Author Topic: **DESIGN PERIOD COMPLETE - 2007 BYOAC Token BACK SIDE Design Thread**  (Read 40871 times)
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
This thread is for the design discussions and proposals regarding the back(reverse) side of the 2007 BYOAC token.
We are designing  .984" (25mm) tokens.  Submissions should be in black and white only.  White should indicate the lowest point of the token, black the highest.  If you want to show half-height details use gray. Different levels of gray are OK.  Of interest as you design,  the 'lowest' or 'deepest' point on the token will usually be shiny because it doesn't require machining.
So that those of us who are not Photoshop Gurus are given a fair shot , no 'blinged' renderings should be posted. (Bling refers to color, photorealistic renderings.)
Guidelines/Rules
-No R-Rated material
-No trademarked or copyrighted images. (Pacman, etc...) MAME IS OK though, we have approval to use the logo if we like as long as we respect the spirit of MAME - i.e. no references to playing thousands of games, etc.
-No Bling - refer to the 2004 thread below to see how blinged line art turns out. Pixelhugger will bling all final entries for us.  Thanks!
-Should display "Build Your Own Arcade Controls" (or at least "BYOAC") and the www.arcadecontrols.com URL on the front because BYOAC is the whole point of the tokens.
-If at all possible you should have your art in vector format. (AI for example.)  Next best is very high-res raster (Hi-res meaning greater than or equal to 300DPI,) but I discourage it because we have always used vector with superb results.  Low-res artwork won't work, you will need to have someone fix it up for you.  Vector fonts need to be converted to curves.
If you are submitting what you consider your final proposal, please say so in your post. Otherwise we will assume you are submitting it for group discussion and tweaking.
This is a sample from 2004:
Here are previous years' threads for reference.
2006 Front
2006 Back
2005 Front
2005 Back
2004 combined thread
Go for it!
« Last Edit: September 25, 2007, 10:10:58 pm by Santoro »
  • Last login:March 17, 2026, 03:35:03 pm
    • GroovyGameGear.com
Re: **2007 BYOAC Token BACK SIDE Design Thread**
« Reply #1 on: May 14, 2007, 03:44:11 pm »
How about a post with artwork for all of the past years designs, and maybe even the finished token photos next to them, for those who may not have been following along.
It might help to get the process going to see, in one place, the current designs and how they finally translated to the real deal.
nostrebor
  • SHOCKING!!
« Reply #2 on: May 14, 2007, 04:31:35 pm »
Also, Randy would like a pony.
« Reply #3 on: May 14, 2007, 04:37:46 pm »
Ok, how about just the artwork proofs sent to the mint for manufacturing?  I'm assuming someone has these and can throw a few pictures up in a post, no?  Got to be easier than everyone going through old threads trying to figure out which designs finally made it.
BTW, I already have a "pony" and it has 1100cc's  ;)
Pixelhugger
  • Last login:March 05, 2026, 11:55:53 pm
« Reply #4 on: May 14, 2007, 04:38:05 pm »
 Grin
:laugh2:
Me too. Because hey. Free pony.
« Last Edit: May 14, 2007, 04:42:21 pm by Pixelhugger »
Project mega thread HERE
Pixelhugger
« Reply #5 on: May 14, 2007, 04:41:13 pm »
I think I have them. I'll put together a token walk down memory lane for posting. Probably a good idea so the newbies can see what the submissions should look like. Last year people still submitted stuff that wasn't line art.
« Last Edit: May 14, 2007, 04:42:53 pm by Pixelhugger »
Zakk
  • Last login:Today at 12:55:51 am
« Reply #6 on: May 14, 2007, 10:37:39 pm »
This should be completed....sometime around 2017.
sirwoogie
  • Supreme Chancellor
  • Last login:April 23, 2025, 10:29:35 pm
  • It's Hollyfeld in a Winnebago!
« Reply #7 on: May 14, 2007, 11:33:02 pm »
OK. I gotta admit that is a pretty gnarly burn. :)
Joystick Jerk
  • Last login:June 26, 2024, 05:10:33 pm
  • Slave to the stick.
« Reply #8 on: May 15, 2007, 03:09:59 am »
Could we reverse that decision about no blinged entries? Not to be too harsh, but if you honestly have no idea how to "bling" an image of a coin, you're probably not up to the task of designing a usable image in the first place.
Edit: Messing around in photoshop, ideas are sparse this late. Comedy entry for laughs:
*** Image link removed by moderator.
 Edit2: ::)
« Last Edit: May 15, 2007, 06:36:23 am by Joystick Jerk »
mwatson
  • Last login:July 03, 2007, 07:28:59 pm
« Reply #9 on: May 15, 2007, 04:52:35 am »
Wow been awhile since I've seen that image anywhere, bets on how long it'll be before its editted?
JoyMonkey
  • Voodoo Wiki Master . . .
