Author Topic: New category - Power Options  (Read 13611 times)
shorthair
« on: May 17, 2007, 11:12:46 pm »
Again, nothing striking, but it should be helpful. Let me know what you think.
http://wiki.arcadecontrols.com/wiki/Power_Options
Re: New category - Power Options
« Reply #1 on: May 18, 2007, 02:43:42 pm »
Good start.  Makes me think, though, that maybe we need a couple people to take on editors' roles and clean stuff up once in a while.
shorthair
« Reply #2 on: May 18, 2007, 08:19:12 pm »
Yeah. I've thought about it.
Felsir
  • Last login:July 09, 2025, 03:34:33 am
  • Creating cab artwork
    • Felsir's World
« Reply #3 on: May 23, 2007, 04:30:42 am »
I moved it from the front page to the "design considerations" section. Seems more appropiate there IMHO.
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #4 on: May 23, 2007, 10:15:13 am »
Is that what I'm supposed to be doing? Oh crud!
« Reply #5 on: May 23, 2007, 11:40:15 am »
Well, you could do it, but I meant mostly grammar, and here specifically shorthair's spiffalicious wordification tendencetas.
JoyMonkey
    • JoyMonkey.com
« Reply #6 on: May 23, 2007, 11:47:50 am »
I reworked the Power Options article. Pulling the plug without shutting down the computer properly is what most people are worried about, so it probably deserves at least a mention.
I thought this would already have been covered in the Wiki someplace  :dunno
shorthair
« Reply #7 on: May 23, 2007, 03:23:43 pm »
Yeah, good additions/corrections, particularly the images (which I thought about but don't know how to do that). The only thing that was taken out that I think is important is the powering-up part - how it might need to be hacked, whether it can operate like a Smartstrip, etc.
« Reply #8 on: May 23, 2007, 04:29:40 pm »
Yeah, that's good... the UPS option, it may be worth mentioning, does limit the OS possibilities down to which ones your given UPS will support.  They require OS drivers to perform the gracious shut down.  They're also not really designed to do that on a regular basis and it could really shorten the battery life of a lower end UPS (the type we'd use in a cab).
Kaytrim
  • I'm too nice a guy
« Reply #9 on: May 23, 2007, 05:53:24 pm »
Here is a link to a site with information on how to make your own smart strip type of power source.  http://home.bendcable.com/werstlein/  I used this basic information and info from another site http://spystyle.arcadecontrols.com/01/index81.htm to build my own.  Works perfectly. 8)
« Last Edit: May 23, 2007, 05:59:28 pm by Kaytrim »
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #10 on: May 24, 2007, 07:15:39 am »
Yes it better to add links from Building page, since it basicly a tool.
Nice article elsewere and using such a thing my self to poweroff monitor and speaker automatic when the pc shutdown.
btw I just added back links.
shorthair
« Reply #11 on: May 26, 2007, 03:19:59 pm »
How's that?
« Reply #12 on: May 29, 2007, 09:27:26 am »
How is what?
shorthair
« Reply #13 on: June 02, 2007, 12:01:05 am »
The battery dying thing.
« Reply #14 on: June 06, 2007, 03:33:58 pm »
All batteries are not good for all applications.
shorthair
« Reply #15 on: June 07, 2007, 02:40:46 pm »
Oh, I see. Any devices that have a sleep-type draw would be drawing on them while the unit is off (if it is in your particular case; it would be in mine), which means it'd have to be designed differently - say, the power switch placed after the batteries, or probably more effectively a master switch and a relief switch. Hm.
« Reply #16 on: June 12, 2007, 07:10:37 pm »
I hacked a cheap power strip from walmart..
Check this out:
http://skennys-arcade.blogspot.com/2007/06/power-strip-hack.html
It is also very possible to "kill" a cheap power strip this way:
http://skennys-arcade.blogspot.com/2007/05/switching-power.html
Hope this helps..
--Skenny
