Author Topic: New Product: KeyWiz-QD™ - GroovyGameGear  (Read 11247 times)
    • GroovyGameGear.com
« on: April 30, 2007, 02:29:02 pm »
And now for something completely different  :).  The KeyWiz-QD™ comes with the same great High-Performance core features of the KeyWiz product line. Added to this is the convenience and versatility of DB-25 connectors. Designed to accept both Male and Female DB-25 plugs, the KeyWiz-QD will allow use of a standard M/F "Straight-Through" DB-25 cable that is split in half, providing "keyed" connections for 1 and 2 player controls. Four additional on-board screw-termninals provide convenient access to 5v, Shazaaam! and Ground connections.
Each players controls are separated to their own connector, with numerous important Admin functions duplicated on each.  5v, Shazaaam! and multiple grounds are also available on each connector.
Click on the thumbnail below to download the full-size PDF pinout diagram.
Price: $32.95 and it is available now.
Thanks for looking, and if anyone has any questions, feel free to ask
« Last Edit: April 30, 2007, 03:12:04 pm by RandyT »
Grasshopper
Re: New Product: KeyWiz-QD™ - GroovyGameGear
« Reply #1 on: April 30, 2007, 02:50:41 pm »
It's a nice idea and long overdue. But I'm a bit puzzled why one of the connectors is male and the other female. I understand the whole cutting a M/F cable in half thing. But why not cut in half a M/M or a F/F cable?
« Reply #2 on: April 30, 2007, 02:56:14 pm »
So there is bulit-in "keying" that prevents one from connecting a cable to the wrong connector.  8)
Havok
« Reply #3 on: April 30, 2007, 03:08:25 pm »
Too late for me, I have an oldskool KeyWiz, but I love it!
So, when are you going to carry universal (can be mounted to any standard or U360 joystick) Tron joystick handles, with built in trigger and thumb buttons?
« Reply #4 on: April 30, 2007, 03:33:15 pm »
What am I missing?  Is this to make it easier to swap panels?
Grasshopper
« Reply #5 on: April 30, 2007, 03:35:34 pm »
Yes.
It also makes it easier to build converter boxes.
« Reply #6 on: April 30, 2007, 03:36:52 pm »
Very nice.   :cheers:
Kaytrim
  • I'm too nice a guy
« Reply #7 on: April 30, 2007, 03:44:59 pm »
Are the Max and Eco versions still going to be avaliable?
« Reply #8 on: April 30, 2007, 04:04:26 pm »
Yes.  The MAX version will remain unchanged, but this new board design will spawn a couple of other styles that we'll be offering soon.  For instance, a solder ECO that will be much easier to solder than the current Eco.  Even though the larger board will increase the Eco price by about a dollar, it will be worth ten times that in ease of use.  The Eco's will also become repairable as CPU sockets will be standard with this style.
The future of the smaller Eco board is unknown at this time, but the new Eco design is likely to supersede them unless there are objections from our OEMs.
bleargh
  • Last login:Yesterday at 12:26:49 pm
  • ribbit...
« Reply #9 on: April 30, 2007, 04:43:41 pm »
WOW.
That's cool, and makes so much sense when you think of it... cut the 25-pin cable in half and get to use both halves!
I'd thought about doing something like this a few years back when I was going to build a modular CP, but gave up when I got bogged down in thinking about how many DB9s/DB25s I'd have to hack up in order to get all the various panel modules plugged in, and how I'd have to wire all of the plugs up to the IPAC4 I was working with at the time.
Having it all on-board just makes life so much simpler.  And cheaper too.... I can generally find old 25-pin cables around here far cheaper than I can plain old wire.
Cool!
ahofle
    • Arcade Ambience Project
« Reply #10 on: April 30, 2007, 04:48:00 pm »
Nice.  Even if you don't have serial cables lying around, they are dirt cheap at monoprice:
monoprice serial cable link
Kaytrim
« Reply #11 on: April 30, 2007, 04:52:09 pm »
Sounds like you are going to offer a GPWiz QD as well.  ;)  I mean it only stands to reason.   You use the same base board for both the KeyWiz and GPWiz for the Max and Eco version of those encoders.
