Author Topic: Soft-15KHz - slim new tool for 15KHz on normal vga cards  (Read 1151170 times)
0 Members and 11 Guests are viewing this topic.
damdai
  • Last login:April 03, 2008, 12:22:24 pm
« Reply #400 on: March 13, 2008, 11:46:34 pm »
Nope, only single display. The only khz options i have in quickres are 60. im not sure what numbers my monitor is shoing in the OSD, but its something like 30 over 50. i can get the exact numbers later if u want them, but they were around there.
Yeah they all should show up with 60Hz (which is vertical refresh btw.), but you shouldn't be able to actually SEE anything on your VGA Monitor now.
Why not? My monitor is capable of displaying up to 800x600.
SailorSat
  • Last login:Yesterday at 07:07:40 pm
    • For Amusement Only e.V.
« Reply #401 on: March 13, 2008, 11:50:34 pm »
Hm... Actually the D9400 should sync to it, my fault.
What does the OSD tell you?
northerngames
  • Trade Count: (+18)
« Reply #402 on: March 14, 2008, 01:26:08 am »
 :notworthy:
bent98
  • Hyperspin Moderator
« Reply #403 on: March 14, 2008, 08:48:24 am »
One last question sailor since I dont have my new ati card to test. When you used that big usermodes.txt list. Did you have any specific resolution specified in the pacman.ini file or mame auto selected that right resolutions and refresh or does it use a default resolution in the pacman.ini file as a reference?
damdai
« Reply #404 on: March 14, 2008, 09:41:57 am »
I'll check when I get home from work tonight. I also have an ATI Radeon X850 to try as well.
SailorSat
« Reply #405 on: March 14, 2008, 10:01:50 am »
I don't use any INIs at all. MAME selects resolutions itself.
northerngames
« Reply #406 on: March 14, 2008, 04:54:03 pm »
I have a radeon X1650 pro 512mb on the way and will post the results.
damdai
« Reply #407 on: March 14, 2008, 07:09:14 pm »
After installing soft 15k and rebooting, the screen is skewed with noticeable flicker, and the OSD says:
    FH 15.8 KHZ
    FV 50.2 HZ
SailorSat
« Reply #408 on: March 14, 2008, 07:30:36 pm »
Sure, 800x600 :)
With your D9400 you should be able to install 15 + 25 + 31kHz.
damdai
« Reply #409 on: March 14, 2008, 07:46:05 pm »
Sure, 800x600 :)
I know. It doesn't seem to be working with my graphics card though. None of the resolutions are listed in quickres, and mame will choose to run games at 800x600. I'm trying an ATI card now.
bent98
« Reply #410 on: March 14, 2008, 10:33:26 pm »
Salior
I just got my x1950xt works great  right out of the box( I will need to add that to your compatablity thread)
I setup the usermodes.txt and pasted in the large list your put in the thread and ran mame -verbose.
I had gotten the same result as you however nearly all thoser usermode resoultions didnt not work with my monitor.
Screen when a little crazy and also made a high pitch noise. Strange because my bill labs quad sync monitor is capable of running many modes.
Also something else I ve played around with is adding those modelines you gave me for pacman two pages ago in this thread and I specified in the pacman.ini file 352x288@55 and it still selected the default one @51. Seems like if you have same resolution with different refresh rates mame will always pick the default ones in embedded in soft 15khz. What is that?
« Last Edit: March 15, 2008, 08:40:38 am by bent98 »
damdai
« Reply #411 on: March 15, 2008, 11:28:28 am »
I'm able to add new resolutions with powerstrip, but not with soft15k.
SailorSat
« Reply #412 on: March 15, 2008, 12:03:13 pm »
Most likely the horizontal flyback on those modes it too high, as they are calculated for standard 15kHz (which is something like 20% of active pixel = sync) and with your Monitor simply has a faster flyback (like 10% of pixel = sync)
I'll attach the same list again with smaller sync width.
Try only to add the usermodes, NOT the base 15kHz ones (as they ALL will be added with 60Hz to the registry).
As for MAME, in your INI try setting "resolution0" not "resolution", MAME seems to have some... pretty nasty behaviour...
Now that IS strange as both should be doing quite the same thing. With both NVidia AND ATI?
Can't help you at all right now, as I'm not sitting in front of it.
« Last Edit: March 15, 2008, 06:55:39 pm by SailorSat »
bent98
« Reply #413 on: March 15, 2008, 12:39:11 pm »
I tried pasting that updated text file, but when I ran soft 15 and intall usermodes it gives me a runtime error 13. It is like the problem I had with the decimal points that u fixed in build38
bent98
« Reply #414 on: March 15, 2008, 12:51:06 pm »
Seems I can add first 3 lines without runtime error after that i get error if I add more.
Also i tried pacman with the first 3 modelines added I it doesnt play nice with my monitor
And as far as mame .ini. It was using resolution0 and it still didnt grab the modeline in usermodes.txt
Infact here is verbose listing
DirectDraw: Using DirectDraw 7
DirectDraw: Configuring device Radeon X1950 Se
DirectDraw: Selecting video mode...
