Author Topic: Easy Led Buttons  (Read 9620 times)
councilface
  • Last login:June 28, 2021, 05:21:26 pm
Easy Led Buttons
« on: July 27, 2007, 02:58:49 pm »
 Hi, I'm a long time listener; first time caller. Im currently in the process of modifying my mame cab. Ive been really impressed by the led buttons and joysticks that I've seen on here and I am truly inspired. So here is my question: Im very inexperienced with electronics and Im looking not to kill myself. What would be the easiest way to hook up some led buttons? I'd like them to ideally to shine when my PC is booted. Is there a way to power the leds via the usb? Any help would be appreciated.
Cheers.
Stobe
Re: Easy Led Buttons
« Reply #1 on: July 27, 2007, 03:07:52 pm »
Easiest?  I would guess the NovaGems from GroovyGameGear.
You might be able to strip the 5V out from USB.  I just used a spare wall-wart I had laying around.
-Stobe
Justin Z
  • Last login:August 23, 2024, 07:17:22 am
« Reply #2 on: July 27, 2007, 03:21:28 pm »
I was a complete newbie as well until I started to build my panel a couple months ago.  I am going to show you a technique that does involve cutting wires inside your computer, but trust me, it is a piece of cake.  You just have to do it and get over the "I don't want to get into electronics" fear.  Once I did that I not only got this to work flawlessly, but I also started to feel confident enough to delve into other things.
The best way I figured out how to do things is this:
First you need to go to Radio Shack or somewhere and buy some quick disconnects and some wire.  Actually if you are planning on ordering the NovaGem glowing buttons from GroovyGameGear you can add some male and female disconnects to your order.  They look like this:
If you can get insulated male and female ones that's best, but whatever really works.  What you do is thread wire into the narrow side and use a wire crimper/stripper . . .
. . . which you can find in any basic tool set like from the Sharper Image or something, to crush the end of the quick disconnect where the wire was inserted so that it can't slip back out.
You are going to cut the red and black wires on one of your CD ROM drive power connectors on the inside of the computer and then strip a little bit of the wire insulation so that you have a nice little bit of wire exposed.  You'll then insert the red wire into one quick disconnect and the black wire into another, and then attach the opposite gender quick disconnect to the other end of each.  It'll look like this, except with red and black instead of yellow and black:
As you can see I managed to get my coin return lights to power up.
Then you need a terminal block; it looks like this:
That's also on the groovygamegear site.  You will take wire from your two quick disconnects and attach each to one side of the terminal.  On the other side you'll be able to attach the power cable for your buttons and your ground cable, respectively.  It'll look like this:
(you can clearly see the wires in the lower right hand corner of the image, connected through the quick disconnects, to the terminal block)
You'll notice I have red and black on one side and then just two wires on the other.  The reason I have all these loops in the block is so that if I need to plug in more than one button, I've got a power source that spreads across the entire one side of the block so I can use any of the terminals on the other side (as long as I match up one with red and one with black) to power buttons.
I know all of this seems complicated but trust me, if you just follow the instructions everything will become crystal clear in no time.  Plus as long as you don't have the power to the computer on and you're careful not to touch exposed ends of the wire to the computer when it's on (that's why you should put the quick disconnects on ASAP, to prevent that from happening) you won't even have any risk of killing yourself because you're dealing with 5V DC at a fairly limited amperage so it's not harmful to you anyway.  I think Edison ran like 1000v DC through his body when he was conducting his smear campaign against AC power.
Not only that but you will actually have fun doing it -- trust me.  Once you're over that fear of delving into the electronics, you'll get all sorts of exciting ideas about what to do with your panel, things you never would've dreamt of before.  It's totally worth it.
Good luck and keep us posted on your progress.
Justin
councilface
« Reply #3 on: July 28, 2007, 12:10:48 pm »
cheers guys. Both sound like fairly uncomplicated solutions. Stobe, how does the wal wart connect to the novagems? again apologies for my nOOb questions.
Stobe
« Reply #4 on: July 28, 2007, 11:52:00 pm »
The Novagems come pre-wired with appropriate resistors, so just double check the source voltage needed (was guessing 5V) and you can wire the possitive lead from the DC "wall wart" to all the possitive LED leads, and the ground from the wall wart to the grounds of the LED leads.
Now this is just generically speaking, so make sure you check the current rating of the wall wart (500mA, 2A, etc) and make sure you don't connect too many LEDs to it.  Randy can tell you how much current each NovaGem draws, since I don't know this off the top of my head.
