Author Topic: GameLists: Multiple emuls in same list work-around solution  (Read 331815 times)
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
Re: Mala multiple emuls in same game list work-around solution
« Reply #40 on: August 14, 2007, 10:27:02 pm »
worked great!  thanks SGT!!!
diverdown
  • Last login:April 21, 2025, 03:45:48 am
« Reply #41 on: August 29, 2007, 07:56:46 am »
SGT  is your layout available for others to use.  I LOVE IT
If it ain't broke give it to me...i'll soon fix that
SGT
  • Last login:March 04, 2026, 07:39:32 pm
« Reply #42 on: August 29, 2007, 08:31:25 am »
If you are referring to the one below, I can make it available.  If you're referring to the older plain one, I'll have to see if I still have it.  Let me know.
sega_mad
  • Last login:July 09, 2015, 04:03:08 am
« Reply #43 on: September 02, 2007, 01:31:13 am »
Hi SGT,
Back again, I have a  question relating to this thread.
Am wanting to add Daytona to my MALa list. I have followed your instructions, buy am confused when I get to number 7. I don't know how to create a mame.cmd.
Any help appreciated
Also, is Daytona and sega rally fully playable with model2 emulator?
I'm sure I will have more questions before I get this right!!
Cheers
SGT
« Reply #44 on: September 02, 2007, 10:41:29 am »
Just open notepad and copy & paste the contents quoted earlier.  Then modify it to suit your setup and save it to the your mame folder with the name "mame.cmd".
Yes, they are fully playable and a lot of fun.  The graphics are not 100% perfect yet.
sega_mad
« Reply #45 on: September 03, 2007, 12:47:27 am »
Cheers, Will have a go.
I'm running mame 1.14...will that be OK for sega rally, and Daytona?
Will these 2 games be supported in mame in the near future, so I wont have to run model 2?
thanks again
sega_mad
« Reply #46 on: September 03, 2007, 01:43:44 am »
SGT
Please help. I can't get it working.
Here's what I did
In C drive I created a folder called "m2emulator" (this has the m2 exe emulator inside)
Also in C drive, I created a folder called "otheremulator" (this has a m2 folder, and inside this is the Daytona zip rom)
I followed your other instructions regarding mala, and had no problem there, so I think the problem must be with the mame.cmd file.
this is what's in my mame.cmd
if "%2" == "C:\otheremulator\m2" goto m2
mame.exe %1
exit
:m2
cd ..\m2emulator
closemul.exe emulator.exe zip %1 rar
exit
Hoping you can help,
Cheers,
Sega mad
SGT
« Reply #47 on: September 03, 2007, 09:44:11 am »
Someone can correct me if I'm wrong, but I think it will be a long time before computers are fast enough for Mame to run Daytona at an acceptable speed.
« Last Edit: September 03, 2007, 10:00:34 am by SGT »
SGT
« Reply #48 on: September 03, 2007, 09:59:47 am »
Here's what I did
mame.exe %1
exit
:m2
cd ..\m2emulator
exit
1) First of all, are you able to run Daytona in the M2 emulator manually (not using Mala)?  In other words, at a C prompt in the m2emulator folder, does it work when you type:
closemul emulator.exe daytona
2) Is the m2emulator folder on the same folder level as the Mame folder?  If its not then the "cd..\m2emulator" command will not work.  In other words, if the Mame folder is here:
c:\emulators\mame
Then the m2emulator folder should be here:
c:\emulators\m2emulator
3) Also the folder names where the m2 rom is stored is case sensitive in the batch file.  Therefore since "\otheremulator\m2" is in your batch file, these actual folder names MUST be lower case.
4) Make sure there is not a Daytona rom in your mame roms folder or Mame will run the rom instead of the m2 emulator.
5) What are any errors you are getting? If you're not getting any errors, set Mala to NOT hide the command window.  Put a pause command into your batch file to help with troubleshooting.   For example:
:m2
pause
cd ..\m2emulator
exit
When you run Daytona from Mala, (if you unhide the command window) you should see a black command window and the code stopping on your pause command.  This will at least tell you whether the batch file is branching to the m2 section or not.
