Author Topic: got U360 + long shafts ... confused ** SOLVED (missing a part)**  (Read 2298 times)
ARTIFACT
**** UPDATE - SOLVED (mising a pastic sleeve piece) ****
I am swapping the short shafts with the longer ones, but I am a bit puzzled
the longer shafts seem to be longer "on the wrong side" ... by this I mean that instead of the "top" being longer, it's the under/inside part that is longer. This means that (again, it "seems") the magnet is hitting the PCB instead of "levitate" above it...
What is this about?
YES I am reading this page carefully:
http://www.ultimarc.com/ultrastik_inst.html
« Last Edit: August 24, 2007, 12:23:16 am by ARTIFACT »
ARTIFACT
Re: got U360 + long shafts ... confused
« Reply #1 on: August 23, 2007, 09:07:10 pm »
phone pic to illustrate ... see how the loger shaft is longer under the CP, not above (it seems to me) See where the lip/bump is positioned on the shaft. Do I need to slide an additional round sleeve piece to pull the shaft up? right now there is so much space below, the spring doesn't get loaded at all -until I assemble it back with the PCB (where it gets "squished")
(thx in advance)
« Last Edit: August 23, 2007, 09:21:17 pm by ARTIFACT »
mlalena
  • Last login:June 12, 2021, 12:31:44 pm
« Reply #2 on: August 23, 2007, 09:54:19 pm »
I've also been looking at the U360, and from what I remember reading the longer shafts are for 3/4" MDF while the shorter shafts are for sheet metal control panels.
So it makes sense that it is longer under the control panel. I think.
ARTIFACT
« Reply #3 on: August 23, 2007, 09:59:11 pm »
I know they are for 3/4",that's what my CP is made with (plywood in my case, Birch). This is why I bought them :)
but even then. By "longer under the CP" I mean longer INSIDE THE JOYSTICK
if that makes more sense
look at the pics. Instead of the stick being longer outside the U360, it's the part under the lip (thinner part of the shaft) that is longer.
« Last Edit: August 24, 2007, 12:23:37 am by ARTIFACT »
« Reply #4 on: August 23, 2007, 10:11:57 pm »
I am using the long shaft in my U360 and I don't recall there being any type of issue swapping it out.  Just be sure to keep everything in order (the clip, spring, etc.) and everything should line up.
ARTIFACT
« Reply #5 on: August 23, 2007, 10:14:39 pm »
thanks for replying! Your projects rock :)
is there an exploded view of all the components somewhere online by any chance?
Do you see what I mean by the inside part of the shaft being longer?
When I assemble the U360 stick with the longer shaft like the other (untouched/regular) U360, the magnet hits the bottom PCB.
At least could someone confirm that this is how the longer shaft is shaped / looks?
« Last Edit: August 23, 2007, 11:03:45 pm by ARTIFACT »
ARTIFACT
« Reply #6 on: August 23, 2007, 11:25:49 pm »
I WAS RIGHT!
Look on the Ultimarcwebsite:
(longer shaft for oval top)
http://www.ultimarc.com/JShopServer/section.php?xSec=10
See the black plastic "sleeve"?
JUST as I expected/thought it was missing
I need ot double check throughout the 2 packages Divemaster127 sent - maybe it is just missing
PHEW! I thought I was going to go crazy
csa3d
  • Will game for food
    • Galaxian Mame Conversion
« Reply #7 on: August 24, 2007, 09:59:07 am »
Sorry to hijack,
So the longer shaft is for flush mounting the metal plate to the under side of the 3/4" wood?  I'm ordering some soon is why I ask.  Thanks!
-csa
scotthh
  • Last login:June 06, 2012, 10:03:42 pm
Re: got U360 + long shafts ... confused ** SOLVED (missing a part)**
« Reply #8 on: August 24, 2007, 11:06:54 am »
Sorry to hijack,
-csa
csa,
Yes. Alternatively, you can use a router to remove some wood, mount the stick in the recess, and use the regular shaft with a wood CP. This is what I did. If you like your joystick up high, you might even rout the wood and use a long shaft.
ARTIFACT
« Reply #9 on: August 24, 2007, 11:33:27 am »
Correct
BTW ... THE U360 ROCKS ... WOW .... I love it...
It *is* a different feel compared to regular arcade sticks, but I even love how SOFT/SMOOTH the regular spring feels, and even the long throw (not THAT long compared to what I read people's posts about it) without restrictors. I don't want it harder to move, nor do I want restricted / shorter ... NICE NICE NICE
Last night, I played Ms Pac Man in true 4 way joystick feel (OK no restrictors ... but still!) ... soooo nice... night and day compared to the previous one I was using (x-arcade / 8 ways).
« Last Edit: August 24, 2007, 11:35:37 am by ARTIFACT »
fatfingers
  • Last login:April 17, 2025, 05:26:08 pm
  • Got UltraStiks?™
« Reply #10 on: August 24, 2007, 08:56:14 pm »
Correct
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
W.W.P.M.D.?                                       I'm here to help ... I just don't do it. ™
ARTIFACT
« Reply #11 on: August 25, 2007, 09:39:11 am »
Oh and OF COURSE I use the FANTASTIC fatfingers plug-in with MaLa and the on-the-fly programming of the sticks is amazing
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #12 on: August 26, 2007, 07:09:52 am »
Apologies for not spotting this thread earlier. Could have answered very quickly! Let me know if you are needing that sleeve:
andy@ultimarc.com
ARTIFACT
« Reply #13 on: August 26, 2007, 11:53:41 am »
thank you Andy! You rock... OMG I looove this U360 stick... AS-IS! no restrictors or different spring... Great product design.
FYI Divemaster127 who I ordered from is sending me the sleeves.
Check out my project thread! I just spent last night on my CP (posted pics)... The short shafts are fine for now while connecting/testing.
ids
  • Fighter Captured
« Reply #14 on: January 18, 2008, 08:54:59 pm »
Does there exist some sort of screw/bolt that can hold it down without also sticking up?