   240x 240@ 60Hz -> 62.279536
   256x 240@ 60Hz -> 62.276498
   256x 256@ 60Hz -> 62.279536
   256x 264@ 60Hz -> 62.281696
   288x 240@ 60Hz -> 62.273001
   296x 240@ 60Hz -> 62.272416
   304x 240@ 60Hz -> 62.271904
   321x 240@ 60Hz -> 62.271001
   321x 256@ 60Hz -> 62.271844
   336x 240@ 60Hz -> 62.270363
   352x 256@ 60Hz -> 62.270363
   352x 264@ 60Hz -> 62.270688
   352x 288@ 60Hz -> 2062.264152
   368x 240@ 60Hz -> 62.269333
   384x 288@ 60Hz -> 68.475332
   392x 240@ 60Hz -> 62.268760
   401x 256@ 60Hz -> 62.268914
   448x 240@ 60Hz -> 62.267815
   448x 384@ 60Hz -> 65.379417
   512x 240@ 60Hz -> 62.267119
   512x 288@ 60Hz -> 65.724360
   512x 384@ 60Hz -> 64.861554
   512x 448@ 60Hz -> 64.491323
   512x 512@ 60Hz -> 64.213470
   632x 264@ 60Hz -> 62.266461
   640x 240@ 60Hz -> 62.266302
   640x 288@ 60Hz -> 64.662233
   640x 480@ 60Hz -> 63.906188
   720x 480@ 60Hz -> 63.715531
   800x 600@ 60Hz -> 63.389011
  1024x 768@ 60Hz -> 63.044792
  1280x 720@ 60Hz -> 62.935744
DirectDraw: Mode selected =  352x 288@ 60Hz
DirectDraw: primary surface created: 352x288x32
here is my usermodes.txt
modeline '352x288 17,1kHz 55Hz' 7,96 352 368 408 464 288 289 292 312 -hsync -vsync
noticed it didnt even see the 352x288@55 in the verbose listing.
« Last Edit: March 15, 2008, 01:01:40 pm by bent98 »
SailorSat
« Reply #415 on: March 15, 2008, 01:14:51 pm »
You DID install 15kHz AND Usermodes did you?
And what error do you get?
bent98
« Reply #416 on: March 15, 2008, 04:14:58 pm »
Yes I Did
I got a run time error 13
SailorSat
« Reply #417 on: March 15, 2008, 05:06:47 pm »
Oo...
Do you really use build 29? If so please attach the mode that generates the error.
bent98
« Reply #418 on: March 15, 2008, 05:32:07 pm »
modeline "272x236@60p;15.72kHz" 5.0304 272 288 288 320 236 244 258 262 -hsync -vsync
modeline "224x224@61p;15.75758kHz" 4.16 224 240 232 264 224 236 254 260 -hsync -vsync
modeline "256x224@60p;15.72kHz" 4.77888 256 272 272 304 224 236 256 262 -hsync -vsync
modeline "240x224@60p;15.72kHz" 4.4016 240 256 248 280 224 236 256 262 -hsync -vsync
modeline "288x224@60p;15.72kHz" 5.28192 288 304 304 336 224 236 256 262 -hsync -vsync
modeline "320x240@57p;15.732kHz" 5.915232 320 336 344 376 240 252 270 276 -hsync -vsync
modeline "512x224@60p;15.72kHz" 9.432 512 528 568 600 224 236 256 262 -hsync -vsync
modeline "480x64@60p;15.72kHz" 8.92896 480 496 536 568 64 130 229 262 -hsync -vsync
modeline "512x240@60p;15.72kHz" 9.432 512 528 568 600 240 248 258 262 -hsync -vsync
modeline "640x240@60p;15.72kHz" 11.82144 640 656 720 752 240 248 258 262 -hsync -vsync
modeline "256x208@60p;15.72kHz" 4.77888 256 272 272 304 208 226 253 262 -hsync -vsync
modeline "256x208@61p;15.74707kHz" 4.787109 256 272 272 304 208 224 250 258 -hsync -vsync
modeline "272x224@60p;15.72kHz" 5.0304 272 288 288 320 224 236 256 262 -hsync -vsync
modeline "272x224@61p;15.75758kHz" 5.042424 272 288 288 320 224 236 254 260 -hsync -vsync
modeline "304x224@60p;15.72kHz" 5.6592 304 320 328 360 224 236 256 262 -hsync -vsync
modeline "288x224@60p;15.7608kHz" 5.295629 288 304 304 336 224 238 257 264 -hsync -vsync
modeline "496x480@60p;31.5kHz" 18.396 496 512 552 584 480 496 517 525 -hsync -vsync
modeline "640x480@60p;31.5kHz" 23.688 640 656 720 752 480 496 517 525 -hsync -vsync
modeline "1024x480@60p;31.5kHz" 38.052 1024 1056 1144 1208 480 496 517 525 -hsync -vsync
modeline "768x480@60p;31.5kHz" 28.476 768 800 840 904 480 496 517 525 -hsync -vsync
modeline "256x192@60p;15.72kHz" 4.77888 256 272 272 304 192 216 250 262 -hsync -vsync
modeline "240x192@60p;15.72kHz" 4.4016 240 256 248 280 192 216 250 262 -hsync -vsync
modeline "240x192@61p;15.71981kHz" 4.401546 240 256 248 280 192 214 246 257 -hsync -vsync
modeline "256x256@60p;15.72kHz" 4.77888 256 272 272 304 256 258 261 262 -hsync -vsync
modeline "256x224@59p;15.74337kHz" 4.785985 256 272 272 304 224 238 259 266 -hsync -vsync
modeline "512x448@60p;31.5kHz" 18.9 512 528 568 600 448 474 512 525 -hsync -vsync
modeline "256x240@60p;15.72kHz" 4.77888 256 272 272 304 240 248 258 262 -hsync -vsync
modeline "256x224@60p;15.7458kHz" 4.786724 256 272 272 304 224 236 256 262 -hsync -vsync
modeline "260x224@60p;15.77863kHz" 4.796702 260 276 272 304 224 238 258 265 -hsync -vsync
modeline "376x248@59p;15.73835kHz" 6.924874 376 392 408 440 248 254 262 265 -hsync -vsync
modeline "256x230@60p;15.72kHz" 4.77888 256 272 272 304 230 240 257 262 -hsync -vsync
modeline "256x184@60p;15.72kHz" 4.77888 256 272 272 304 184 210 249 262 -hsync -vsync