Hope that helps,
Stobe
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #5 on: July 30, 2007, 06:27:51 am »
As far as easiest/quickest goes, our UltraLux buttons have quick-connects for the LEDs and we sell a daisy-chain harness which enables all the LEDs to be wired in a few minutes.
You could take 5 volts from a stripped-out USB cable (red and black wires) but the PC might give strange USB messages. Or use a PC disk power connector, again red is 5V, black GND.
Justin Z
« Reply #6 on: July 30, 2007, 08:51:05 am »
They draw 100mA, I had to ask him the same question. :)
TOK
  • The Game Always Wins
« Reply #7 on: July 30, 2007, 04:58:26 pm »
In my opinion, the easiest is to get 12v automotive LEDs and connect them directly to the yellow lead of a power supply lead. No resistors, no adapters. I drilled small holes in Happ translucents and stuck them up inside.
    • GroovyGameGear.com
« Reply #8 on: July 30, 2007, 05:27:22 pm »
Yes, but how do they look with the lights on?
jcoleman
  • Last login:March 15, 2025, 04:12:49 pm
  • RTFM
« Reply #9 on: July 30, 2007, 11:54:10 pm »
How long before we see shots of these in action?  Lights on and light off both would be great.  :)
Coleman
TOK
« Reply #10 on: July 31, 2007, 01:28:40 pm »
Ambient light... Its an arcade room, so it's not supposed to be well lit.  ;)
whammoed
  • Last login:November 25, 2025, 03:34:11 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #11 on: July 31, 2007, 06:35:38 pm »
I'm confused.  The automotive 12v LEDs I have used, have all been built into a base (like a wedge or bayonet base) with the resistor built in.  That pic looks like just wires directly on the bulb...but I've never heard of a 12v LED.  Are you sure thats not a tiny incandescent bulb.  If it is truly an LED can you provide a link to an example?
TOK
« Reply #12 on: July 31, 2007, 09:03:11 pm »
These are from Pep Boys, and yes they're LED's, but thanks for the vote of stupidity.  ;)
They're available in multiple colors too. I matched them to the button colors and they're incredibly vibrant. 7 bucks for a 3 pack. Here is a picture of the package.
Every time I post this, people seem to think I'm incorrect or the setup is inferior... Yes they're bright, yes they're cheap, and yes its as easy as stripping some wires and connecting them to an existing plug on your power supply.
whammoed
    • NiceMite
« Reply #13 on: July 31, 2007, 09:41:11 pm »
Cool.  Thanks for the reply.  Wasn't a vote for stupidity, I was just ignorant of the product.  Haven't been to Pep boys in a while.  They must have incorporated resistance within the bulb itself somehow...I guess.  Cool nonetheless.
 Maybe not "cheap", but definitely easy.  (easy usually wins with me)  8)
« Reply #14 on: July 31, 2007, 10:30:33 pm »
From what I can see, they aren't really a bargain, and they don't appear to compare to the light output of the source used in the NovaGems.  Do they list any specifications for these units at all?  The Pilot Automotive web site is no help.
Don't get me wrong.  I'm not knocking the approach.  Just stating that the end result going to be different than other approaches, and whether that result is "inferior" is going to depend on the application and what is expected by the user.  The same can be said for any approach mentioned in this thread.
rlehm
  • Last login:September 30, 2010, 09:04:25 pm
« Reply #15 on: July 31, 2007, 10:31:21 pm »
I spent 332 at groovygamegear, spent 2 days wiring the led-wiz and buttons up. Just to find out my computer doesn't auto install the Led-Wiz as the directions describe. So I have 332 bucks worth of unlighted buttons. I sure am happy.........  :dunno
« Last Edit: July 31, 2007, 10:46:17 pm by rlehm »
« Reply #16 on: July 31, 2007, 10:39:38 pm »
I spent 332 at groovygamegear, spent 2 days wiring the led-wiz and buttons up. Just to find out my computer doesn't auto install the Led-Wiz as the directions discribe. So I have 332 bucks worth of unlighted buttons. I sure am happy.........  :dunno
I just read your email.  I haven't met a computer that the LED-Wiz wouldn't install on, so you might not have something wired correctly.  Best we get you sorted out in email.
rlehm
« Reply #17 on: July 31, 2007, 10:42:13 pm »
This is how I have it wired up:
I even tried the USB ports that I have the I-Pac and Illuminated Joystick Balltops in just incase it was the usb port, I got nothing,
« Reply #18 on: July 31, 2007, 10:51:57 pm »
I don't see your power connections.  Don't even think about powering all those NovaGems from just the 5v on the USB port.  I'm going to need more info, but not here.
