Author Topic: Soft-15KHz - slim new tool for 15KHz on normal vga cards  (Read 1134471 times)
0 Members and 25 Guests are viewing this topic.
SailorSat
  • Last login:Yesterday at 11:07:42 am
    • For Amusement Only e.V.
« Reply #1720 on: January 07, 2010, 01:36:43 am »
Hm... Maybe give it a shot without the LCD attached while installing (select a lower res like 640x288 first)
(note to myself, make window smaller ;D)
pubjoe
  • Last login:August 19, 2025, 09:58:38 pm
« Reply #1721 on: January 07, 2010, 07:56:37 pm »
 :laugh: Would be a good idea.
androtaz08
  • Last login:October 09, 2024, 07:17:01 am
« Reply #1722 on: January 07, 2010, 11:57:04 pm »
tried it that way and nothing. seems like sometimes 640x288 works but I need 640x480. I have only been able to get that resolution by reinstalling drivers then installing 15k then booting up with the lcd and then switching to the arcade monitor. sometimes it shows up as 2 nice looking screens. sometimes as 4 zig zagy screens. Maybe its just my card? If all else fails I can go back to my arcadevga wich works great but I want to be able to run a Sega Naomi emulator and ultimarc's card is way to antiquated.
androtaz08
« Reply #1723 on: January 08, 2010, 12:00:20 am »
also even when 640x480 is working and I re select in in quick res the screen goes nuts. I have tried every possible way using both the vga and dvi output using the vga adapter.
gravitone
  • Last login:February 26, 2010, 07:21:50 am
« Reply #1724 on: January 09, 2010, 03:54:36 am »
is there any way to get soft15khz working yet with windows 7 x64 and an nvidia card? I just need one resolution really (1024x600).
androtaz08
« Reply #1725 on: January 10, 2010, 01:12:45 am »
ok tried an older driver seems to work a little better. now when it tries to display a res it cant do everything goes black. some of the lower resolutions work. but useless unless I can get 640x480. Maybe I need a dongle? I dont even know what that is. very frustrating. especially when it works by accident sometimes.
secret80sman
  • Last login:March 14, 2013, 07:04:31 pm
    • The Ultimate 80's Tribute Band
« Reply #1726 on: January 15, 2010, 02:15:13 pm »
Guys,
Does anyone have a modeline worked out for 800x600 @60 hertz
and also the 1024x768 @60 hertz or are neither of these possible with Soft 15khz?
SailorSat
« Reply #1727 on: January 15, 2010, 02:34:41 pm »
15khz? not possible
800x600@60 = 35khz and 1024x768@60=48khz
(or 17 and 24 is interlaced)
secret80sman
« Reply #1728 on: January 15, 2010, 03:49:08 pm »
15khz? not possible
No, 31khz. My 800x600 resolution now only comes up at 51 and flickers where it once didn't and my 1024x768 interlaced shows up as 29 and 30 and also has too much flicker so I wanted to bump up the refresh rate to compensate unless you have a better idea. Would modelines for either of these work? If so could you please post or point me towards where I can get them to cut and paste into my custom31khz.txt file.
I read through posts and you had posted this a few years ago:
modeline '800x600@60p' 40.0 800 840 968 1056 600 601 605 628 -hsync -vsync
 I used it and my 800x600 is back! Any thoughts on how to make the 1024x768 flicker free on a wells gardner d9800?
« Last Edit: January 15, 2010, 06:22:32 pm by secret80sman »
FritoFredrik
  • Last login:December 21, 2011, 12:00:39 am
« Reply #1729 on: January 20, 2010, 04:19:16 am »
so i just made a vga to scart and it workt fine but now when i am running the monitor at 15khz 800x400 and i get flickering in some parts of the screen
and its too big cant see everything its to stretch at top and bottom
need some help tv is a 27" and graphics card is ati radeon 9550 so what setting should i use ?
bulldawg
  • Last login:September 13, 2025, 10:23:47 pm
« Reply #1730 on: January 20, 2010, 07:13:53 pm »
Ok Ive been trying with no luck to get my setup going. I have a WinFast A340T NVIDIA GeForce FX 5200 AGP vga card. I downloaded the latest build of soft15k and the quick res. I opened soft15k and it said my drivers where not compatable so I downloaded the ones it suggested. Opened soft15k again and saw that it recognized my vga card. So I clicked install and it installed the 15 & 31k s/w. Then I set quickres to 640x480 60hz and restarted my pc and turned on my mtc9000 hantarex monitor and nothing, black screen. I should mention that im using a j-pac aswell. I also tried it on my hantarex polo monitor and still nothing, also tried different resolutions, but nothing works. Any ideas?