modeline "240x248@60p;15.72kHz" 4.4016 240 256 248 280 248 252 260 262 -hsync -vsync
modeline "223x240@50p;15.75kHz" 4.158 223 239 232 264 240 264 303 315 -hsync -vsync
modeline "352x240@60p;15.73426kHz" 6.545454 352 368 384 416 240 248 258 262 -hsync -vsync
modeline "512x480@60p;31.5kHz" 18.9 512 528 568 600 480 496 517 525 -hsync -vsync
modeline "480x480@60p;31.5kHz" 17.892 480 496 536 568 480 496 517 525 -hsync -vsync
modeline "256x240@59p;15.74337kHz" 4.785985 256 272 272 304 240 248 262 266 -hsync -vsync
modeline "240x224@60p;15.72327kHz" 4.402516 240 256 248 280 224 236 256 262 -hsync -vsync
modeline "256x224@60p;15.76613kHz" 4.792903 256 272 272 304 224 236 256 262 -hsync -vsync
modeline "240x252@57p;15.77305kHz" 4.416454 240 256 248 280 252 260 274 278 -hsync -vsync
modeline "240x240@57p;15.732kHz" 4.40496 240 256 248 280 240 252 270 276 -hsync -vsync
modeline "256x224@57p;15.77305kHz" 4.795007 256 272 272 304 224 242 269 278 -hsync -vsync
modeline "240x256@57p;15.7765kHz" 4.41742 240 256 248 280 256 264 274 278 -hsync -vsync
modeline "256x256@55p;15.73kHz" 4.78192 256 272 272 304 256 266 281 286 -hsync -vsync
modeline "384x256@55p;15.73kHz" 7.04704 384 400 416 448 256 266 281 286 -hsync -vsync
modeline "384x248@55p;15.73kHz" 7.04704 384 400 416 448 248 260 280 286 -hsync -vsync
modeline "384x256@55p;15.73503kHz" 7.049296 384 400 416 448 256 266 281 286 -hsync -vsync
modeline "512x256@55p;15.73kHz" 9.438 512 528 568 600 256 266 281 286 -hsync -vsync
modeline "384x240@60p;15.72kHz" 7.04256 384 400 416 448 240 248 258 262 -hsync -vsync
modeline "320x240@60p;15.72kHz" 5.91072 320 336 344 376 240 248 258 262 -hsync -vsync
modeline "384x256@60p;15.72kHz" 7.04256 384 400 416 448 256 258 261 262 -hsync -vsync
modeline "256x240@61p;15.738kHz" 4.784352 256 272 272 304 240 246 255 258 -hsync -vsync
modeline "256x256@76p;25.02441kHz" 7.607422 256 272 272 304 256 280 316 328 -hsync -vsync
modeline "232x224@60p;15.72kHz" 4.27584 232 248 240 272 224 236 256 262 -hsync -vsync
modeline "224x232@60p;15.72kHz" 4.15008 224 240 232 264 232 242 257 262 -hsync -vsync
modeline "256x224@59p;15.753kHz" 4.788912 256 272 272 304 224 238 260 267 -hsync -vsync
modeline "320x224@60p;15.72kHz" 5.91072 320 336 344 376 224 236 256 262 -hsync -vsync
modeline "288x208@60p;15.72kHz" 5.28192 288 304 304 336 208 226 253 262 -hsync -vsync
modeline "320x232@60p;15.72kHz" 5.91072 320 336 344 376 232 242 257 262 -hsync -vsync
modeline "384x240@57p;15.73582kHz" 7.049647 384 400 416 448 240 252 268 274 -hsync -vsync
modeline "384x224@60p;15.72kHz" 7.04256 384 400 416 448 224 236 256 262 -hsync -vsync
modeline "384x240@58p;15.755kHz" 7.05824 384 400 416 448 240 252 268 274 -hsync -vsync
modeline "512x400@60p;25.02kHz" 15.012 512 528 568 600 400 406 414 417 -hsync -vsync
modeline "320x224@59p;15.74499kHz" 5.920116 320 336 344 376 224 238 260 267 -hsync -vsync
modeline "320x232@59p;15.74499kHz" 5.920116 320 336 344 376 232 244 261 267 -hsync -vsync
modeline "640x200@60p;15.72kHz" 11.82144 640 656 720 752 200 220 252 262 -hsync -vsync
modeline "264x240@60p;15.72kHz" 4.90464 264 280 280 312 240 248 258 262 -hsync -vsync
modeline "280x240@60p;15.72kHz" 5.15616 280 296 296 328 240 248 258 262 -hsync -vsync
modeline "260x240@60p;15.72kHz" 4.77888 260 276 272 304 240 248 258 262 -hsync -vsync
modeline "320x240@55p;15.74995kHz" 5.921979 320 336 344 376 240 256 279 287 -hsync -vsync
modeline "320x240@56p;15.736kHz" 5.916736 320 336 344 376 240 254 274 281 -hsync -vsync
modeline "256x224@58p;15.755kHz" 4.78952 256 272 272 304 224 240 266 274 -hsync -vsync
modeline "320x240@59p;15.753kHz" 5.923128 320 336 344 376 240 248 263 267 -hsync -vsync
modeline "320x240@61p;15.738kHz" 5.917488 320 336 344 376 240 246 255 258 -hsync -vsync
modeline "320x240@59p;15.74382kHz" 5.919677 320 336 344 376 240 248 261 265 -hsync -vsync
modeline "320x240@58p;15.76888kHz" 5.929098 320 336 344 376 240 252 268 274 -hsync -vsync
modeline "384x240@58p;15.76888kHz" 7.064457 384 400 416 448 240 252 268 274 -hsync -vsync
modeline "320x224@58p;15.76888kHz" 5.929098 320 336 344 376 224 240 266 274 -hsync -vsync
modeline "318x239@58p;15.76888kHz" 5.929098 318 334 344 376 239 251 268 274 -hsync -vsync
modeline "294x238@60p;15.74519kHz" 5.416346 294 310 312 344 238 246 258 262 -hsync -vsync
modeline "316x239@60p;15.74519kHz" 5.794231 316 332 336 368 239 247 258 262 -hsync -vsync
modeline "292x240@60p;15.74519kHz" 5.416346 292 308 312 344 240 248 258 262 -hsync -vsync