rlehm
« Reply #19 on: July 31, 2007, 11:11:00 pm »
A couple more photos:
Will be taking advice on how to install these buttons without the LED-Wiz. They are advertised as brighter than normal LED lights. So they may require a different type install. Can anyone advise me on how to install these buttons another way?
rlehm
« Reply #20 on: July 31, 2007, 11:15:37 pm »
the piece of paper that came with the LED-Wiz and buttons directed me to use the USB cable that was provided. Now I am not supposed to use it?
use this link and refer to Figure 3
http://forum.arcadecontrols.com/index.php?topic=69351.0http://groovygamegear.com/PDF/LEDWIZ+GP_INSTALL.pdf
« Last Edit: July 31, 2007, 11:23:43 pm by rlehm »
rlehm
« Reply #21 on: July 31, 2007, 11:43:42 pm »
Justin
Hey Justin,
I am glad that you made this post. I think I am going to try your method. I have all the supplies here on hand. Wish me luck.
Groovygamegear's parts look very impressive, and seem to be manufactured well. His shipping was excellent, and he even seemed to do extra little things to make life easy. Like the silicone dab on the two wires the kept me from accidentally pulling the wires loose :P
Not sure what the heck I did wrong. I think i'll have more luck wiring it up your way and just putting the LED-Wiz on the shelf for now.
rlehm
« Reply #22 on: July 31, 2007, 11:57:20 pm »
I found an extra Wal Wart laying around that was +5.0 V and gave it a try.... YAY!! to my delight, the button came on. I am going to use one terminal strip for power, and one for grounding all the buttons.
I think i was under the impression that the LED-Wiz was used to light the buttons easily through USB. I did something wrong. I hope I did not leave the impression that the error was on Grovvygamegear's side. I am a total newb.. I am 100% sure it was on my end. I just thought his gear was plug and play simple.
Randy
« Reply #23 on: August 01, 2007, 12:07:28 am »
Not a good idea unless you know that the wall-wart is regulated at +5v  Many unregulated wall-warts put out several volts higher than what is shown on the label and will damage your LED's, and may even cause the resistors to overheat and present a fire hazard!   :o
Stay away from ANY power supply that you don't know to be regulated (as your PC power supply is.)  If you have an ohm meter, check the output before even thinking of using something else.
« Last Edit: August 01, 2007, 12:34:41 am by RandyT »
rlehm
« Reply #24 on: August 01, 2007, 12:53:46 am »
How. How are these to be hooked up. And please leave out the LED-Wiz, I am not going to use it. I keep hearing what not to do, but what am I to do?
rlehm
« Reply #25 on: August 01, 2007, 01:47:01 am »
If any other newbs like me read this and are looking for an easy way to illuminate your buttons, please don't think buying NovaGems+ a LED-Wiz is plug and play. It is not. You will still need to hack your comp for +5v and all tht, so may as well go with much cheaper buttons.
« Reply #26 on: August 01, 2007, 02:27:17 am »
First of all, I want to apologize to all who are reading this for the destruction of this thread with a GGG support issue.  In an attempt at atonement, I'll provide some food for thought relative to the topic while answering the above question.
While lighting projects are fun and not terribly complicated, I cannot stress enough that they require some basic electronics skills.  They are not the same as wiring up a KeyWiz or other input only device.
The abilities one should at minimum possess :
  • read and understand instructions
  • use and understand a multi-meter
  • read simple wiring diagrams
  • understand the power requirements of a device / devices
  • understand the power delivery capabilities of a given power supply
  • safe and neat wiring practices.
  • patience.
Even something as simple as connecting 12v LEDs to a PC power supply needs to have the quantity of the LEDs, the power requirements of those LEDs and the power delivery capabilities of the supply taken into consideration.  If you have a huge power supply with very few devices / drives attached and are connecting only a few LEDs, then this becomes less important.  But connecting 20 NovaGems to a power supply will draw approx. 2 amps of current!  You must know that you have this available and that your wiring methods can support it, or you risk a lot of problems.  This is not the type of project where one can just "wing it" and everything will be fine.  A case in point is where one fairly well-known panel manufacturer caused a whole panel full of RGB-Drives to be destroyed through a wiring error.  We did what we could to ease the burden on the very distraught customer, but it illustrates the fact that not even those who often build control panels are fully up to speed with some of the work required.