If none of that helps, you need to post screen shots of the pertinent Mala configuration screens that you have set up.  You also need to tell me what folder Mame is in and answer ALL the questions above.   ;)
« Last Edit: September 03, 2007, 10:18:02 am by SGT »
sega_mad
« Reply #49 on: September 04, 2007, 12:29:49 am »
Hi again,
Man I feel stupid, I can't even complete question number 1...can you spell that out for me!!
I moved the m2emulator folder to the mame folder...no help
Did have the case (lower) correct
Daytona rom is not in mame
Not getting any errors....it wont run, just goes back to mala!!
I tried the pause in the batch file, and unhide the command window. but the black screen was gone so fast i couldn't read it!!
As for the last one, how do I post screen shots!!
So sorry for all the dumb questions, and thanks for your help so far.
Chees
« Last Edit: September 04, 2007, 12:52:04 am by sega_mad »
SGT
« Reply #50 on: September 04, 2007, 10:20:49 am »
No, I just wanted to make sure that the m2emulator folder and the mame folder are subfolders that are side by side, so to speak.  For example, I have a folder called "emulators".  In that folder is my m2emulator folder *and* my mame folder.  It doesn't have to be this way, but that's the way it needs to be unless a change is made to the batch file.
Providing you have your folders set up as outlined as above:
Click START, then click RUN
Type CMD, then click OK
In the black window, type the following:
C: <ENTER>
CD \emulators\m2emulator <ENTER>
What error if any do you get?
Not sure if you're asking how to create a screenshot or how to attach one into this forum.
1)  Bring up the Mala option screen that you want.
2)  Press PrintScreen
3)  Click Programs>Accessories>Paint
4)  Click Edit>Paste
5)  If you know how, crop out all of the screen shot accept for the Mala options window
6)  Save the file.
7)  When posting a reply, choose Additional Options....
8 )  Browse for the attachment that you saved in the Paint program.
sega_mad
« Reply #51 on: September 04, 2007, 03:42:09 pm »
Hi Sgt,
Many thanks for the instructions....very easy to follow!!
I have changed the folder around to how you have  it.....m2emulator inside emulators folder.
Here are the screen shots
Cheers,
Sega-mad
SGT
« Reply #52 on: September 04, 2007, 04:42:15 pm »
1) You need to open m2's emulator.ini file into notepad and make sure the Dir1 is pointing to your rom folder which I assume should be:
Dir1=\otheremulator\m2
2) You don't have the closemul program in your m2emulator folder.  This is a wrapper that allows for the ESC key to close the m2emulator.  You can download it at the link below.  Make sure you unzip into the m2emulator folder.
http://lustar.free.fr/clusters/closemul/
3) Retry the CMD steps again, but make sure you type it exactly.  Last time you had a typo.  Make sure it is NOT emutator :laugh2::
C: <ENTER>
4) Try the above step twice as I know that the closemul program creates the closemul.ini file the first time it is run.
5) After the second try, post the error messages that you get.
EDIT ADDITION:
I didn't see a screenshot of your Mame command line.  Make sure it is:
%rom% %path%
Notice the space between %rom% and %path%
« Last Edit: September 04, 2007, 04:50:31 pm by SGT »
sega_mad
« Reply #53 on: September 04, 2007, 05:00:50 pm »
Hi again,
Mame command line is correct (has space)
But the download for the esc wrapper does not work. When I try to extract the file it says "cannot open file.it does not  appear to be a valid archive"
Cheers
SGT
« Reply #54 on: September 04, 2007, 05:04:37 pm »
I can download and open it okay.  Sometimes when corruption occurs on downloads its necessary to do the following:
This time right-click the download link and choose "Save Target As".
Keep trying until the archive is valid.
sega_mad
« Reply #55 on: September 04, 2007, 05:09:13 pm »
Tried that.