SailorSat
« Reply #1731 on: January 21, 2010, 01:30:09 am »
1. if your card has 2 outputs, try the other one
2. why 15 & 31khz? both your mtc9000 and polo are 15khz only
bulldawg
« Reply #1732 on: January 21, 2010, 08:16:01 am »
My card only has one output for vga and a yellow video out for tv. When i opened up soft15k build 48 I think, both 15 & 31k where highlighted, so when I hit install it installed both.
gse123
  • Last login:April 10, 2010, 11:25:19 am
« Reply #1733 on: January 23, 2010, 06:12:25 pm »
I have successfully got soft1 5khz up and running with a JPAC, and all is good. The only thing is, i can't seem to add custom resolutions... i'm creating a file called custom15htz.txt that contains the desired modeline, and place it in the DIR of soft15khz. Then, I load soft 15, and select 'user' option and reboot... but the new resolution isnt available from the quickres list. Any ideas?
SailorSat
« Reply #1734 on: January 23, 2010, 09:11:58 pm »
for custom15khz.txt use the 15khz button.
gse123
« Reply #1735 on: January 24, 2010, 04:43:02 am »
I already have the 15htz button seected from when i first installed and ran the software. It is now greyed out...
SailorSat
« Reply #1736 on: January 24, 2010, 05:05:17 am »
Actually click "uninstall" and then "install 15khz"
gse123
« Reply #1737 on: January 24, 2010, 05:09:07 am »
Great thanks - i'll go give that a try  :cheers:
gse123
« Reply #1738 on: January 24, 2010, 05:20:28 am »
Still no joy i'm afraid. Clicked Uninstall, then re-selected the 15khz button and rebooted. Still no new res showing up in quickres list. here is a screen grab of the txt file and contents, just to make sure i've got that part looking ok!
SailorSat
« Reply #1739 on: January 24, 2010, 07:08:29 am »
I think you have your explorer set to hide file extensions (soft15khz is missing the .exe extension)
so most likely your file is named custom15khz.txt.txt now, try removing the .txt extension
*EDIT*
I doubt THAT modeline will work...
1st your vertical active parameter is wrong (is 334, should most likely be 224)
2nd you have 236 total lines and the should be output at 60hz? 236 * 60 = 14.160, which is way too low for a 15.750 Hz (aka 15kHz) monitor.
3rd.. pixel clock of 12.75mhz? htotal * vtotal = pixel per frame
pixelclock / pixel per frame = framerate
-> 388 * 236 = 91568px
12.750.000hz / 91568px = 139,24?
« Last Edit: January 24, 2010, 07:16:36 am by SailorSat »
gse123
« Reply #1740 on: January 24, 2010, 07:41:58 am »
Removed the extra .txt from the file, and then re-calculated the modeline with another online calculator that I have been recommended (as I tried several, and they all gave quite different results for the same input values?)
Success!  ;D The resultion is now showing in quickres. Many thanks for your prompt replies and great support... not to mention fantastic software!  :cheers:
*** EDIT: Gah! Even though it is now showing, it will not display correctly. Like I mentioned above, I am a bit lost as to how to correctly work out the modeline, as every caculator I use gives a different (and none working) result.
« Last Edit: January 24, 2010, 08:18:13 am by gse123 »
secret80sman
« Reply #1741 on: February 03, 2010, 05:58:53 am »
Which online calculator did you use to get things working?
Really need a modeline that will give me 1024x768 flicker free on my WG9800. If anyone has achieved that please post it as well.
Thank You!
« Last Edit: February 03, 2010, 06:25:05 am by secret80sman »
bent98
  • Hyperspin Moderator
« Reply #1742 on: March 13, 2010, 03:17:15 pm »
Sailor. Mame 137. Can you release your wonderful cabmame 137?
bent98
« Reply #1743 on: March 13, 2010, 03:46:34 pm »
Can you use the Hiscore file from BYOAC? The one you use doesnt disable the disclamer nag screen.
SailorSat
« Reply #1744 on: March 13, 2010, 06:24:39 pm »
I'll look into it later today.
Need to get my 64bit rig updated with the new compile tools.
And I have a new "hack" in the pipe.
M3d10n
  • Last login:February 18, 2012, 11:42:04 am
« Reply #1745 on: March 14, 2010, 06:57:36 pm »
Just came to post about how awesome Soft15KHz is. I got Windows 7 and an ATI HD 4850 and it allowed me to get 15KHz resolutions on my secondary display, while using 1440x900 on my primary display! Windows 7 detects the secondary display as an "unidentified display", but it offers an option to force the connection in the display resolution settings.
bent98
« Reply #1746 on: March 15, 2010, 04:46:45 pm »
Whats the "new hack" going to introduce?
SailorSat
« Reply #1747 on: March 17, 2010, 02:26:15 am »
Actually now there are two...
1. "inputlag"-fix is actually a bruteforce approach to the "input lag" problem. mame now polls twice a frame instead of once.
