Author Topic: hiscore diff (with no nag/white box removal)  (Read 958003 times)
0 Members and 11 Guests are viewing this topic.
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
Re: hiscore diff (with no nag/white box removal)
« Reply #240 on: December 01, 2008, 12:02:24 pm »
Hmmm ...
I was able to compile mame .128 using the posted 128 - 128u3 patch, easy as pie thanks to the mame64 compiler.
The nag screens are gone, but the hi score isn't working ... I created a hi folder, and placed the hiscore.dat file in my mame folder, but it never saves my score (using Radiant Silvergun to test it). Any ideas?
Thanks in advance.
That's an easy one to answer, hiscore.dat doesn't support that game. How do I know that? If you open up hiscore.dat in a text editor and search for rsgun it doesn't find anything.
Also the game does not have save state support so there is really no way to keep hiscores for this game. You could of course read the tutorial on creating a hiscore.dat entry for the game.
Ah! Thanks for the explanation  :gobama (<=== hahahaa! was looking for an "embarassed" smiley, but this is just TOO funny!)
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
9innail
  • Last login:September 22, 2011, 11:18:53 am
« Reply #241 on: December 22, 2008, 10:46:13 pm »
Is a new diff needed for 128u7? This is the first time I have been unable to get it to work. Thanks.  :banghead:
MKChamp
  • Last login:December 24, 2025, 01:30:45 pm
  • Stil around.
« Reply #242 on: December 23, 2008, 05:01:06 pm »
Oops...I got lazy...
Yes, there is a new diff needed for u7...it's uploaded and ready to go.
9innail
« Reply #243 on: December 24, 2008, 12:33:55 pm »
Thank you. This diff makes all the difference with my Arcade Machine.  :cheers:
Gatsu
« Reply #244 on: January 04, 2009, 07:50:30 pm »
just recompiled mame 127. Worked like a charm. no more annoying nag screens!!
FrizzleFried
    • Idaho Garagecade
« Reply #245 on: January 05, 2009, 01:48:25 am »
Is .128u7 working with .129?
headkaze
  • 0x2b|~0x2b?
« Reply #246 on: January 05, 2009, 03:54:03 am »
I'm not sure but you could always give it a try. I'm sure MKChamp will make a new one soon if needed.
FrizzleFried
    • Idaho Garagecade
« Reply #247 on: January 05, 2009, 10:22:47 am »
I usually check first because I have to compile a 64 bit version and I can only do it on the cab itself and it's ...well ...a pain in the ass frankly so I usually hold off until I hear confirmation the DIFF works.
headkaze
  • 0x2b|~0x2b?
« Reply #248 on: January 05, 2009, 01:06:39 pm »
Okay I just checked and no it doesn't work. src\emu\profiler.c has changed too much for the patch to apply. We will have to wait for MKChamp to make a new diff.
Applying Diff Patch...
patching file src/emu/crsshair.c
patching file src/emu/emu.mak
Hunk #2 succeeded at 52 (offset -1 lines).
patching file src/emu/emuopts.c
patching file src/emu/emuopts.h
patching file src/emu/fileio.h
patching file src/emu/hiscore.c
patching file src/emu/hiscore.h
patching file src/emu/mame.c
patching file src/emu/profiler.c
Hunk #1 FAILED at 125.
1 out of 1 hunk FAILED -- saving rejects to file src/emu/profiler.c.rej
patching file src/emu/profiler.h
Hunk #1 succeeded at 48 with fuzz 2 (offset 9 lines).
patching file src/emu/romload.c
Hunk #1 succeeded at 556 with fuzz 2 (offset 52 lines).
patching file src/emu/ui.c
patching file src/emu/video.c
patching file src/emu/video.h
patching file src/mame/machine/cps2crpt.c
patching file src/osd/osdepend.h
patching file src/osd/windows/video.c
patching file src/osd/windows/window.c
patching file src/osd/windows/window.h
Finished!
0 Hours 0 Minutes and 0 Seconds Elapsed.
Paul Olson
    • Paul's Arcade
« Reply #249 on: January 05, 2009, 02:53:21 pm »
I tried it at 2am and it didn't work, looking forward to the update.
Friz - Use remote desktop and configure everything on your cab from another computer. I have the same problem with 64bit, and it is much nicer to work on the cab using remote. I worked on this watching a movie in the living room last night.