    • JoyMonkey.com
« Reply #10 on: May 15, 2007, 08:19:56 am »
Last year there were a lot of designs that would have suited the front or the back either way; would it make more sense to just have one thread and then vote on the two best designs out of them all?
Seems like the only requirements are that "2007", "ArcadeControls.com" and the chosen annual slogan (All Your Slogan Are Belong to Us) be featured on the token; these could be edited into most token designs pretty easily once the two designs have been chosen. Designers could just keep in mind that there should be two spaces on each side reserved for this text.
« Last Edit: May 15, 2007, 08:29:39 am by JoyMonkey »
Joystick Jerk
« Reply #11 on: May 15, 2007, 08:27:31 am »
I asked this back in 2005, and the answer was basically no dice. Makes sense and cuts down on the thread hopping back and forth... go figure.
Pixelhugger
« Reply #12 on: May 15, 2007, 11:45:57 am »
Well, the idea was to keep the entries on equal ground. Otherwise it becomes a contest for who can create the coolest looking gradients and embossing. It really distracts attention from the designs themselves.
I do think the entries should be "blinged" before voting. But they should all be done identically.
Pixelhugger
« Reply #13 on: May 15, 2007, 01:42:36 pm »
Heh. Or later.. since I've switched computers several times since 2004 I can't seem to find them.  :dunno
Santoro
  • Santoro
    • ArcadeReplay!
« Reply #14 on: May 15, 2007, 09:29:18 pm »
I'll do it, I just need a few days.. lots of family stuff happening right now, and work is busy on top of that.
But no Ponies.  If my daughter can't have one, no one can.  ;)
Joystick Jerk
« Reply #15 on: May 15, 2007, 09:33:34 pm »
I was thinking maybe make the coin sort of exotic looking, like it was an arcade token from south america or something. Sort of has an incan/aztec feeling to it, with the BYOAC logo carved in stone atop an incan pyramid. This is of course a rough mockup, final quality will be much higher. Just looking to get opinions on the concept and layout right now.
NIVO
« Reply #16 on: May 16, 2007, 09:36:34 pm »
even more stickiness for your pleasure, ewwwwwwwwwww.
Anyhoo, these token threads will be stickied until the designs are finalized. Then will be unstickied and fade into BYOAC realm.  :cheers:
Pixelhugger
« Reply #17 on: May 18, 2007, 04:40:54 pm »
If Santoro is interested, I'm willing to bling final entries as long as they can be provided properly. IMO it's important that all the final entries be given identical treatment. If someone else has a better way to bling and is willing to do them, I happily defer.  :) :)
For me to do the blinging I'd need the file of the final design setup in black, white and grey as Santoro outlined above. No gradients. No embossing. Just line art and solid greyscale shapes.
The best format for the process is Illustrator. If that's not available, a layered Photoshop file at 2000x2000 pixels will work. If that's not possible a JPEG of the same size (2000 x 2000) can be used but the results may not look very good.
Cross posted in "FRONT SIDE" thread.
Pixelhugger
« Reply #18 on: May 18, 2007, 04:52:28 pm »
Here's my backside. Errr. Entry.
And here's the blinging I'm talking about. I decided to post this (even tho it makes me a hippocrite) because it seems like enthusiasm for the design process doesn't really pick up until the bling stage. So again, if anyone has final entries they'd like blinged send them my way. Final entries only. It definitley makes a big difference seeing how the designs will look in relief. Santoro.... let me know if you're OK with this. If not I'll pull it.
Now lets see more designs!!
Kaytrim
  • I'm too nice a guy
« Reply #19 on: May 18, 2007, 04:57:38 pm »
I like this one best of any so far. :cheers: Nice job Pixel
Kaytrim
Santoro
  • Santoro
    • ArcadeReplay!
« Reply #20 on: May 19, 2007, 07:35:11 am »
This would be very cool. I have nothing against Bling, I just want it to be fair for all entries!
Thanks Pixel.
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #21 on: June 13, 2007, 07:59:29 pm »
Pixelhugger, for some reason that cabinet makes me think of an Elvis (as in the king) impersonator.
Pixelhugger
« Reply #22 on: June 13, 2007, 09:03:29 pm »
 :laugh2: :laugh2: :laugh2: :laugh2: :laugh2: :laugh2: :laugh2: :laugh2: :laugh2: :laugh2: :laugh2: :laugh2: :laugh2:
It's the sequined jumpsuit it has on.
steveh
  • Last login:January 29, 2024, 09:33:42 am
    • thecrazysteve.com
« Reply #23 on: June 14, 2007, 10:59:55 am »
how does this process work?  once decided do we get them made up?  how much do they cost?