modeline "292x231@60p;15.74519kHz" 5.416346 292 308 312 344 231 241 257 262 -hsync -vsync
modeline "276x240@60p;15.74519kHz" 5.164423 276 292 296 328 240 248 258 262 -hsync -vsync
modeline "240x240@60p;15.72kHz" 4.4016 240 256 248 280 240 248 258 262 -hsync -vsync
modeline "352x240@60p;15.72kHz" 6.53952 352 368 384 416 240 248 258 262 -hsync -vsync
modeline "384x224@60p;15.7432kHz" 7.052954 384 400 416 448 224 238 257 264 -hsync -vsync
modeline "360x245@57p;15.732kHz" 6.670368 360 376 392 424 245 255 271 276 -hsync -vsync
modeline "360x240@57p;15.732kHz" 6.670368 360 376 392 424 240 252 270 276 -hsync -vsync
modeline "400x240@60p;15.72kHz" 7.41984 400 416 440 472 240 248 258 262 -hsync -vsync
modeline "360x240@60p;15.72kHz" 6.66528 360 376 392 424 240 248 258 262 -hsync -vsync
modeline "384x256@60p;15.74803kHz" 7.055118 384 400 416 448 256 258 261 262 -hsync -vsync
modeline "256x224@60p;15.77951kHz" 4.796971 256 272 272 304 224 236 257 263 -hsync -vsync
modeline "256x224@60p;15.77984kHz" 4.797073 256 272 272 304 224 236 257 263 -hsync -vsync
modeline "512x256@60p;15.72kHz" 9.432 512 528 568 600 256 258 261 262 -hsync -vsync
modeline "280x210@60p;15.72kHz" 5.15616 280 296 296 328 210 228 253 262 -hsync -vsync
modeline "240x208@60p;15.72kHz" 4.4016 240 256 248 280 208 226 253 262 -hsync -vsync
modeline "512x224@59p;15.77727kHz" 9.466364 512 528 568 600 224 238 260 267 -hsync -vsync
modeline "320x224@60p;15.73425kHz" 5.916078 320 336 344 376 224 236 256 262 -hsync -vsync
modeline "320x224@60p;15.74428kHz" 5.919847 320 336 344 376 224 238 257 264 -hsync -vsync
modeline "321x224@60p;15.73425kHz" 5.916078 321 337 344 376 224 236 256 262 -hsync -vsync
modeline "496x384@58p;24.998kHz" 14.59883 496 512 552 584 384 400 423 431 -hsync -vsync
modeline "416x224@60p;15.72kHz" 7.67136 416 432 456 488 224 236 256 262 -hsync -vsync
modeline "496x384@60p;25.02kHz" 14.61168 496 512 552 584 384 396 411 417 -hsync -vsync
modeline "512x512@60p;31.5kHz" 18.9 512 528 568 600 512 516 523 525 -hsync -vsync
modeline "704x513@60p;31.5kHz" 26.208 704 736 768 832 513 517 523 525 -hsync -vsync
modeline "256x240@57p;15.732kHz" 4.782528 256 272 272 304 240 252 270 276 -hsync -vsync
modeline "248x240@57p;15.732kHz" 4.530816 248 264 256 288 240 252 270 276 -hsync -vsync
modeline "256x256@55p;15.76637kHz" 4.792976 256 272 272 304 256 266 283 288 -hsync -vsync
modeline "256x256@56p;15.76637kHz" 4.792976 256 272 272 304 256 264 276 280 -hsync -vsync
modeline "256x256@57p;15.732kHz" 4.782528 256 272 272 304 256 262 273 276 -hsync -vsync
modeline "248x240@60p;15.72kHz" 4.52736 248 264 256 288 240 248 258 262 -hsync -vsync
modeline "256x232@58p;15.776kHz" 4.795904 256 272 272 304 232 246 265 272 -hsync -vsync
modeline "240x240@57p;15.73989kHz" 4.407169 240 256 248 280 240 252 268 274 -hsync -vsync
modeline "256x224@58p;15.776kHz" 4.795904 256 272 272 304 224 240 264 272 -hsync -vsync
modeline "256x232@60p;15.72kHz" 4.77888 256 272 272 304 232 242 257 262 -hsync -vsync
modeline "256x240@58p;15.776kHz" 4.795904 256 272 272 304 240 250 267 272 -hsync -vsync
modeline "256x240@57p;15.73034kHz" 4.782023 256 272 272 304 240 252 268 274 -hsync -vsync
modeline "320x240@58p;15.776kHz" 5.931776 320 336 344 376 240 250 267 272 -hsync -vsync
modeline "319x240@58p;15.776kHz" 5.931776 319 335 344 376 240 250 267 272 -hsync -vsync
modeline "336x256@60p;15.72kHz" 6.16224 336 352 360 392 256 258 261 262 -hsync -vsync
modeline "240x224@61p;15.75758kHz" 4.412121 240 256 248 280 224 236 254 260 -hsync -vsync
modeline "280x224@60p;15.72kHz" 5.15616 280 296 296 328 224 236 256 262 -hsync -vsync
modeline "304x224@54p;15.768kHz" 5.67648 304 320 328 360 224 246 281 292 -hsync -vsync
modeline "320x256@60p;15.72kHz" 5.91072 320 336 344 376 256 258 261 262 -hsync -vsync
modeline "376x224@60p;15.72kHz" 6.9168 376 392 408 440 224 236 256 262 -hsync -vsync
modeline "304x256@59p;15.753kHz" 5.67108 304 320 328 360 256 260 265 267 -hsync -vsync
modeline "488x384@58p;24.998kHz" 14.39885 488 504 544 576 384 400 423 431 -hsync -vsync
modeline "512x384@60p;25.02kHz" 15.012 512 528 568 600 384 396 411 417 -hsync -vsync
modeline "240x256@60p;15.72kHz" 4.4016 240 256 248 280 256 258 261 262 -hsync -vsync
modeline "256x256@60p;15.77916kHz" 4.796865 256 272 272 304 256 258 262 263 -hsync -vsync
modeline "248x256@57p;15.732kHz" 4.530816 248 264 256 288 256 262 273 276 -hsync -vsync
modeline "256x224@60p;15.73381kHz" 4.783077 256 272 272 304 224 236 257 263 -hsync -vsync
