Author Topic: GO7 Blurry Monitor issue  (Read 4334 times)
ToplessZ
  • Last login:December 08, 2018, 09:55:34 pm
« on: July 05, 2007, 02:43:54 pm »
I have a 19" Electrohome GO7.  When I turn it on it takes 20 mins to "warm up" before the picture becomes clear.  I have done a full Bob Roberts repair kit, (cap kit, replaced flyback, transitor, and fueses) still no change.  When I first bought it it was having this issue, I capped it and it fixed it right up.  The picture and color was perfect.  Then after a month of using it, I turn it on and its right back to being blurry again, this is when I recaped and did the Bob kit but didnt fix it.  Any other suggestions?  I have tried to reflow just about everything on the chassis as well.
SirPeale
  • Green Mountain Man
Re: GO7 Blurry Monitor issue
« Reply #1 on: July 05, 2007, 03:03:20 pm »
Have you adjusted the focus knob?
ToplessZ
« Reply #2 on: July 05, 2007, 03:12:39 pm »
Yea, still doesnt fix it
grantspain
« Reply #3 on: July 05, 2007, 05:58:31 pm »
perhaps the tube is dying
Ken Layton
  • Guru
  • Technician
« Reply #4 on: July 05, 2007, 08:00:15 pm »
You could have one of two problems:
1. The flyback (especially if original) may be going bad.
2. The picture tube needs rejuvenation.
Kevin Mullins
    • Me on Myspace
« Reply #5 on: July 05, 2007, 08:51:07 pm »
I think you're totally screwed... set it on the curb and be done with it.   ;)
Have you reflowed all joints on the neck board as well?
Have you measured the heater voltage on the neck board?
Possibly the tube dying as mentioned.
(good time for a tube swap project maybe)
ToplessZ
« Reply #6 on: July 09, 2007, 09:45:54 pm »
I got my hands on another GO7 chassis and intalled it to my tube....and it works great! problem is, that chassis isnt mine :banghead:  So I need to figure out what on my chassis is wrong?  I also noticed that when I discharged the "other" chassis after testing it there is alot of voltage discharged, when I discharge my chassis I never hear a snap at all.  So what can cause a monitor to be blurry that isnt changed out on a normal cap kit and flyback change?
Kevin Mullins
    • Me on Myspace
« Reply #7 on: July 10, 2007, 01:17:35 am »
Sounds like a power issue of sorts.
Have you measured the B+ voltage on your chassis?
ToplessZ
« Reply #8 on: July 10, 2007, 09:50:35 am »
I got 118V at the big white resistor, adjusted it to 120v. Still blurry :dizzy:  What would be the next thing to check?  I was thinking about replacing the large cap, its like a 680uf 200v, do you think that could be the issue?
« Last Edit: July 10, 2007, 09:55:26 am by ToplessZ »
hammad
  • Last login:August 14, 2011, 04:23:27 am
« Reply #9 on: July 10, 2007, 10:46:45 am »
Blurry picture ..... usually its flyback problem .....
« Last Edit: July 10, 2007, 10:49:00 am by hammad »
ToplessZ
« Reply #10 on: July 10, 2007, 10:56:19 am »
Already replaced the flyback, but I will go back and make sure Im getting good connections...
grantspain
« Reply #11 on: July 11, 2007, 06:11:28 pm »
do you get the exact same fault that you had before the cap kit and flyback change or is the fault different
ToplessZ
« Reply #12 on: July 15, 2007, 07:12:28 pm »
same before and after
Kevin Mullins
    • Me on Myspace
« Reply #13 on: July 15, 2007, 07:22:55 pm »
Is there a focus line/lead on these ?
Going to the neck board ?
(I'm fishing for something simple here)
grantspain
« Reply #14 on: July 15, 2007, 07:29:37 pm »
thats what i was thinking at first(reversed leads),now i am learning towards a broken trace somewhere
ToplessZ
« Reply #15 on: July 15, 2007, 07:44:13 pm »
Yes, there is, Im gonna resolder it at the pot and see if that helps..
Ken Layton
  • Guru
  • Technician
« Reply #16 on: July 16, 2007, 01:59:41 am »
I've seen instances where the picture tube socket on the neckboard was either corroded internally on the socket pins or the focus wire where it's soldered inside the tube socket has got bad solder.
