November 29, 2025, 10:48:02 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Well, that was weird. Outage sorted out. Thank you SirWoogie for saving the day!
Main
Main Forum
Anybody have pix of t-molding with a lip installed?
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Anybody have pix of t-molding with a lip installed? (Read 2550 times)
Crowquill
Trade Count:
0
Full Member
Offline
Last login:November 21, 2024, 09:42:17 am
Scratch-built Guitar - Under Construction!
on:
March 17, 2007, 09:56:43 pm »
As I'm cutting down particle board that's already laminated, I'm having to contend with chipping on the edge. Also, with the thickness of the laminate on the 3/4" particle board it makes the thickness about 13/16. One of the options for 13/16 t-molding on t-molding.com has a lip that would cover the edge. I've requested a sample, but wondered if anybody had used this stuff and had pictures.
Here's the t-molding:
http://www.t-molding.com/store/product.php?productid=16&cat=24&page=1
here's my project w/ pictures of the countertop that's being cut down:
http://forum.arcadecontrols.com/index.php?topic=63541.0
Logged
spacies
Trade Count:
0
Full Member
Offline
Last login:February 19, 2015, 03:40:49 am
Re: Anybody have pix of t-molding with a lip installed?
Reply #1 on:
March 17, 2007, 11:07:41 pm »
Use a router to cut it.
That will stop chipping. Or buy a better blade for your saw.
If this isn't possible then that T-molding is a simple solution.
Logged
polaris
You're a genius! Sheer genius!
Wiki Contributor
Trade Count:
+1
Full Member
Offline
Last login:May 21, 2012, 05:18:59 pm
veni vidi congai
Reply #2 on:
March 18, 2007, 09:59:32 am »
i echo the sharp new tools advice, plus will add , i think if you put masking tape over the bits you want to cut ,mark the cut on the masking tape and cut through it ,it helps to reduce the chipping of the laminate.
Logged
got
C
O
L
O
R
codes
from projects, post them
here
add stuff to the
uk wiki section
Crowquill
Trade Count:
0
Full Member
Offline
Reply #3 on:
March 18, 2007, 08:29:07 pm »
I may check out a different blade. All of this is based on a test-cut that I made on a scrap piece of the matieral. The chipping was pretty minimal and only on the side where the blade exited (through tape even). I purposely cut so that this would be the inside side. The only thing I'm worried about is that I wanted to have the sides of the cocktail inset about 1/4" from being flush. I just thought this t-molding might be an easy, quick solution if I can't work out smooth cuts on the exit side. I'm just wondering how goofy it looks installed.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Main Forum