So, the simple answer to "How do I light a NovaGem without an LED-Wiz" is that the Cathode side (the side with the heat shrink covered resistor that would normally go to the output of the LED-Wiz) goes to Ground.  The other side (Anode) goes to a well-regulated 5v DC power supply, such as the one in your PC.  With this information, one must then consider the number of NovaGems to be connected, the best and safest method of making those connections (jumpered euro-style terminal blocks in many cases) and whether the power supply has enough 5v DC current left to drive that quantity of devices after the motherboard, video card, processor, USB Devices, Hard Drives, DVD Burner, etc. are considered.
In conclusion, this is not a project to fear as some fantastic looking panels with enhanced functionality will result when done properly (as we continually see.)  But no-one should think for one moment that  any method of lighting a panel is just going to be "plug and play" with no knowledge or ability required from the user.  This is specialized fabrication, no different than what kiosk manufacturers do.  It stands to reason that some skills will be required.
« Last Edit: August 01, 2007, 02:32:41 am by RandyT »
bfauska
« Reply #27 on: August 01, 2007, 02:32:29 am »
Which buttons are you referring to that will be much cheaper that won't also be more work?
NovaGem + 5v = lit button.
LedWiz + 5v(if lighting more than 5 buttons) + USB + NovaGem = controllable lit button.
Cheaper button + drill + LED + resistor + solder + wire + 5v = lit button
While not being the cheapest option for illuminated concave pushbuttons, the NovaGems look good to me.  Using other sources you could save less than maybe $2.50 a button if you were willing to shop several sources, cut and strip wires, drill holes, solder resistors and wires, and cover the resulting product w/ heat-shrink tube.  And even after all that work you would probably end up with a product that doesn't glow as evenly or as brightly.
Green Giant
« Reply #28 on: August 01, 2007, 02:48:26 am »
You are supposed to use the usb to drive the on-off control of the ledwiz.  The computer tells the chip on the ledwiz what buttons to light, but it only acts as a great big switch.
LED's, while efficient, still consume power.  The nova gem leds not only require 5V but also 100ma.  The document you are refering to specifically says, "It is pre-configured for USB supplied 5v DC power with a total current delivery of 500ma or less."  This is 500ma total through the usb cable.
This means no more than 5 nova gems can be hooked up with the usb cable alone.  Also on that document is directions on powering the full current load necessary.  Remove the jumper and add a simple 5V line from your computer power supply.  The thing about USB is that it can only supply .25watts.  Your computer power supply probably has 300watts.  Using a wall wart for the 5V power using the ledwiz could cause problems with the ledwiz and wall wart having different grounds.
You will not see anything on the LEDwiz if you don't give the onboard chip enough power to turn on.  Try removing all but two nova gem buttons from the ledwiz.  If you still don't see anything when you plug it in, you might have a problem.
Now if you need help or advice on supplying the 5V just let me know.
Toxic Arcade, my first build
Green Giant
« Reply #29 on: August 01, 2007, 02:54:13 am »
The funny thing about what you said is the innaccuracy.  "You will still need to hack your comp for +5V and all that,".
You should have said "you still need to hack your computer for 5V and thats it."  Really, if you supply the 5V from your computer, using some really simple extension plugs, all you do is plug and play.
Connecting 5V to a computer power supply or external supply is much more complicated as you will have to regulate the power with resistors so you don't blow the diode.
rlehm
« Reply #30 on: August 01, 2007, 05:27:28 am »
My point was simply, if it aint plug and play, it wasn't worth 332.00 when I could have paid half, and done a little more work. Simple as that.
rlehm
« Reply #31 on: August 01, 2007, 05:33:37 am »
Well, that would explain my last failed attempt. I cut the red and black dvd wires inside my computer, powered up the novagems that way, 3 dead at start up, while checking the wiring of them, more began to fail. Guess I needed resistors.
I did email RandyT before receiving these. Told him in an email that I read the instructions on his website and did not understand them. He replied that I need wait for the buttons to be infront of me before he'd help, as then it would make more sense. I mailed saying I had them, 2 days later and after 3 emails, I started posting here. I too am sorry this landed here, but hey, he was checking this place, and not his email.
Doesn't what you say conflict?
You say, just hook it to a computer with extensions, and plug and play,
then you say it is much more complicated and you can't just hook it to a power supply without a resistor. it is this kind of conflicting advice that leaves me thinking wtf.... this type of confusing advice got me into this mess..