Pixelhugger
« Reply #24 on: June 14, 2007, 11:08:05 am »
We vote between the submissions. Then final designs get made into standard .984" tokens. You can see where prices have been at Santoros website arcadetokens.com. I don't think those prices are necessarily accurate for new designs, since the mint is always raising prices.
steveh
    • thecrazysteve.com
« Reply #25 on: June 14, 2007, 11:44:45 am »
thansk for the speedy reply.  this is the year i finally get my arcade machine.  i will be ordering these. its the minor touches like this that make all the difference.
Santoro
  • Santoro
    • ArcadeReplay!
Re: **TIME IS RUNNING OUT! 2007 BYOAC Token BACK SIDE Design Thread**
« Reply #26 on: July 05, 2007, 12:14:39 pm »
OK, let's put an end date on this.   Please submit your final entries by end of day, Sunday July 8.
dstone
  • Last login:January 14, 2021, 01:03:52 pm
    • Vectorcade
Re: **TIME IS RUNNING OUT - 2007 BYOAC Token BACK SIDE Design Thread**
« Reply #27 on: July 09, 2007, 12:06:15 am »
Here are two finals for the back. As I stated in the Front thread, I don't have Illustrator but did the vector work in AutoCAD (minus the text). I can provide the DWG file if requested, which I've heard will directly import into Illustrator.
Edit: It helps when I actually read the instructions for image dimensions...
« Last Edit: July 09, 2007, 01:21:49 am by dstone »
jfunk
  • Last login:October 24, 2018, 04:36:39 pm
  • BYOAC Wannabe
    • JFunk's Arcade
« Reply #28 on: July 10, 2007, 08:39:10 am »
Well, I still like mine from last year, so I'll add it back to this thread including the blinged out version that Pixel did (so he doesn't have to do it again  :)  )
Thanx!
fatfingers
  • Last login:April 17, 2025, 05:26:08 pm
  • Got UltraStiks?™
« Reply #29 on: July 10, 2007, 10:46:00 am »
Go jfunk!
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
W.W.P.M.D.?                                       I'm here to help ... I just don't do it. ™
dcsipe
  • Last login:November 09, 2015, 08:45:36 pm
« Reply #30 on: July 10, 2007, 06:51:39 pm »
I thought we were wrapping things up on Sunday? When's this thing going to finally be done?????
jfunk
  • BYOAC Wannabe
    • JFunk's Arcade
« Reply #31 on: July 11, 2007, 08:26:57 am »
I'd like to see a few more entries to vote on before we close shop on this thing..  Want to make sure we get great tokens again!  Not that there aren't great entries already, but it's always nice to have choices  :)
dcsipe
« Reply #32 on: July 11, 2007, 03:33:13 pm »
Seriously though?  The thread has been open for nearly 2 months.  We keep waiting around for more entries and it'll be time to start working on the 2008 tokens!  I can't imagine that there are people who have been working on tokens designs for the past 2 months and just need those few more days to get em in.
jfunk
  • BYOAC Wannabe
    • JFunk's Arcade
« Reply #33 on: July 11, 2007, 03:38:20 pm »
Heh..  Were you around for last year's threads?  :)
This is the way it goes..  :)
I agree, there probably aren't those who've been toiling away for months..  but there are those procrastinators who have an idea and are only now realizing they'd better get them in or it'll be too late  :)
And, if this goes like last year, we will now have to vote on tokens..
We _THEN_ have to vote on slogans..  And THEN we do pre-orders..  And THEN we wait for the tokens to be minted..  So, I hope nobody's urgently needing tokens  :)
This is nobody's fault.  It's just the way it seems to go...
dstone
    • Vectorcade
« Reply #34 on: July 11, 2007, 04:39:43 pm »
Huh, wish I would have known that. Would have saved me from the mad scramble of trying to get this stuff together at the last minute.
Pixelhugger
« Reply #35 on: July 11, 2007, 04:47:15 pm »
In past years there seems to have been much more interest. More entries. More posts. More discussion. I'm hoping that there is actually enough demand to do the run, especially given the higher prices. :'(
fatfingers
  • Got UltraStiks?™
« Reply #36 on: July 11, 2007, 06:27:56 pm »
Yes, I have noticed and been wondering the same.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
dstone
    • Vectorcade
« Reply #37 on: July 13, 2007, 10:00:07 am »
Just out of curiosity, is there anyone out there still working on a design?
mr.Curmudgeon
  • It's going to hurt your brain. A lot.
  • Last login:October 11, 2021, 07:15:49 pm
  • Huzzah!
« Reply #38 on: July 14, 2007, 09:01:52 pm »
I was thinking of creating a design...but I've been hella busy these past few weeks. I just checked today and noticed the Santoro suggested a July 8th deadline.
So as far as I know, I missed out. If there's still time, I can try to finish it up over the next few days.
JustMichael
« Reply #39 on: July 18, 2007, 07:02:38 pm »
I don't know if there is still time or not but I know the tokens haven't been minted yet...
I think everyone would like to see your design.