2. "doublebuff" is the other half of the "new hack". It changes the tripplebuffer to a doublebuffer (and changes the way directdraw handles vsync) which also "could" reduce the input delay.
Its a fact that any form of vsync in MAME causes some slight delay, though I can't really tell why.
As for the S15K topic... Nothing new yet. But some new "stock" modelines will be available for testing soon.
Sosetsuken
  • Last login:November 10, 2014, 02:13:46 pm
  • Da Daaah Da Daaah Da, Da Da Daaah Da
« Reply #1748 on: March 17, 2010, 02:58:15 am »
Hey SailorSat,
Thanks tonnes for the new Cabmame Diff's, helps my cab heaps!
I just wanted to ask, the default 640x480i mode line in soft15khz is very, very flickery but the 720x480 mode is nearly flickerfree.  Is there any way to adjust the 640x480 mode line to make it flicker free like the 720x480?
Thanks.
EDIT: 640x480 is the only resolution that seems to flicker.
« Last Edit: March 17, 2010, 04:04:51 am by Sosetsuken »
SailorSat
« Reply #1749 on: March 17, 2010, 02:01:37 pm »
give it a try with
custom15khz.txt
modeline '640x480' 13,09 640 672 736 836 480 486 489 525 interlace -hsync -vsync
M3d10n
« Reply #1750 on: March 20, 2010, 11:59:48 am »
I don't know if it's a side effect of using soft15Khz in a dual-monitor setup, but I cannot make MAME use interlaced resolutions. I can set my extended desktop resolution to interlaced 640x480 or 720x480 if I disable the "hide modes not supported by this monitor" in the Window's advanced video settings, but only 720x480 is listed in MAME and it goes out of sync when selected (progressive?).
Is there a way to permanently get rid of 31KHz 640x480, or fool windows into using the 15KHz mode instead?
Sosetsuken
« Reply #1751 on: March 24, 2010, 01:07:55 am »
give it a try with
custom15khz.txt
Thanks Heaps for that SailorSat, that Modeline looks nearly as good as Progressive :D
Thanks a million! ^_^
SailorSat
« Reply #1752 on: March 24, 2010, 02:09:08 am »
Hm... Some more info would be great.
What kind of monitors? Dual Monitor with a VGA and an Arcade Monitor?
What OS? What kind of gfx card?
M3d10n
« Reply #1753 on: March 24, 2010, 10:57:57 am »
Oops, sorry. I'm running a LCD on DVI and the arcade monitor on VGA, Windows 7 64-bit, ATI HD 4850 (10.2 drivers). All progressive 15KHz resolutions work properly and the interlaced ones are there if I go into Window's "list all modes", but MAME always picks the 31KHz ones instead.
Also, if I manually set the monitor to 15KHz 480i via Windows 7 advanced video options and MAME tries to switch to a different resolution automatically , I get the "failed to create DirectDraw surface" error. But this is probably completely unrelated.
Haggar
  • Last login:February 13, 2017, 05:12:32 am
« Reply #1754 on: March 26, 2010, 07:54:16 am »
This would be fantastic! Can't wait to see that!  :)
Eric_Adapted
  • Newbie
  • Last login:March 30, 2010, 10:53:49 am
« Reply #1755 on: March 30, 2010, 09:57:36 am »
What is the URL to get the newest Soft15kHz?
I'm using this link http://community.arcadeinfo.de/showthread.php?t=9367
Which shows build 48, is that the most current software?
codecrank
  • Last login:August 04, 2017, 08:47:39 pm
« Reply #1756 on: March 30, 2010, 03:08:47 pm »
FYI, a buddy and I both just setup a mame cabinet using soft15Khz with Nvidia 6xxx/7xxx series cards. It does not work with the latest nvidia drivers.
windows XP + nvidia drivers 93.71  = success
btw those drivers won't works with windows 7.
Sosetsuken
« Reply #1757 on: March 31, 2010, 04:45:28 am »
SailorSat,
Card: Gigabyte HD4650 OC PCI-E ( Model: GV-R465OC-1GI )
Driver: Catalyst 10.3
Result: Works / Funktioniert
Notes: 640x480 better modeline
custom15kHz.txt
EDIT: I'll be testing a 4890 in a few weeks.
« Last Edit: March 31, 2010, 05:13:44 am by Sosetsuken »
SailorSat
« Reply #1758 on: March 31, 2010, 01:03:08 pm »
Nice :)
That reminds me...
ATI Radeon HD5970 ... should be fast enough to render AND emulate pacman on the gpu xD
Sosetsuken
« Reply #1759 on: April 02, 2010, 10:16:19 am »
Nice :)
That reminds me...
LOL.  Probably enough programmable units on the 5970 to emulate a few games in real time ^_^.
Are you getting a 5970?
