Author Topic: Coctail restoration/ Mameification. - Now Double the Pleasure!  (Read 3194 times)
Stobe
Well, as if I had nothing better to do, I went and picked up a cocktail project that someone decided to abandon.  So with your help, I hope to get this thing to a presentable/playable condition.
Thanks to some fine members here, we've started to narrow down what this cocktail may have been.  Even without pictures, they've done a good job so far.  So perhaps with these pictures below, we can get a definate answer.
The rounded edges, I'm told, are the giveaway that it may be a Pacman or Galaxian.
Notice also the P1 P2 button holes that were added.  And the mystery hole above the coin door.  There is an identical hole on the opposite side.  As far as I know, the guy I got it from said there were just speaker grills over these holes (vents?)
The "veneer" as he called it appears to be shelf paper.  (At least that's what the extra rolls he gave me said).  I'm thinking about peeling that stuff off and perhaps getting some vinyl from partsexpress.  Any experiance with that stuff for cocktails??  What color looks best?
Here's a picture of the CP areas.  The bottoms have been chewed out to fit new joys and buttons.
Since these CP "wings" are glued in pretty good, I'm probably going to use them, but cut out the rest of the bottoms and put new wood in there.
Here's a picture of the new CPs this guy had fabricated.  He paid over $200 to make them???  (should have gone to mikesarcade.com or the like).  Unfortunately, the carriage bolt holes are HUGE!  If I decide to use these, is there anything I can do about that?  I put in some #10 bolts, and the head doesn't slip through, but it obviously doesn't stop from turning also.
Here's the coin door that came with it.  Looks like a Stern?  It had some angle iron bolted to it to be used with a padlock, I imagine.  So its got a few extra holes in it.  But it doesn;t look like a real good fit for the hole.  As seen above, the coin door hole has the 4 corner bump-outs, and those don't get covered by this Stern door.  The opening is about 12 1/4" x 12 1/4".  Any idea what would be the best door for that opening?  (midway door?)
(just noticed you can't really see the extra holes in this picture too good.  But they're there, lol).
And here is a close up of the CP "wings".  (sorry for the rotation).  These look awful "shallow" to me.  I've got some J-sticks that will probably be short enough, but I fear standard happ buttons will be too long.  Should I get the replacement leave buttons for this CP?
I've got a new monitor that came with it (no pics yet, sorry).  Its a WG with VGA input.  This project also came with a decent enough computer, and an old IPAC, so initial plans are to make it a mame machine.
Thanks for looking.  Don't expect super fast progress, as I have another project cab I'm picking up tomorrow (ug!)
-Stobe
« Last Edit: July 05, 2007, 11:15:06 pm by Stobe »
Crowquill
  • Last login:November 21, 2024, 09:42:17 am
Re: Midway cocktail restoration
« Reply #1 on: July 05, 2007, 03:16:28 am »
Hey! Maybe it's a Stern cocktail! Kinda like the one on the Super Cobra Flyer.
Now you might have to change the title of your project.  ;D
I'm interested to see what you work out for the vinyl. I have a Ms Pac cocktail that I'm working on ever-so-slowly. I'm thinking about using Cherry vinyl instead of Teak (which I think is the closest to the original Midway laminate). I figure if I'm going to go to the effort I might as well make it look a bit more like modern furniture since this one won't be in my office/game room.
« Last Edit: July 05, 2007, 03:21:44 am by Crowquill »
Stobe
« Reply #2 on: July 05, 2007, 06:05:26 am »
That would explain the stern coin door.  Does anyone know if that coin door is supposed to have a frame around it, or does the left hinge screw into the wood.  (The fram would explain the slightly larger hole).
-Stobe
  • Last login:November 25, 2025, 07:49:55 pm
« Reply #3 on: July 05, 2007, 08:26:03 am »
-Stobe
Ahh, is this the guy from craigslist? I talked to the guy. I felt he wanted too much to for me to take on the project. I'll be interested to see how it turns out. Good job.
« Last Edit: July 05, 2007, 08:27:47 am by leapinlew »
shardian
  • Trade Count: (+23)
Re: Coctail restoration/ Mameification.
« Reply #4 on: July 05, 2007, 10:02:10 am »
Yeah, that's not a midway cabinet. Although with the designs so similar, I wonder who copied who back then. ;)
I am using the Teak laminate. I just don't like the "BAM! In yo FACE!" factor of the cherry.
Stobe
« Reply #5 on: July 05, 2007, 10:20:12 am »
Seems like all the metal parts so far that I have are pretty much the same as that used on a Midway cocktail.
I'll probably post a picture tonight of all the parts that were in the box I got, so I can get all these things identified. :)
-Stobe
Crowquill
« Reply #6 on: July 05, 2007, 12:54:15 pm »
-Stobe
The pic of the Super Cobra one seems to have a frame. I also realized that the flyer for The End shows the same cocktail.
Stobe
« Reply #7 on: July 05, 2007, 11:14:13 pm »
You're not going to believe this...
I went today to pickup another project upright, and the guy asks..."are you looking for anything else, I have a few machines left from a big purchase"
So I ask him... "you wouldn't happen to have any pieces from a Stern cocktail?"
He said... "Like this one?"  (lifting a box of parts off a table, which happens to be a Stern cocktail.
Me:  "Yup. like that one". >:D
So it looks like I may be doing a TwoFer.  Perhaps a Mr and Mrs Pac at the same time?
-Stobe
theCoder
Re: Coctail restoration/ Mameification. - Now Double the Pleasure!
« Reply #8 on: July 06, 2007, 12:26:07 am »
Sounds like you're going to busy 'til Christmas.  What are you going to do with two cocktail cabs?
Stobe
« Reply #9 on: July 06, 2007, 09:36:19 am »
I'll probably end up finding a new home for one of them, to help fund the hobby.
(Or I could drop it off at the local Pizza Hut so I'd have something to play when I ate there)  :)
-Stobe
