Author Topic: How do you cut a marquee retainer?  (Read 2650 times)
  • Last login:Yesterday at 12:10:15 pm
« on: June 11, 2007, 10:16:42 pm »
I just busted up the end of one of the strips trying to cut it with the radial saw - it just cracked into pieces.  Is there an easy way to get a clean/smooth cut?  The plastic is pretty thick...
RetroACTIVE
  • Last login:January 28, 2024, 04:27:52 pm
  • Gramps
Re: How do you cut a marquee retainer?
« Reply #1 on: June 11, 2007, 10:43:58 pm »
I cut mine with a hack-saw... fine enough teeth so as not to bite too much.
Happy Gaming!
northerngames
  • Trade Count: (+18)
« Reply #2 on: June 11, 2007, 10:58:03 pm »
dremel cut off wheel
cut with razor close to the desired then sand flush
tin snips may work also
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #3 on: June 11, 2007, 11:03:32 pm »
I threw mine at the table saw and it cross cut it like butter.  Nice finished edge ta boot.
I was rockin one of those 80tooth blades but I dont think it really matters if you go slow.
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« Reply #4 on: June 11, 2007, 11:16:40 pm »
I wedged mine between two small pieces of scrap MDF and blew through all of it with my circular saw. No prob!
My old user name was marlborroman13, but I kicked the habit many years ago!
bfauska
« Reply #5 on: June 11, 2007, 11:22:37 pm »
Anytime the material being cut can fit between the teeth on a saw you have to feed very slowly so that the saw cuts instead of grabbing the part.  With a shape like a marquee retainer the other potential problem is that parts of the piece can essentially be unsupported while cutting, the retainer on my Dynamo is simply plastic angle but I know that some marquee retainers are more like a U shape stuck onto an L this leaves some of the plastic out in the air instead of against a fence or table, this piece will try to snap out of the way when cutting so if you can fill the gaps with some scrap wood or something like that then you can also avoid the part catching the blade and breaking.
I don't know whether or not that made any sense, but I hope so, it should help if it did.
  • Last login:Yesterday at 09:19:57 pm
« Reply #6 on: June 12, 2007, 05:56:40 am »
Like this:
ChicagoDave
  • Last login:May 18, 2023, 11:08:23 am
    • Dave's Website
« Reply #7 on: June 12, 2007, 06:50:52 am »
I used tin snips, and then just sanded the edge smooth.
Homer Simpson:
"Here's to alcohol, the cause of, and solution to, all life's problems."
« Reply #8 on: June 12, 2007, 07:15:30 am »
Everyone is doing it the hard way. Just get one of these. Cutting the marquee retainer will be a breeze:
http://cgi.ebay.com/9554-FLOW-WMC2-4040-WATERJET-MACHINING-CENTER_W0QQitemZ120054383457QQcmdZViewItem
« Reply #9 on: June 12, 2007, 09:00:48 am »
I'm going to put in a $1 bid.  It seems totally worth it.
I ended up using a mitre saw to make the cut - it came out just OK - it was a jagged blade so it didn't go through the plastic like I wanted it to.  What do you guys thing about using a lighter to carefully melt the plastic on the ends where the cut is?  I'm hoping it creats a smooth looking surface when it melts and rehardens... I have a few inches to spare so I think I'm going to give it a shot...
« Reply #10 on: June 12, 2007, 09:24:35 am »
Whats the deal with the plastic? Seems you could get angle iron from Home Depot and end up with a much more durable retainer and a 8 foot section only costs $10 for the stuff I was using.
« Reply #11 on: June 12, 2007, 09:57:05 am »
You know, I'm not really sure.  It's pretty simple stuff and not decorative at all.  It does have a nice rounded corner and is pretty thick (probably 1/8"), which is something I guess.  I could have bought an L-bracket and spray painted it or something (I wanted black) but it never really crossed my mind until I already ordered it.
« Reply #12 on: June 12, 2007, 10:05:30 am »
Oh, that sounds nice. I was thinking you were using a corner protector (those plastic L shaped things you put on walls).
« Reply #13 on: June 12, 2007, 10:27:36 am »
This is the stuff:  REALLY long link - shortened.
Not the greatest picture on their site though...
« Last Edit: June 12, 2007, 10:39:55 am by Peale »
BradC
  • Last login:December 22, 2010, 05:56:28 pm
    • My First Arcade Cabinet
« Reply #14 on: June 12, 2007, 10:29:59 am »
[Edit]Nevermind, I totally missed the point of what you were asking. [/Edit]
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« Reply #15 on: June 12, 2007, 12:59:26 pm »
The custom marquee I sell I cut with a radial arm
thanks
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
