Author Topic: P360 base the same size as a super base?  (Read 1639 times)
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« on: June 02, 2007, 08:41:05 pm »
Can I use my Happ super router template for a P360?
I am top mounting a P360 that wont arrive for a few weeks.  Can I use the same router template to top mount it?
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: P360 base the same size as a super base?
« Reply #1 on: June 02, 2007, 08:48:57 pm »
Should match fine.  Go for it.
Jeff AMN
    • Gamer Theory
« Reply #2 on: June 02, 2007, 09:15:50 pm »
Yes you can.
I have a panel that has two P360s and one super. While I was putting the panel together I checked out of curiosity and they were the same.
Kremmit
  • - AHOTW -
« Reply #3 on: June 03, 2007, 02:50:55 am »
FWIW, P-360s are made on the same base pattern as old-school Wico sticks- which, in turn, have the same mounting dimensions as Happ Ultimates, Competitions, Reunions, 49-ways and Supers.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #4 on: June 03, 2007, 09:14:50 am »
Yeah, I used my Wico base just to be sure.  My concern was the are under the top of the base.  I figured the widest part of the base (top) looked exactly like a wico.
My concern was the circle part on the bottom of the P360.  I dont know if I'll be able to "drop in" for a top mount.  Does the round base part come off?
Kremmit
  • - AHOTW -
« Reply #5 on: June 03, 2007, 05:29:01 pm »
Yeah, the round part will unscrew.  It's just barely wider than the narrow dimension of the top portion of the base assembly, like 1/16" - 1/8" wider.  The round part begins 1 1/8" from the top of the base assembly, and the total height of the base assembly is 2 1/8" with the round part installed, not including handle/actuator.
« Last Edit: June 03, 2007, 05:30:57 pm by Kremmit »