modeline "320x236@60p;15.72kHz" 5.91072 320 336 344 376 236 244 258 262 -hsync -vsync
modeline "336x225@60p;15.75984kHz" 6.177855 336 352 360 392 225 237 257 263 -hsync -vsync
modeline "480x464@60p;31.5kHz" 17.892 480 496 536 568 464 484 515 525 -hsync -vsync
modeline "256x224@60p;15.75kHz" 4.788 256 272 272 304 224 236 256 262 -hsync -vsync
modeline "496x232@60p;15.72kHz" 9.18048 496 512 552 584 232 242 257 262 -hsync -vsync
modeline "255x232@60p;15.72kHz" 4.77888 255 271 272 304 232 242 257 262 -hsync -vsync
modeline "512x240@45p;15.73497kHz" 9.440983 512 528 568 600 240 276 331 349 -hsync -vsync
modeline "160x200@60p;15.75981kHz" 3.025884 160 176 160 192 200 220 253 263 -hsync -vsync
modeline "304x240@60p;15.72kHz" 5.6592 304 320 328 360 240 248 258 262 -hsync -vsync
modeline "304x256@60p;15.72kHz" 5.6592 304 320 328 360 256 258 261 262 -hsync -vsync
modeline "256x224@57p;15.732kHz" 4.782528 256 272 272 304 224 242 267 276 -hsync -vsync
modeline "256x231@61p;15.74707kHz" 4.787109 256 272 272 304 231 239 254 258 -hsync -vsync
modeline "240x232@60p;15.72kHz" 4.4016 240 256 248 280 232 242 257 262 -hsync -vsync
modeline "256x224@61p;15.75kHz" 4.788 256 272 272 304 224 236 253 259 -hsync -vsync
modeline "319x255@61p;15.74707kHz" 5.920898 319 335 344 376 255 255 258 258 -hsync -vsync
modeline "256x232@61p;15.74707kHz" 4.787109 256 272 272 304 232 240 254 258 -hsync -vsync
modeline "296x240@60p;15.72kHz" 5.53344 296 312 320 352 240 248 258 262 -hsync -vsync
modeline "336x240@60p;15.75968kHz" 6.177795 336 352 360 392 240 248 259 263 -hsync -vsync
modeline "512x384@60p;25kHz" 15 512 528 568 600 384 394 411 416 -hsync -vsync
modeline "508x384@60p;25kHz" 15 508 524 568 600 384 396 411 417 -hsync -vsync
modeline "512x288@60p;25.02915kHz" 15.01749 512 528 568 600 288 330 394 415 -hsync -vsync
modeline "512x228@60p;15.77287kHz" 9.463722 512 528 568 600 228 240 256 262 -hsync -vsync
modeline "640x240@60p;15.75968kHz" 11.85128 640 656 720 752 240 248 259 263 -hsync -vsync
modeline "672x240@60p;15.75968kHz" 12.48167 672 704 728 792 240 248 259 263 -hsync -vsync
modeline "336x240@60p;15.72kHz" 6.16224 336 352 360 392 240 248 258 262 -hsync -vsync
modeline "360x240@60p;15.75968kHz" 6.682105 360 376 392 424 240 248 259 263 -hsync -vsync
modeline "256x224@61p;15.74041kHz" 4.785086 256 272 272 304 224 236 251 257 -hsync -vsync
modeline "240x224@57p;15.732kHz" 4.40496 240 256 248 280 224 242 267 276 -hsync -vsync
modeline "256x216@61p;15.75758kHz" 4.790303 256 272 272 304 216 230 253 260 -hsync -vsync
modeline "256x224@61p;15.738kHz" 4.784352 256 272 272 304 224 236 252 258 -hsync -vsync
modeline "272x216@61p;15.75758kHz" 5.042424 272 288 288 320 216 230 253 260 -hsync -vsync
modeline "240x216@61p;15.75758kHz" 4.412121 240 256 248 280 216 230 253 260 -hsync -vsync
modeline "288x216@60p;15.72kHz" 5.28192 288 304 304 336 216 232 254 262 -hsync -vsync
modeline "320x224@59p;15.74337kHz" 5.919508 320 336 344 376 224 238 259 266 -hsync -vsync
modeline "512x432@60p;31.5kHz" 18.9 512 528 568 600 432 464 509 525 -hsync -vsync
modeline "256x240@57p;15.73989kHz" 4.784926 256 272 272 304 240 252 268 274 -hsync -vsync
modeline "240x224@56p;15.736kHz" 4.40608 240 256 248 280 224 244 271 281 -hsync -vsync
modeline "256x240@57p;15.73856kHz" 4.784522 256 272 272 304 240 252 268 274 -hsync -vsync
modeline "256x224@60p;15.74428kHz" 4.78626 256 272 272 304 224 238 257 264 -hsync -vsync
modeline "720x241@60p;15.76424kHz" 13.36807 720 752 784 848 241 249 259 263 -hsync -vsync
modeline "256x256@59p;15.74625kHz" 4.78686 256 272 272 304 256 260 264 266 -hsync -vsync
modeline "224x240@50p;15.75kHz" 4.158 224 240 232 264 240 264 303 315 -hsync -vsync
modeline "512x192@60p;15.72kHz" 9.432 512 528 568 600 192 216 250 262 -hsync -vsync
modeline "256x224@56p;15.736kHz" 4.783744 256 272 272 304 224 244 271 281 -hsync -vsync
modeline "384x224@56p;15.736kHz" 7.049728 384 400 416 448 224 244 271 281 -hsync -vsync
modeline "256x240@56p;15.736kHz" 4.783744 256 272 272 304 240 254 274 281 -hsync -vsync
modeline "511x399@55p;24.98207kHz" 14.98924 511 527 568 600 399 417 446 455 -hsync -vsync
modeline "399x253@55p;15.73195kHz" 7.425482 399 415 440 472 253 265 281 287 -hsync -vsync
modeline "512x400@57p;25.00417kHz" 15.0025 512 528 568 600 400 412 430 436 -hsync -vsync
modeline "400x256@57p;15.753kHz" 7.435416 400 416 440 472 256 264 274 278 -hsync -vsync
modeline "512x400@57p;25.02504kHz" 15.01502 512 528 568 600 400 412 432 438 -hsync -vsync