Am I missing something....this is the only file I can see to down load "Closemul v0.3.0.2"
sega_mad
« Reply #56 on: September 04, 2007, 05:14:30 pm »
Tried it again, if I put my mouse over the file it says
"no zip file, bad zip file, or part of a spanned/split zip file"
SGT
« Reply #57 on: September 04, 2007, 06:07:09 pm »
Email attachment sent.
sega_mad
« Reply #58 on: September 04, 2007, 11:25:34 pm »
Ok, think I'm making progress.
After I did the re install, now it looks like I can get to the m2 emulator from Mala, but there is a fault/error with the roms. I'm running mame 1.14...could that be the problem?
Cheers
« Last Edit: September 04, 2007, 11:27:08 pm by sega_mad »
SGT
« Reply #59 on: September 05, 2007, 08:21:19 am »
Cheers
No, Mame has nothing to do with the M2 emulator.  I would say that either you have the wrong rom or M2 is not looking in the right folder.  Open the Daytona rom and see if the files that it says are missing are in there.  If the files aren't there, you have the wrong ROM.  If they are there, you need to check and make sure that the line in M2's emulator.ini file is pointing to the right folder for your roms.
« Last Edit: September 05, 2007, 08:37:22 am by SGT »
Lakersfan
  • Last login:February 14, 2026, 05:37:56 pm
« Reply #60 on: December 21, 2007, 01:14:03 pm »
I was wondering if someone can help me out with this ... I am trying to get fceUltra to play Super Mario Bros. 2 (USA).zip and (of course) add this one game to my main list (which is primarily mame games).
If I open a command prompt, I can get this cmd line to run just fine:
Closemul.exe fceu.exe "I:\Emulators\emulators\fceUltra\roms\Super Mario Bros. 2 (USA).zip" so I don't think that's my problem.
I can get it listed in my games by editing the mame.xml file, adding this:
<game name="Super Mario Bros. 2 (USA)">
                                  <description>Super Mario Bros. 2</description>
                                  <driver status="good" emulation="good"/>
</game>
However, I'm pretty sure my screw up is somewhere in my mame.cmd file:
if "%2" == "I:\Emulators\emulators\fceUltra" goto fceUltra
mame.exe %1
exit
:fceUltra
cd ..\fceUltra
exit
but I can't figure it out!
Any suggestions?
ps- attached a pic if helpful...
SGT
« Reply #61 on: December 21, 2007, 02:46:39 pm »
Where is fceUltra.exe located?  Is it located here?:
Where is mame.cmd located? Here?:
I:\Emulators\Mame
or here?:
I:\Emulators\emulators\mame
Lakersfan
« Reply #62 on: December 21, 2007, 03:44:27 pm »
fceu.exe is located here: I:\Emulators\emulators\fceUltra
mame.cmd is located here: I:\Emulators\Programs\mame
SGT
« Reply #63 on: December 21, 2007, 04:24:50 pm »
That being the case, in mame.cmd change:
cd ..\fceUltrato:
cd \Emulators\emulators\fceUltra
Also %2 will equal the folder that the rom is actually in; therefore, change:
if "%2" == "I:\Emulators\emulators\fceUltra" goto fceUltrato:
if "%2" == "I:\Emulators\emulators\fceUltra\roms" goto fceUltra
Note that the path in the preceding line is case sensitive.  Once you get it working, you won't want to use the actual rom name in mame.cmd, but I'm guessing you probably already know that.  There may be more problems, but that is what jumps out at me right now.
SGT
« Reply #64 on: December 21, 2007, 04:29:38 pm »
Another thing that I'm not sure about is you have Mala to search subfolders under I:\Emulators\emulators which is correct, but the roms are two levels down instead of one level down.  I haven't tested Mala to know whether Mala searches for roms in subfolders of subfolders if you know what I mean.
Edit:  Nevermind.  A quick test shows Mala will search down more than one level of subfolders.
