Author Topic: Silly Button Question  (Read 1370 times)
FrizzleFried
    • Idaho Garagecade
« on: March 27, 2007, 04:19:41 pm »
I have a Donkey Kong Jr cabinet I am putting a 48-in-1 board in to.  Some of the games require 2 buttons but I don't want to alter the CP of the DK Jr.
Can I map 2 functions to the same button?  For example,  can I make the P1 button both P1 and Button 2?   If I do this and the board is set for for free play is it going to somehow register the P1 button over and over as I press the button while playing a 2 button game?
My thinking is that once in a game,  the P1 button doesn't do anything until the game is over anyway so it shouldn't make a difference?
I am keeping the DK Jr. 4-way stick anyways so I suppose I should check to see how many 4-way games use a 2nd button on this board (probably none)...so this question then becomes unnecessary anyway.
horseboy
  • Only Saint has those powers.
  • Last login:March 07, 2021, 02:19:14 pm
  • With my last breath, I curse Zoidberg!
Re: Silly Button Question
« Reply #1 on: March 27, 2007, 05:27:53 pm »
Don't be silly.  :)
Quote from: saint
saint is all powerful.
Apparently he is.
modessitt
  • Last login:October 17, 2021, 07:02:28 pm
  • Technician
« Reply #2 on: March 27, 2007, 06:16:25 pm »
You could, although the layout would be awkward - and I'd probably put it on P2 instead.  Just remember that the P1 & P2 buttons are your save buttons in programming mode as well, so don't know if this would cause a problem.  You COULD always just tie both s1 & s2 inputs to the same button, then they would do both options at once.  Wouldn't matter in games like Xevious as you have unlimited bombs, but you'd run out of warps right away in Moon Cresta and don't know how the fast/slow in Qix would be affected.
I've added a 2nd button to these games before, and they look fine as long as you match the original button in color.  If it bothers you that much, do one of two things, either add a floor pedal for the 2nd button that you can stick inside the coin door when you're not using it, or don't play any of the 2 button games.  There's only 5 or so anyway....
Working Games:Joust CT,Gyruss UR,Pong,Battlezone UR#1
Current Proj's:Battlezone UR#2
Cheap/Free Cabs Wanted: DK,KarateChamp,Shinobi,Ghosts&Goblins,CircusCharlie,10ydFight,PolePositnCP,RallyX,Frogger
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
« Reply #3 on: March 27, 2007, 07:04:25 pm »
Perhaps you could put a toggle switch to send the P1 button to either player start or B2.
If I do not respond to your post in a timely manner, feel free to PM me.
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: March 29, 2007, 11:09:18 am »
It works fine in MAME, http://www.mameworld.net/tigerheli/encoder/startkey.htm, don't know how it will do with actual hardware.