To be honest though I don't see the need for all the duplication of contacts on the player one and two sides.  I don't see the need for 8 action buttons though there may be some games that I am not aware of.  After a quick check I see a total of only about 18 contacts that are absolutely necessary for each player. However you have put much more time in thought on this then I certainly have.  For example DB25 cables (printer) are much more easier to obtain that any other of this type of connector.
TTFN :cheers:
Kaytrim
Buddabing
« Reply #12 on: April 30, 2007, 05:04:42 pm »
Rotatable or modular panels.
Please read the wiki!
bfauska
« Reply #13 on: April 30, 2007, 08:20:33 pm »
That looks like a great product.  I did something similar with my GPwiz based desktop CPs.  I added a DB15 connector so that I could run one panel daisy chained to the other.  With this product half the work would have been done for me.  It works great with a pair of controllers hooked up this way.  So that's another potential use for it.
KenToad
  • Last login:January 29, 2026, 11:31:56 pm
  • Flap Flap Flap
« Reply #14 on: April 30, 2007, 08:47:03 pm »
The modular panels on my bartop are swappable via two DB25 connectors that I have wired to two GPWiz49's.  Definitely another great idea, Randy.
Fozzy The Bear
  • Handbags at dawn in here!!!
« Reply #15 on: April 30, 2007, 09:19:45 pm »
No questions.... Just WOW!! This is perfect for plugging and unplugging multiple panels with ease.  :applaud: :applaud: :applaud: :applaud:
Just exactly what I needed for my next project. Cheers Randy!!! :cheers:
Order coming your way very soon!
Best Regards,
Julian (Fozzy The Bear)
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #16 on: April 30, 2007, 11:20:14 pm »
But if the board can do it, and the connector can do it, then why not do it?
Also, other, non-MAME emulators for more modern console gaming systems use more buttons than MAME does.
Extreme8
  • Last login:August 24, 2008, 03:46:24 pm
« Reply #17 on: April 30, 2007, 11:30:39 pm »
Yup,
Another "why didn't I think of that" from RandyT.
Great job.
loadman
    • MaLa
« Reply #18 on: May 01, 2007, 06:55:22 am »
Nice   :applaud:
Tiger-Heli
    • Tiger-Heli
« Reply #19 on: May 01, 2007, 07:08:15 am »
Cool Idea.
Typo on the Input Sheet - Player two second entry - KeyWiz Uploader (TM) equivalent should be "B" not "8".
(Might be others - I didn't fully check it, yet . . .)
Also, you might consider adding ribbon cable and DB25 IDC connectors (or M/F RS-232 cables) to the site to go along with this.
Thanks again for all your hard work for the community.
« Reply #20 on: May 01, 2007, 09:56:36 am »
Fixed....Thanks for catching this.
I'm looking into some sort of wiring product to go along with this.  Not sure what form it's going to take at the moment though.
psychotech
    • psychotech
« Reply #21 on: May 01, 2007, 11:08:29 am »
Groovy  ;D
..but, as this was not available a month ago...
DarkBubble
« Reply #22 on: May 01, 2007, 11:15:48 am »
And to think, I was just looking at a DB-25 cable the other day, thinking, "WTF am I gonna do with that?"
markrvp
  • NFL Expert
« Reply #23 on: May 01, 2007, 11:35:59 am »
Great idea!
Randy - if you can find a bunch of DB25 cables that all have the SAME COLOR WIRES inside and can sell the cables with a diagram showing which color wire goes to which pin it would be a huge bonus and time saver.  The most time-consuming part of using cables like that is having to use a multimeter to figure out which wire is connected to each pin.
I wish this solution had been around a couple of years ago when I built my multiple-panel machine.  I may be re-wiring it soon.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #24 on: May 01, 2007, 12:31:53 pm »
Guess you mean DIFFERENT color wires?
Tiger-Heli
    • Tiger-Heli
« Reply #25 on: May 01, 2007, 12:37:43 pm »
What he means is the different color wires are the SAME from cable to cable.  I.e. Pin 1 is always the RED wire, Pin 2 is always the Blue wire, Pin 3 is always orange.
markrvp
  • NFL Expert
« Reply #26 on: May 01, 2007, 01:10:15 pm »
Exactly.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #27 on: May 01, 2007, 01:28:26 pm »
ah duh  :-[
knave
« Reply #28 on: May 01, 2007, 01:59:51 pm »
Randy, any chance your USB products will incorporate the DB25 connectors?