modeline "640x480@57p;31.521kHz" 23.70379 640 656 720 752 480 504 541 553 -hsync -vsync
modeline "400x256@60p;15.72kHz" 7.41984 400 416 440 472 256 258 261 262 -hsync -vsync
modeline "256x256@50p;15.75kHz" 4.788 256 272 272 304 256 276 305 315 -hsync -vsync
modeline "240x248@57p;15.77567kHz" 4.417186 240 256 248 280 248 258 273 278 -hsync -vsync
modeline "320x240@54p;15.768kHz" 5.928768 320 336 344 376 240 258 283 292 -hsync -vsync
modeline "320x224@61p;15.738kHz" 5.917488 320 336 344 376 224 236 252 258 -hsync -vsync
modeline "320x256@61p;15.738kHz" 5.917488 320 336 344 376 256 256 258 258 -hsync -vsync
modeline "320x224@61p;15.72327kHz" 5.911949 320 336 344 376 224 234 251 256 -hsync -vsync
modeline "248x224@60p;15.72kHz" 4.52736 248 264 256 288 224 236 256 262 -hsync -vsync
modeline "240x216@60p;15.72kHz" 4.4016 240 256 248 280 216 232 254 262 -hsync -vsync
modeline "256x224@54p;15.768kHz" 4.793472 256 272 272 304 224 246 281 292 -hsync -vsync
modeline "256x240@54p;15.768kHz" 4.793472 256 272 272 304 240 258 283 292 -hsync -vsync
modeline "256x224@54p;15.7634kHz" 4.792074 256 272 272 304 224 248 281 293 -hsync -vsync
modeline "256x216@60p;15.72kHz" 4.77888 256 272 272 304 216 232 254 262 -hsync -vsync
modeline "342x240@60p;15.72kHz" 6.288 342 358 368 400 240 248 258 262 -hsync -vsync
modeline "319x223@60p;15.72kHz" 5.91072 319 335 344 376 223 235 256 262 -hsync -vsync
modeline "320x224@59p;15.7738kHz" 5.930949 320 336 344 376 224 238 259 266 -hsync -vsync
modeline "256x224@55p;15.73582kHz" 4.783688 256 272 272 304 224 244 274 284 -hsync -vsync
modeline "376x240@60p;15.72kHz" 6.9168 376 392 408 440 240 248 258 262 -hsync -vsync
modeline "1024x512@60p;31.5kHz" 38.052 1024 1056 1144 1208 512 516 523 525 -hsync -vsync
modeline "368x240@60p;15.72kHz" 6.79104 368 384 400 432 240 248 258 262 -hsync -vsync
modeline "320x240@59p;15.7206kHz" 5.910945 320 336 344 376 240 248 262 266 -hsync -vsync
modeline "480x240@59p;15.7206kHz" 8.929301 480 496 536 568 240 248 262 266 -hsync -vsync
modeline "384x240@59p;15.7206kHz" 7.042829 384 400 416 448 240 248 262 266 -hsync -vsync
modeline "576x432@60p;31.5kHz" 21.42 576 592 648 680 432 464 509 525 -hsync -vsync
modeline "272x232@60p;15.72kHz" 5.0304 272 288 288 320 232 242 257 262 -hsync -vsync
modeline "448x224@60p;15.72kHz" 8.30016 448 464 496 528 224 236 256 262 -hsync -vsync
modeline "384x240@57p;15.75148kHz" 7.056663 384 400 416 448 240 252 272 278 -hsync -vsync
modeline "448x240@60p;15.72kHz" 8.30016 448 464 496 528 240 248 258 262 -hsync -vsync
modeline "304x232@60p;15.72kHz" 5.6592 304 320 328 360 232 242 257 262 -hsync -vsync
modeline "336x236@60p;15.72kHz" 6.16224 336 352 360 392 236 244 258 262 -hsync -vsync
modeline "344x240@60p;15.72kHz" 6.41376 344 360 376 408 240 248 258 262 -hsync -vsync
modeline "384x384@60p;25.02kHz" 11.20896 384 400 416 448 384 396 411 417 -hsync -vsync
modeline "351x251@60p;15.72kHz" 6.53952 351 367 384 416 251 255 260 262 -hsync -vsync
modeline "320x224@56p;15.736kHz" 5.916736 320 336 344 376 224 244 271 281 -hsync -vsync
modeline "512x240@60p;15.74519kHz" 9.447115 512 528 568 600 240 248 258 262 -hsync -vsync
modeline "256x234@60p;15.72kHz" 4.77888 256 272 272 304 234 244 257 262 -hsync -vsync
modeline "384x280@60p;25.02kHz" 11.20896 384 400 416 448 280 326 394 417 -hsync -vsync
modeline "256x288@60p;25.02kHz" 7.60608 256 272 272 304 288 332 395 417 -hsync -vsync
modeline "368x224@60p;15.72kHz" 6.79104 368 384 400 432 224 236 256 262 -hsync -vsync
modeline "304x240@58p;15.776kHz" 5.67936 304 320 328 360 240 250 267 272 -hsync -vsync
modeline "320x224@58p;15.776kHz" 5.931776 320 336 344 376 224 240 264 272 -hsync -vsync
modeline "256x248@60p;15.72kHz" 4.77888 256 272 272 304 248 252 260 262 -hsync -vsync
modeline "360x224@60p;15.72kHz" 6.66528 360 376 392 424 224 236 256 262 -hsync -vsync
modeline "360x224@58p;15.776kHz" 6.689024 360 376 392 424 224 240 264 272 -hsync -vsync
modeline "304x224@58p;15.776kHz" 5.67936 304 320 328 360 224 240 264 272 -hsync -vsync
modeline "380x224@60p;15.72kHz" 7.04256 380 396 416 448 224 236 256 262 -hsync -vsync
modeline "320x240@55p;15.73kHz" 5.91448 320 336 344 376 240 256 278 286 -hsync -vsync
modeline "508x224@60p;15.72kHz" 9.432 508 524 568 600 224 236 256 262 -hsync -vsync
modeline "508x240@60p;15.72kHz" 9.432 508 524 568 600 240 248 258 262 -hsync -vsync
Yes i did use build 29
plus these new ones you created dont all work dont with monitor either.
