Author Topic: Joystick Screws?  (Read 2006 times)
cowguy
  • Last login:August 08, 2011, 01:07:41 pm
  • an 80s child in spirit
Joystick Screws?
« on: June 05, 2007, 08:04:32 pm »
How could I mount my joysticks so the bolts don't show?  I see some control panels with them showing and some that don't have them showing, I really don't wont giant metal things stickin out of my cp.
ChicagoDave
  • Last login:May 18, 2023, 11:08:23 am
    • Dave's Website
Re: Joystick Screws?
« Reply #1 on: June 05, 2007, 08:20:56 pm »
Homer Simpson:
"Here's to alcohol, the cause of, and solution to, all life's problems."
DrumAnBass
  • Last login:July 10, 2024, 10:36:54 pm
  • "I love this computer magic!" - Viv Savage
« Reply #2 on: June 05, 2007, 09:26:59 pm »
T-Nuts work dandy for that - just route out a little indent for the top of the t-nut.
"Some drink from the fountain of knowledge; I only gargle."
KenToad
  • Last login:Today at 01:07:28 pm
  • Flap Flap Flap
« Reply #3 on: June 05, 2007, 11:37:08 pm »
I use T-Nuts, as well.  I just cut out a little circle in the CP top (or route, as DrumAnBass said) so the T-Nuts are flush, then run bolts up into them through the joystick mounting holes on the bottom of the CP.  It seems to be the simplest way to seamlessly mount Happ joysticks in wood.
BobA
  • What Me Worry?
« Reply #4 on: June 06, 2007, 01:21:41 am »
Do the T nuts work OK in MDF as well as wood?   Thinking MDF does not hold screws as well as wood so what about the T nuts?
KenToad
  • Flap Flap Flap
« Reply #5 on: June 06, 2007, 01:40:01 am »
I have mine in MDF.  Worked well so far.  You have the force of gravity on your side, so I guess it wouldn't be too likely that the T-Nuts would come loose.
northerngames
  • Trade Count: (+18)
« Reply #6 on: June 06, 2007, 06:30:16 am »
I cut a counsink on a drill bit and made the holes just a tad smaller then the screw I was using so it still threads tight but I just have mine screwed in and have not had any problems at all and I too use mdf but I use 3/4" mdf with formica.
(+_+)
  • Let me splain.
  • Last login:July 27, 2012, 09:00:32 pm
  • For I am ]{eyser Soze
« Reply #7 on: June 06, 2007, 09:30:27 am »
Wouldn't it be the pinch between the T-Nut and bolt and not the force of gravity?
This plan is so perfect, it's retarded. -- Peter Family Guy
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
« Reply #8 on: June 06, 2007, 11:16:25 am »
Definitely pinches the wood inbetween.  That's what the teeth are there for, to bite into the wood, hold in, and prevent spinning.
KenToad
  • Flap Flap Flap
« Reply #9 on: June 07, 2007, 12:35:16 am »
Umm, yes.  Posting tired, sorry.   :dizzy:
langdoguk
  • Last login:October 30, 2009, 03:45:23 pm
  • hey you Guys !
« Reply #10 on: June 07, 2007, 05:22:35 am »
Has anyone got any pics of them using the T-Nut , I've never seen them before but they sounds pretty good , any certain size ?
Help I'm useless !!!!