« Last Edit: December 21, 2007, 05:48:38 pm by SGT »
Lakersfan
« Reply #65 on: December 21, 2007, 06:15:32 pm »
Well, before you posted your response I was trying to figure some things out. Sorry, but I'll have to re-verify a few things. My folders are now as follows:
Main- I:\Arcade
Mala- I:\Arcade\mala
Emulators- I:\Arcade\emulators
Mame- I:\Arcade\emulators\mame
fceUltra- I:\Arcade\emulators\fceUltra
fceUltra Roms- I:\Arcade\emulators\fceUltra\roms
Based on that, I changed my mame.cmd from
cd ..\fceUltra to
cd I:\Arcade\emulators\fceUltrawhich is where my fceu.exe emulator resides.
Also, you said,
so I changed my line to
if "%2" == "I:\Arcade\emulators\fceUltra\roms" goto fceUltraI refreshed my games and still no-go.
The error that pops up is so fast it's hard to read. But I think it says something along the lines of
I:\Arcade\emulators\mame>if "Mario" == "I:\Arcade\emulators\fceUltra\roms" goto fceUltra
I:\Arcade\emulators\mame>mame.exe Super
"Super" approximately matches the following:"
then it goes and list some mame roms.
Maybe this has something to do with the rom name of "Super Mario Bros. 2 (USA)" since it has spaces. Also, where is it getting "Mario" from in the first line?
Here's my latest mame.cmd file:
mame.exe %1
exit
:fceUltra
Closemul.exe fceu.exe "I:\Arcade\emulators\fceUltra\roms\Super Mario Bros. 2 (USA).zip"
exit
SGT
« Reply #66 on: December 21, 2007, 06:58:42 pm »
Yeah, the spaces in the rom name is causing a problem.  In Mala for the command line you'll need to enclose %rom% with quotation marks:
"%rom%" %path%
You also need to change:
cd I:\Arcade\emulators\fceUltrato:
cd \Arcade\emulators\fceUltra
You can include the drive letter in the cd command if you need to change drives if you use the /D parameter.  But in this case, its not needed.
TheManuel
  • Last login:April 09, 2025, 10:13:43 pm
  • On and off hobbyist
« Reply #67 on: December 21, 2007, 10:07:31 pm »
Thank you for providing that work-around, SGT.
I just begun playing with Mala and, like you, I use one or more older versions of MAME for some games.  At a glance, I could not find a way to have all the games from the different versions show up on the same list so I figured I had not tried hard enough.
However after reading through your post, I am completely shocked that this is not a basic feature of such a powerful front-end considering how many different emulators are out there for arcade games even if MAME is so ubiquitous.  I imagine most people would like to have a list that includes all arcade games regardless of what emulator runs them.
At any rate, I know I should not look a gift horse in the mouth.  Your work-around sounds like a good deal so I will give it a try.
Regards.
"The Manuel"
SGT
« Reply #68 on: December 21, 2007, 10:34:42 pm »
@TheManuel  -  Thanks for the kudos. :cheers:
@Lakersfan  -  Be forewarned.  I have played around a little bit with fceUltra.  Adding the quotes around %rom% for Mala's mame commandline works for fceUltra, and it doesn't seem to affect Mame.  However, it did cause a problem with VivaNonno.  I haven't tested to see what problems it might cause with the other emus that I use in the Mame gamelists such as M2, Daphne, Zinc, Radikal Biker, Mjolnir, and PC Games.
Fortunately, Mala has the Advanced feature for the Mame command line which allows for conditional command lines.  I may be wrong, but I believe any problems can easily be resolved by adding a conditional command line based upon the rom path.
On another note, I noticed after exiting fceUltra that the Mala screen was scrambled.  When this has happened before, I usually resolve it by setting the emulator resolution to the same resolution used by Mala.   I wasn't able to run fceUltra at the same resolution without it crashing.  This is no big deal for me as I do not intend to run this emulator, but I wanted to give you a heads up in case you encounter the same problem.
Lakersfan
« Reply #69 on: December 22, 2007, 12:54:33 am »
Thanks for the help, SGT. However, I still am unable to get it to work. One quick question after re-reading your post. Do I need a "dummy" file of Super Mario Bros 2 somewhere?