« Last Edit: March 15, 2008, 06:30:37 pm by bent98 »
SailorSat
« Reply #419 on: March 15, 2008, 06:56:11 pm »
Mhm... It was a typo in the mode generator...
Try this one...
bent98
« Reply #420 on: March 15, 2008, 07:41:37 pm »
  that worked with no errors, but monitor doesnt like those resolutions
couldnt sync
screen went crazy
 224x 224@ 61Hz -> 717.406697
  240x 224@ 60Hz -> 62.276498
  256x 208@ 60Hz -> 62.273001
  256x 208@ 61Hz -> 717.400162
  256x 224@ 60Hz -> 62.274461
  256x 224@ 61Hz -> 717.401621
  272x 224@ 60Hz -> 62.273001
  272x 224@ 61Hz -> 717.400162
  272x 236@ 60Hz -> 62.274053
  288x 224@ 60Hz -> 62.271904
  288x 224@ 61Hz -> 717.399064
  304x 224@ 60Hz -> 62.271048
  352x 288@ 60Hz -> 70.016090
  480x  64@ 60Hz -> 62.266231
  496x 480@ 60Hz -> 64.414690
  512x 224@ 60Hz -> 62.266985
 1024x 480@ 60Hz -> 63.271201
irectDraw: Mode selected =  224x 224@ 61Hz
irectDraw: primary surface created: 224x224x32 (R=00FF0000
irectDraw: New blit size = 224x288
irectDraw: blit surface created: 224x288x32 (R=00FF0000 G=
irectSound: Primary buffer: 48000 Hz, 16 bits, 2 channels
awInput: APIs detected
nput: Adding Mouse #1: \??\HID#Vid_045e&Pid_0039#6&2c66b9f
f-11d1-bc8c-00a0c91405dd}
nput: Adding Gun #1: \??\HID#Vid_045e&Pid_0039#6&2c66b9f9&
nput: Adding Mouse #2: \??\HID#Vid_fafa&Pid_0020#6&37ce979
nput: Adding Gun #2: \??\HID#Vid_fafa&Pid_0020#6&37ce9792&
nput: Adding Mouse #3: \??\HID#Vid_fafa&Pid_0060#6&3293176
nput: Adding Gun #3: \??\HID#Vid_fafa&Pid_0060#6&3293176f&
nput: Adding Kbd #1: \??\HID#Vid_047b&Pid_0011#6&35de7bcd&
nput: Adding Kbd #2: \??\HID#Vid_d209&Pid_0301&MI_00#8&2aa
-56ef-11d1-bc8c-00a0c91405dd}
nput: Adding Kbd #3: \??\HID#Vid_d209&Pid_0301&MI_01#8&6d4
irectInput: Using DirectInput 7
nput: Changing default joystick map = s8.4s8.44s8.4445
 s8888888s
 4s88888s6
 44s888s66
 444555666
 444555666
 444555666
 44s222s66
 4s22222s6
 s2222222s
ound: buffer overflows=1 underflows=0
SailorSat
« Reply #421 on: March 15, 2008, 08:07:05 pm »
How did you hook up your monitor?
bent98
« Reply #422 on: March 15, 2008, 09:00:44 pm »
VGA cable. Why do you ask?
Video card is X1900XT and has two  DVI and I use DVI to VGA converter
Dont have any issues
Here is specs on monitor
http://www.billabs.com/bl27cb0p.htm
« Last Edit: March 15, 2008, 09:44:33 pm by bent98 »
SailorSat
« Reply #423 on: March 15, 2008, 09:50:32 pm »
Hm... Well then I can't help you.
I don't see why it doesn't work.
bent98
« Reply #424 on: March 15, 2008, 09:51:09 pm »
I was reading over what you said here. Are you saying when using that monster list you created dont install 15khz just install usermodes? Custom15k resolutions override the usermodes??
SailorSat
« Reply #425 on: March 16, 2008, 12:18:09 am »
No... the base 15kHz modes get added as 60Hz, though the 288 line modes really just have 50Hz...
bent98
« Reply #426 on: March 16, 2008, 08:18:34 am »
I understand that part. What I am asking is this. When using usermodes can resolutions from those usermodes co exist with the defaults in soft15. Again it seems like when a default resolution is present a duplicate resolutions with a different refresh inserting in the  usermodes.txt wont be  recongizned.