Edit: Make sure MALA is closed first (if you use it), it doesn't handle the resolution change very well.
« Last Edit: January 05, 2009, 02:55:13 pm by pcolson »
MKChamp
  • Stil around.
« Reply #250 on: January 06, 2009, 06:43:25 pm »
hiscore 129 ready to roll...
TheManuel
  • Last login:April 09, 2025, 10:13:43 pm
  • On and off hobbyist
« Reply #251 on: January 06, 2009, 08:21:38 pm »
Thanks, Champ!
"The Manuel"
TheManuel
« Reply #252 on: January 06, 2009, 08:24:48 pm »
Not a popular option here but, does the diff work with MAMEUI?
"The Manuel"
TheManuel
« Reply #253 on: January 06, 2009, 08:27:32 pm »
Never mind.
I was reading Headkaze's compiler instructions and apparently you can.
"The Manuel"
FrizzleFried
    • Idaho Garagecade
« Reply #254 on: January 06, 2009, 08:33:01 pm »
Thank you MKChamp....
....Soul Caliber here I come!
TheManuel
« Reply #255 on: January 06, 2009, 08:42:00 pm »
Did it not work before?
Remember you can play the Dreamcast version with NullDC...
"The Manuel"
nuka1195
  • Last login:April 18, 2020, 08:47:25 pm
« Reply #256 on: January 06, 2009, 11:06:47 pm »
Thank You
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #257 on: January 16, 2009, 08:02:41 pm »
I just compiled .108.  Having some severe problems.  I'm trying to configure some things, but it seems that I can not use the enter key.  Anywhere.
csa3d
  • Will game for food
    • Galaxian Mame Conversion
« Reply #258 on: January 18, 2009, 10:56:28 pm »
Do i need to disable any save state settings in mame.ini to get hiscores to save in v129?  Something is making my scores not save since updating...
-csa
MKChamp
  • Stil around.
« Reply #259 on: January 19, 2009, 01:03:05 pm »
It used to make the "enter" key "1". ( to make it work better for dedicated cabs...this was taken out starting with 124)
What you can do is use your "1" key as enter and you can change it back to the "enter" key in the configuration menu.
csa3d
« Reply #260 on: January 19, 2009, 02:08:08 pm »
-csa
Is this just a millipede issue?  Seems to be saving for frogger...
MKChamp
  • Stil around.
« Reply #261 on: January 19, 2009, 02:34:54 pm »
-csa
I think this might be due to a mistype in the hiscore.dat. Due a search for "silliped" and change the "s" to "m" so it reads "milliped"...then see if it saves.
csa3d
« Reply #262 on: January 19, 2009, 02:56:22 pm »
-csa
Naming issue was the trick!  ON a side note, if we compile with HighScore enabled, autosave should be set to 0 and all .nv files in the nvram should be disabled, or not?  If you enable autosave, is the default behaviour to check the .nv ram file first, then default to the .hi files?  Also, is there a way to disable the State Loading box if autosave is set to 1?
-csa
MKChamp
  • Stil around.
« Reply #263 on: January 19, 2009, 04:46:32 pm »
-csa
-csa
.nv files are not a part of the save state system. NV files are generated by games that saved data when they were turned off. The save state files are stored in the sta folder. To be honest, if you have hiscore support, then isn't any reason to enable save states...unless you just want to be able to start a game where you left off. If you upgrade often, you'll find that save states are not that reliable anyways.
iano
  • Last login:June 15, 2011, 03:39:11 pm
« Reply #264 on: January 22, 2009, 07:25:40 am »
I'm trying to compile MAME0.129 with MKChamps diff file but i keep getting the same error. I've no doubt that i'm doing something wrong because other people have compiled MAME0.129 without a hitch. Any help would be appreciated.
src/emu/sound/ay8910.c: 751: internal compiler error: in assign_386_stack_local, at config/i386/i386.c: 13482
Please submit a full bug report, with preprocessed source if appropriate.
see<URL: http://www.mingw.org/bugs.shtml> for instructions
mingw32-make: ***[obj/windows/mame/emu/sound/ay8910.o] error 1
Thanks,
ian.
MKChamp
  • Stil around.
« Reply #265 on: January 22, 2009, 10:22:59 am »
Thanks,
ian.