From what I can tell, I am getting the same error when trying to run the game ... it seems to be looking in mame roms for a game similar to Super Mario Bros. 2.
SGT
« Reply #70 on: December 22, 2007, 10:43:27 am »
In your case, you don't need a dummy file because the actual fceUltra rom is stored in the searchable rom path.  You really need to see exactly what variables Mala is passing to Mame.cmd.  To do this you can add the following two lines at the beginning of mame.cmd:
echo %1 > test.txt
echo %2 >> test.txt
After you have attempted to start that game, view the contents of test.txt which is in the mame folder.  The first line is your rom name and the second line is the rom path.  Post the contents of test.txt here if you want to.
Lakersfan
« Reply #71 on: December 22, 2007, 11:53:57 am »
Thanks! Will give a try a bit later today after I'm done xmas shopping and a few other pre-Christmas chores. :p
Lakersfan
« Reply #72 on: December 22, 2007, 01:07:39 pm »
Here's my test.txt:
SGT
« Reply #73 on: December 22, 2007, 01:14:14 pm »
Wow.  Isn't your Super Mario Bros rom actually in?:
Any chance you have a second copy of that rom sitting in?:
Lakersfan
« Reply #74 on: December 22, 2007, 03:03:19 pm »
Yes, the rom is in I:\Arcade\emulators\fceUltra\roms
For whatever reason, I also had the rom in I:\Arcade\emulators\fceUltra... I took it out but I get the same exact log as above when I try to run it.
last mame.cmd file:
echo %1 > test.txt
echo %2 >> test.txt
mame.exe %1
exit
:fceUltra
exit
Thanks so much for all your help with this.
« Last Edit: December 22, 2007, 03:05:06 pm by Lakersfan »
Lakersfan
« Reply #75 on: December 22, 2007, 03:11:35 pm »
no wait .. it works now! I just had to do a refresh in mala... one of the most basic things.
Thanks for helping me out with this!!
SGT
« Reply #76 on: December 22, 2007, 03:25:40 pm »
Great!  :cheers:
TheManuel
« Reply #77 on: December 23, 2007, 12:30:58 am »
 :banghead:  :banghead:  :banghead:  :banghead:
I feel better now.
Hey SGT:
I can't get it to work with an older version of MAME.
Here is what my mame.cmd looks like:
if "%2" == "D:\MAME\roms104\Using" goto mame104
mamep.exe %1
exit
:mame104
cd D:\MAME\Emulator\MAMEplus_Intel_0.104
mame.exe
exit
The problem is that the rom name is not being passed to the alternate version of MAME described above.  It simply starts MAME as mame.exe and I get the quick text the command line version of MAME displays when you start it without a rom namea.
Any ideas where I can start looking?
Thanks.
"The Manuel"
SGT
« Reply #78 on: December 23, 2007, 07:49:13 am »
Two things to change and two things to check on:
Change
mame.exeto:
mame.exe %1
Change
cd D:\MAME\Emulator\MAMEplus_Intel_0.104to:
cd \MAME\Emulator\MAMEplus_Intel_0.104
Also the following is case sensitive, so make sure it matches the folder names exactly:
To verify that Mala is passing the exact same thing as the line above:
Put the following as the first line in the mame.cmd:
echo %2 > test.txt
After you attempt to run the game, check the contents of test.txt file which will be in the same folder as mame.cmd.  There will be one line in test.txt that should match EXACTLY (case included) the line below:
Also make sure that there is not a rom with the exact same name in your regular rom folder.  I am assuming you changed the mala settings as outlined earlier in this thread.
TheManuel
« Reply #79 on: December 23, 2007, 11:24:34 am »
Thank you SGT.
The %1 after mame.exe did it.
I will knock my head a few more times against the wall for not trying that after everything I did try.
I had assume %1 was rompath #1 and %2 rompath #2 when %1 is actually the rom name and %2 is the path.
I should point out that including the drive letter after cd does not affect the process.
Regards.
"The Manuel"
