Author Topic: Silly wiring question  (Read 2503 times)
Justin
  • Last login:March 13, 2026, 07:40:07 am
    • Centipede MAME cabinet
« on: April 11, 2003, 02:05:52 am »
Last time I wired my buttons, i ended up with sore hands and neck.
OK, OK, I'm exaggerating, but seriously:  Is there an easier way to wire all the 'grounds'? I'm sure there has to be a better way than making a cable from ground to ground.  The jey here, is that it needs to be insulated  from A to B, so simply running a bare wire won't do the trick.
Someone please tell me there is a better way!
-J
"3 warps to Uranus" -- so I stopped playing!
paigeoliver
  • Awesome face!
Re:Silly wiring question
« Reply #1 on: April 11, 2003, 02:25:53 am »
Why does it have to be insulated? One or two of my arcade games have a bare wire as the ground that goes from switch to switch and it works just fine.
Justin
« Reply #2 on: April 11, 2003, 02:27:56 am »
If it is a bare wire, you risk it touching non-ground terminals.  no?
« Last Edit: April 11, 2003, 02:28:19 am by Justin »
paigeoliver
  • Awesome face!
« Reply #3 on: April 11, 2003, 02:31:11 am »
Well, whenever I saw it that way it was always stiff wire that they did it with. It certainly didn't have any room to move around or anything.
TacoSmuggler
  • Last login:March 30, 2017, 06:35:45 am
« Reply #4 on: April 11, 2003, 03:52:27 am »
I also purchased a game at an auction that had unshielded wire for the ground.
It is a very shoddy way to do it though!
You are correct in the fact that is is very easy to cause a ground fault with this setup. The easiest way to wire a Cp is still daisy chaining the ground.( or buy a prewired Jamma CP)
Sanity leaves too many walls to bounce off of
While the deranged can run endlessly in any direction they choose
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
« Reply #5 on: April 11, 2003, 04:00:40 am »
Just get a good tool to crimp and strip wires (all in one), and everything goes much easier! :)
Justin
« Reply #6 on: April 29, 2003, 01:12:20 am »
Is it possible to use quick disconnects to connect all the 'ground' terminals of buttons/joys?   I only see how you can make a connection between 2, but then youre screwed.  no?
aj6500
  • Last login:July 29, 2003, 06:17:31 am
  • Does this rash look contagious?
« Reply #7 on: April 29, 2003, 07:19:26 am »
No, just put 2 wires into 1 connector to form a chain.
They say patience is a virtue, and ignorance is bliss.  So I guess you can have a pretty good life if you're stupid and don't mind waiting around.
Smittydc
  • Last login:October 05, 2008, 12:48:10 am
  • because its fun!
« Reply #8 on: April 29, 2003, 10:42:05 am »
Get one of those nice spring-loaded automatic wire strippers -- makes a world of difference... saved my hands a lot of pain.
Then all you have to do is mash the connectors on with the crimper -- which I think is actually kind of fun -- I like the crunching sound it makes.  ;D
Build a man a fire, he's warm for a night.  Set a man on fire, he's warm the rest of his life.
s8n
  • Last login:April 02, 2003, 06:12:12 pm
  • The Prince of Darkness
« Reply #9 on: April 30, 2003, 04:59:52 pm »
this pic helped me a TON when i was wiring my first CP.
http://www.darkravenwind.com/cdvision/madcatz2.htm
hedge
  • Last login:October 07, 2003, 10:49:00 pm
« Reply #10 on: April 30, 2003, 09:49:28 pm »
Thanks for the link!  You just saved me hours of time this weekend!!
Dak-ak
  • Last login:July 29, 2008, 05:14:50 pm
  • RSD: Redefining Slacking Daily
« Reply #11 on: April 30, 2003, 11:33:54 pm »
i got a hold of quick disconnects that have a female plug (like you would find on a microswitch) piggybacked on the end of a normal plug.. so i just make ground wires with a normal quick disconnect on one endand a male/female disconnect on the other...
seems to work okay... not sure how happy i am with it or not (they look a bit unruly once its done, but i think it makes it much easier to rewire or fix something if you get a broken wire.. )  just taste i spose