« Last Edit: August 01, 2007, 05:52:22 am by rlehm »
TOK
« Reply #32 on: August 01, 2007, 06:01:47 am »
The 12v automotive option I showed is bright and evenly lit. They are bright enough that the buttons light reflects off the ceiling in the dark. I wouldn't want 7 flashlights blasting me in the face, so any brighter would be silly. Drilling takes all of 5 seconds, no resistors.
My whole lit build was around 40 bucks, and that is with spare LED's since I did different colors and they came in a 3 pack.
Green Giant
« Reply #33 on: August 01, 2007, 09:17:07 am »
I thought the space inbetween the paragraphs meant they were two separate thoughts.
The extension I refer to is just an easy way to hack up your computer power supply to get 5V out.  Then you run this into the ledwiz.
Then the space inbetween those paragraphs was refering to your idea.  You mentioned using your own led's and an external power supply.  Either way you do it, you would have to find the correct balance of resistors to leds to make sure you don't blow them.  The resistor cuts some of the voltage sent to the led.  This voltage drop determines how bright it will be.  The ledwiz can control the intensity of the led's automatically.  Otherwise you will be stuck with one brightness on them or have to wire in a potentiometer on every led.
The first thing I said is the easy way, at least it seems much easier to me.  The second is the hard way.
The option from TOK sounds good and cheap, but it requires more soldering and work than the nova gems you already have.  But if you are really dead set on not using your ledwiz, there are a ton of people on here that would snatch it up for a reduced price.
The extension cable is the one shown below.  To get 5V, you cut it in half, tape up the yellow and black wires so they don't short, attach a long wire to the red and another to the black.  Wire the red, 5V line, to the ledwiz as seen on the diagram.  Attach the black, ground, to the ledwiz ground.  Now you have power for all the nova gems.
mcfreak
  • Last login:March 01, 2021, 01:55:04 pm
  • Asteroids moving along...
    • Hobby Blog
« Reply #34 on: August 01, 2007, 10:18:06 am »
  • patience.
Randy,
I have to commend you for being so level headed about this.  There are threads in the past where your products were attacked and it ended up being a huge battle.  I love my GGG products and would only shop with you (And tornado terry's  ;) ).  This response makes me want to go replace all my buttons with NovaGems...  :cheers: :applaud:
Havok
« Reply #35 on: August 01, 2007, 10:27:46 am »
rlehm, step away from the computer. Pay someone to do it...
« Reply #36 on: August 01, 2007, 10:47:43 am »
Check and double-check your wiring.  The NovaGems have these resistors in place, and unless they were cut off or the LEDs attached to a power supply of higher than intended voltage, they should not be "failing".  In the unlikely event that there is a problem (I say unlikely as this is the first instance we have had of anything like this for the hundreds of these we have shipped) then return them for evaluation and, if necessary, repair.
The rest is not exactly an accurate characterization.  I'm happy to hold someone's hand through the installation process, as I have done many times before.  But I can't do it if the customer hasn't even received the parts yet.  It will literally take 5 times the explaining and in the end, little will be accomplished.  I also can't do it if I am not in front of my email when it arrives (6:59 pm in this case)  I was out until 9:30pm at which time I chose to log onto here and make the short post in this thread before "going back to work".  This act is apparently what precipitated the onslaught.  For the record, no other emails were received prior stating that your parts have arrived and you were awaiting help.
« Last Edit: August 01, 2007, 12:39:52 pm by RandyT »
« Reply #37 on: August 01, 2007, 01:19:59 pm »
I did the automotive LEDs/drill a hole in the bottom of clear ones, but thats before I knew about the LED Wiz.
rlehm, I'll give you $166 for your set up, thats exactly half. then you can do it your way and I'll redo mine randys way.
rlehm
« Reply #38 on: August 01, 2007, 02:31:35 pm »
I used the red wire from the dvd player as stated here. These buttons pop, one by one. Smoke fills the button, then pop. I don't think anyone wants to buy these from me. sure most were fine, but why would i wany 40 out of 48 buttons to be lit?
I won't be discussing this further. RandyT's responces to me in email is not helpfull, but be-little me. So I give up. I am ripping these from my machine. I will just settle on the unlighted buttons I originally had. I guess I am just too stupid to dp this, right?
Later.
Thanks goes to those who tried to help me out and not blame my unawareness, and make me feel stupid.
« Last Edit: August 01, 2007, 02:36:23 pm by rlehm »
Green Giant
« Reply #39 on: August 01, 2007, 02:45:55 pm »
After the first button popped, did you try switching which wire is connected to the power.  LED's are direction specific.  You need to push the current through one way, otherwise you will mess it up.