Only way I can get a different linemode is to remove that resolution from custom15khz and then re add new one.
Dont give up on me. There has to be sometype of adjustment to the modelines to get them to work.
« Last Edit: March 16, 2008, 08:29:01 am by bent98 »
Xb0x3r
  • Last login:August 06, 2010, 07:47:33 pm
« Reply #427 on: March 16, 2008, 11:36:41 am »
I've got a WG 25k7193, currently with soft15kHz running (15khz installed) I don't seem to get any picture at all. I pulled this out of an old beat-up Outrunners Cab.
Any ideas on how to even get some sort of picture on it?
john_abey
  • Last login:September 07, 2011, 03:51:12 pm
« Reply #428 on: March 16, 2008, 01:17:08 pm »
thanks for the great program :cheers:
hantarx polo 25" serial #40029
geforce 5200fx nvidia drivers and soft 15 only 15kHz installed
problem is there is a black line threw the screen half screen shows full screen other 1/4 of screen all over the place
<a href="http://s246.photobucket.com/albums/gg98/john_abey/?action=view&current=DSC01564.jpg" target="_blank"><img src="http://i246.photobucket.com/albums/gg98/john_abey/DSC01564.jpg" border="0" alt="arcadesplitscreen"></a>
anyhelp would be much appreciated
« Last Edit: March 16, 2008, 01:24:23 pm by john_abey »
SailorSat
« Reply #429 on: March 16, 2008, 01:26:55 pm »
Yes they do, as the base 15kHz modes have the lowest priority.
I only can say that those modelines work fine for my two Hantarex Polos, my Hantarex MTC 9110 and my good old Commodore 1084.
You will have to investigate yourself where the problem is, as I simply don't have your monitor and thus no way to try around, sorry.
Hm... What graphics card are you using? How is it connected with the monitor?
Mhm...
Looks to me as If your card output is still 31kHz.
What drivers do you use exactly?
What resolution do you have your Windows set to?
Does it happen with other resolution too?
Xb0x3r
« Reply #430 on: March 16, 2008, 01:46:12 pm »
Here's the thread with some pictures now, I just randomly got a picture on the monitor while fiddling around with the nVidia Control Panel. Now it thinks there are two monitors (which is true, one is my normal computer monitor).
I'm using an nVidia GeForce 5950
Here's the thread: http://forum.arcadecontrols.com/index.php?topic=77887.0
SailorSat
« Reply #431 on: March 16, 2008, 02:02:06 pm »
Yeah actually I "force" the detection of two monitors as a J-PAC or a Ultimarc VGA Amp won't be "sensed" as a valid display, which is bad If you want to use dualhead :)
As for now... Do you still have a image on your VGA monitor after reboot?
If so, your card doesn't output 15kHz but 31+kHz.
Also after installing Soft-15kHz DO a reboot, and don't fiddle around in the control panel, as it will overwrite any settings :)
Xb0x3r
« Reply #432 on: March 16, 2008, 08:24:23 pm »
My VGA monitor does not show anything but "Frequency Over Range." Now the picture is decent but is partially squished at the bottom of the screen. I'll update my other thread tomorrow with pictures of it.
damdai
« Reply #433 on: March 17, 2008, 10:46:18 am »
Still no luck on getting soft15k to work for me. With powerstrip, I was able to create a custom 15k resolution and test it, but after rebooting it would not be selectable anywhere (through powerstrip and quickres). For some reason they aren't sticking in the registry or aren't being loaded from the registry upon reboot. Is there a way I can confirm this? Would the fact that I'm using windows server 2003 have anything to do with it? The architecture is virtually identical to XP. There has never been anything that runs on XP that I was not able to run on 2003. I purchased an arcadevga card. Hopefully this will solve my problems.
john_abey
« Reply #434 on: March 17, 2008, 08:00:44 pm »
oem drivers version: 82.65z2
windows running 640 x 420
the higher i go the more desktops there are 1240 780 showed 3 desktops across screen
450x254 shows around 6 to 10 windows
thanks and keep working on the great program :cheers:
SailorSat
« Reply #435 on: March 17, 2008, 11:01:37 pm »
Try this one -> http://www.nvidia.com/object/winxp_2k_93.71.html
For some reason they aren't sticking in the registry or aren't being loaded from the registry upon reboot. --- Would the fact that I'm using windows server 2003 have anything to do with it? --- I purchased an arcadevga card. Hopefully this will solve my problems.
Hm...
As for 2003 Server, should work fine, I'm using XP-64Bit, which itself is basically 2003 Client.
I'm curious why the registry changes don't stick.
Hm yeah as long as you have an 32Bit Version of 2003 the ArcadeVGA should solve the problem, as there are no 64Bit drivers for the ArcadeVGA.
damdai
« Reply #436 on: March 17, 2008, 11:39:21 pm »
Yea, I'm running 32bit. I'll post my results when I get the card set up.
john_abey
« Reply #437 on: March 18, 2008, 10:15:55 am »
thanks the driver worked :cheers:
thanks the driver worked  >:D
now to get my keyboard hack working
when i checked nvidia the driver download was version 169 or so
how to find old drivers
SailorSat
« Reply #438 on: March 18, 2008, 10:29:50 am »
Theres a button somewhere to a driver archive :)
northerngames
« Reply #439 on: March 18, 2008, 01:56:33 pm »
 I installed a PCI card and made it the primary display under the bios setting and I had also disabled the PCI display under windows and I still am getting the bios screens with both AGP & PCI card's connected with those settings.
 I figured I would leave the setting like above and pulled the PCI card out and rebooted the pc to see what happens and it still loaded the bios screens even without the pci hooked to the PC but with it was still set as the main display in the bios settings.
think the card is too old or malfunctioned?
I am running XP pro SP2 for a OS.
I also have 5 PCI slots and had the card sitting in slot#3 of the 5 PCI slots
any idea's?
