Author Topic: Where to get 5/8 inch MDF?  (Read 6034 times)
Spyridon
« on: June 15, 2007, 01:35:35 pm »
I would like to make my cotrol panel out of 5/8 inch MDF, however, Lowes and Home Depot (at least in my area) only carry it in 3/4 inch and 1/2 inch.  Any one know where to get 5/8 inch thick MDF?
If I can't get MDF in this size, and recommendations on what type of 5/8 inch wood to use?
ScottS
  • Last login:November 01, 2007, 02:21:30 pm
Re: Where to get 5/8 inch MDF?
« Reply #1 on: June 15, 2007, 01:58:02 pm »
Try Plywood and Lumber Sales (PALS) in San Jose, California. They have everything!
ChicagoDave
  • Last login:May 18, 2023, 11:08:23 am
    • Dave's Website
« Reply #2 on: June 15, 2007, 02:52:10 pm »
I got it at Home Depot.  The first Home Depot I went to only had 3/4, but I tried another one a little farther away and they carried the 5/8.
Just shop around, or phone first... :-)
Homer Simpson:
"Here's to alcohol, the cause of, and solution to, all life's problems."
fjl
  • Pixels Rule!
« Reply #3 on: June 16, 2007, 04:19:58 pm »
Home Depot I go to didn't have 5/8 MDF. Then months later when I returned they now carry it. By the way, didn't someone say that its a bad idea to make a cp out of MDF?
Spyridon
« Reply #4 on: July 23, 2007, 04:48:10 pm »
Okay, I've called every Home Depot, Lowes, and 84 Lumber in the area and none of them carry 5/8 inch MDF.  Any suggestions on what other type of wood would work well for the control panel?
ScottS
« Reply #5 on: July 23, 2007, 05:19:06 pm »
Try calling a lumber yard that isn't part of a national chain. Tell them you want 5/8" MDF. If they tell you they don't have it in stock, tell them you want to special order it. You might also try WoodFinder to locate a lumber yard in your area that can special order the stuff. WoodFinder doesn't have a search for MDF, so try "Hardwood-veneer plywood". Places that carry hardwood-veneer plywood will tend to sell to custom cabinet shops, so they're more likely to stock or at least special order 5/8" sheet goods. Not everyone is listed in WoodFinder, so be sure to use your local yellow pages, too!
If you can't find 5/8" MDF and 5/8" sheet good can work: plywood, OSB (assuming you're going to laminate it), melamine, particle board, etc.
Spyridon
« Reply #6 on: July 24, 2007, 03:46:48 pm »
Thanks for the info ScottS.  Yesterday I was able to find a local small lumber yard that can special order it for me.  Quick turnaround too.  I ordered today and it will be here on Thursday.
