on: August 24, 2007, 09:59:42 am »
I have the same one.. How do you fill in the holes left over.. mine has Nine button holes per side and some of the are overlaped. I only need 2 or 3 per side.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Working: Not Enough
Projects: Too Many
Progress: None
northerngames
  • Trade Count: (+18)
« Reply #10 on: August 24, 2007, 04:26:01 pm »
a dremel tool with wire brush
burn it with gas and sand it
try finger nail polish remover I used many cleaning products and nothing eats away goop like this stuff well maybe some thinner lol.
8way
  • Last login:February 03, 2017, 05:52:21 am
  • This is my BOOM stick!
« Reply #11 on: August 24, 2007, 08:20:30 pm »
Just did a metal CP last week. I used gas a scraper and steel wool. If you let the gas soak in it scrapes off nicely. You may need to repeat the steps several times. Then when only little bit of adhesive left and the scraper is just smearing it around use the steel wool. You may want to finish it off with some hot soapy water, to get rid of the smell. In the end you have several ways to achieve the same results, but defiantly remove the left over adhesive before applying the new overlay. Good luck.
  • Last login:February 04, 2026, 05:27:25 pm
« Reply #12 on: August 24, 2007, 09:00:54 pm »
With the cost of gas these days, you might be better off having a metal company build a new one.  ;)
Also, I agree with spaces - use a automotive degreaser.
spacies
« Reply #13 on: August 24, 2007, 09:07:44 pm »
Cheers Leapinlew.  :cheers:
I am serious, Stobe don't stuff  about with a dremel or powertools.
Use that tar remover/degreaser like I said and watch the stuff drip off. There is nothing better, trust me.
mountain
  • Last login:Yesterday at 07:00:04 am
    • Mountain Jukeboxes
« Reply #14 on: August 24, 2007, 09:47:20 pm »
Any remover with Xylene works best. You can buy pure Xylene at Home Depot as well.
Good luck!
Arcadiac
  • Last login:April 14, 2020, 01:26:31 am
« Reply #15 on: August 28, 2007, 11:08:31 pm »
http://forum.arcadecontrols.com/index.php?topic=17788.msg142068#msg142068
I took mine to a metal shop, they baked it, ran it thru an abrader and it came out good bare and smooth as new, all for $15, check out the pics.
I had terrible luck with solvents and wasted a lot of time and money.
Pissed me off, I should have just paid someone to kick me in the balls!
Just my experience, good luck!
ARCADIAC!
whatzcrackn
  • Last login:January 19, 2019, 12:14:02 pm
  • U just won tickets to da 'GUN SHOW'
« Reply #16 on: August 28, 2007, 11:41:27 pm »
steel wool and goo off 2 (name maybe off) but with the elbow greese it comes off.
