Author Topic: PS2 with bad mod installed problems (obviously)  (Read 1881 times)
yugffuts
  • Last login:August 19, 2011, 01:22:57 pm
« on: April 15, 2007, 05:34:44 pm »
All right, I've got a PS2 that has a bunch of problems.
It seems to eject repeatedly.  It will never keep the disc in the system.
There is no video at all.  I do hear the sound of the PS2 startup.
I cannot hear the DVD drive spinning at all.
I opened it up, and noticed it has a mod of some kind installed.  This would have been probably 5 years ago.  I don't know what chip it is, but I'm sure the install was screwed up which caused these problems.
While this was open, I noticed that the ribbon cable reciever for the controller/mem card is broken off, so this ribbon will not sit properly (so, even if the above problems were fixed, this still wouldn't work).
So, I figured I could just remove the chip completely and see what happens, but there is no point since the controller input is broken.  I guess the question is:
Are these problems fixable? Are these problems WORTH fixing? I would like the mod to work (or have a new mod installed) since I have a few import PS1 games, but I guess it working like normal would be a good start.
SlammedNiss
  • Last login:Yesterday at 10:56:38 pm
  • Mine Drags the Ground!
Re: PS2 with bad mod installed problems (obviously)
« Reply #1 on: April 15, 2007, 11:00:54 pm »
If all you're wanting to do is play some import PS1 games, it would be cheaper getting a PS1 and putting a chip in it instead.
yugffuts
« Reply #2 on: April 16, 2007, 08:13:43 am »
Well, I do have some PS2 games that I would like to play.  I have a working PS2, so the easiest thing to do would be to get a chip put in that to play all my PS2 & PS1 games.
But in terms of the broken PS2, should I just throw it away?
yugffuts
« Reply #3 on: April 17, 2007, 03:09:20 pm »
Pulled it apart today.  It's a V7 PS2, with a 'Magic 2' mod chip (V3).  I checked the solder points, and didn't notice anything bridged.  I didn't touch any of the points, since the soldering skills required are well beyond me...