Also while I'm at it...could this come in a USB "flavor"?
Would a usb/ps2 adaptor work?
Tiger-Heli
    • Tiger-Heli
« Reply #29 on: May 01, 2007, 02:18:09 pm »
See Reply #11 by KayTrim above.
Doubtful and Doubtful - see my comments here: http://forum.arcadecontrols.com/index.php?topic=35840.0
Kaytrim
« Reply #30 on: May 01, 2007, 02:32:26 pm »
The answer is No and No.  Randy has confirmed it that the KeyWiz doesn't work with an USB adapter.  He also has his reasons as to why he won't produce a KeyWiz USB model.  Something to do with performance, this is why he created the GPWiz.  If you want USB then go with the GPWiz otherwise go with the KeyWiz and a PS/2 connection.  I have used both and have had no issues with either model.
TTFN :cheers:
Kaytrim
btw Tiger-Heli, the T is not capitalized. ;)  Kaytrim
« Reply #31 on: May 01, 2007, 03:04:47 pm »
The board is "USB Ready" for the GP-Wiz models.  I'll need to do a little firmware tweaking to get the inputs where I want them, but a DB-25 version of the GP-Wiz models will be available.
Tiger-Heli
    • Tiger-Heli
« Reply #32 on: May 01, 2007, 03:16:36 pm »
My bad - sorry!
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« Reply #33 on: May 22, 2007, 10:17:13 am »
which one is 'better'...?
the keywiz max or the keywiz qd...
the max has the switchable keyboard interface...the qd doesn't...is the switchable keyboard interface really that important...?
obviously the qd would be easier to install...plus it's two bucks cheaper...
which one(if either) works better with a ledwiz...?
thanks for your thoughts...!
« Last Edit: May 22, 2007, 10:33:41 am by fixedpigs »
Tiger-Heli
    • Tiger-Heli
« Reply #34 on: May 22, 2007, 10:51:53 am »
The QD is 'better' if you think you might end up with swappable CP's somewhere down the road.  Otherwise it really doesn't matter.
Not to me, get a USB or wireless keyboard, or hot-swap in a PS/2 one when you need one.  Some people really like this, but I wouldn't find an active pass-thru that useful, and with the KeyWiz Max being switched, even less so.
Perhaps, not sure about that.
Don't think it matters!
Kaytrim
« Reply #35 on: May 22, 2007, 10:57:10 am »
Randy will have to answer this one as to why the QD doesn't have a switchable KB.  Looking at the QD image there is no input for a keyboard.  From the looks of it you will have to use a USB keyboard if you require one in your setup if you use the QD.
There should be no difference here.  The LEDWiz has a separate connection to the computer (USB) and has no conflict because it is output not input.  If you need additional inputs you can get a GPWiz to work along side the KeyWiz.
TTFN :cheers:
Kaytrim
SavannahLion
« Reply #36 on: May 22, 2007, 12:58:02 pm »
....hot-swap in a PS/2 one when you need one.
Most of the time it's probably better to avoid hot swapping PS/2 devices. I have a few motherboards lying around that are really fussy about hot-swapping on the PS/2 port.
Strange, given the original intent of the port, you would think hot swapping would've been incorporated. Oh well.  :dunno
Tiger-Heli
    • Tiger-Heli
« Reply #37 on: May 22, 2007, 02:02:44 pm »
Probably should have added the standard "Hot-swapping PS/2" disclaimer, although it's NEVER given me any issues.
Kaytrim
« Reply #38 on: May 22, 2007, 02:05:49 pm »
I've had computers lock up when trying to 'hot swap' a ps/2 port device.  That is why I always power down the PC prior to changing out a ps/2 keyboard or mouse.
Kaytrim
Havok
« Reply #39 on: May 22, 2007, 02:39:22 pm »
Yeah - I've seen computers lock up when "hot-swapping" a ps/2 port. Doesn't stop me from still doing it on work computers - usually it's fine...
However, for my home setup, I went with GP-Wiz encoders. USB is definitely the safer hot-swap option...
« Last Edit: May 23, 2007, 11:10:59 am by Havok »