I think this might be related to Headkaze's MAME compiler...you are using that, right? If so, are you using Pentium 4 (+SSE3) optimize option? If you are, try compiling with Pentium 4 (-SSE3) option instead. If that doesn't work (and you ARE using this program to compile MAME) you may want to post in his thread for assistance....
http://forum.arcadecontrols.com/index.php?topic=71845.0
iano
« Reply #266 on: January 22, 2009, 12:10:27 pm »
Yes MKChamp, i am using HK's MAME Compiler with that option and i will post in the link you provided. Thanks for your help.
gatordad
  • Trade Count: (+11)
  • Last login:Today at 11:42:26 am
« Reply #267 on: January 27, 2009, 11:03:55 pm »
Will the diff attached in the first post Remove loading messages (decoding/decrypting/Updating Artwork, etc.) and the 'white box' when loading for mame 114?
MKChamp
  • Stil around.
« Reply #268 on: January 28, 2009, 01:58:12 am »
No, that was added starting with MAME v120. It will get rid of the 'nag' screens such as 'type ok' or incomplete driver screens, etc.
Dazz
  • HyperSpin Team
    • VPUniverse
« Reply #269 on: January 28, 2009, 10:10:45 am »
MKChamp,
Have you and Fyrecrypts talked about these diffs?  I know that he has made several additions/corrections to these .diffs when working on his HiToText project.  Are you including his updates?
headkaze
  • 0x2b|~0x2b?
« Reply #270 on: January 28, 2009, 10:24:21 am »
MKChamp,
He hasn't touched the diff's only the hiscore.dat file because the memory locations needed to be changed. So it's leezer who distributes the hiscore.dat that should update to use Fyrecypts mods.
« Last Edit: January 28, 2009, 10:27:19 am by headkaze »
Dazz
  • HyperSpin Team
    • VPUniverse
« Reply #271 on: January 28, 2009, 10:53:54 am »
MKChamp,
Oh snap, my bad.  You are correct.  It is the dat file that I am questioning not the diffs.  Thanks HK!
Fyrecrypts
  • Last login:August 19, 2015, 10:50:47 am
  • .hi guy
« Reply #272 on: February 01, 2009, 01:02:42 pm »
MKChamp,
I've talked with Leezer, and have been giving him the updates, I'd bet his releases will contain the fixes added in the HiToText hiscore.dat file.
Help us crack more .hi files here:
http://forum.arcadecontrols.com/index.php?topic=83614.0
Generate the newest hiscore.dat here:
http://www.hitotext.com/HiScoreDat/index.php
Sourceforge project page:
https://sourceforge.net/projects/hitotext
Tinydane
  • Last login:November 29, 2010, 04:21:59 pm
« Reply #273 on: February 05, 2009, 12:56:25 pm »
Just wanted to toss out a big thanks to the guys that put this together.  I just did my first recompile on .128 and it went real smooth.  I followed MrDo's step by step info on the actual recompile and all went well..
thanks again. :cheers:
csa3d
« Reply #274 on: February 07, 2009, 03:51:09 pm »
I want to pose this question:
Given that I've seen at few people attempting to hook up the mouse Z-Axis to the spinner, do we think it might be beneficial to roll the option to use the Z-Axis when applying this patch as well?  I typically apply this patch and then the TT2 Z-Axis patch described here when I compile my own.
Just a thought
-csa
MKChamp
  • Stil around.
« Reply #275 on: February 08, 2009, 01:23:45 pm »
Just a thought
-csa
Then we'd have to add a hundred other patches used by a 'few' people :-)
csa3d
« Reply #276 on: February 08, 2009, 02:32:50 pm »
Ha!  True..
-csa
Todd H
  • Last login:August 26, 2024, 02:23:32 pm
  • It's Gameday!
« Reply #277 on: March 06, 2009, 08:57:27 am »
Probably a stupid question but in order to compile a 64-bit version you need to do it in a 64-bit OS correct? I assume I couldn't compile a 64-bit version under a 32-bit version of Vista.
FrizzleFried
    • Idaho Garagecade
« Reply #278 on: March 06, 2009, 09:58:06 am »
Correct.
kaptainsteve
  • Last login:November 22, 2025, 09:12:21 pm
    • Swamp-Ass
« Reply #279 on: March 10, 2009, 06:42:41 pm »
Hello,
Wondering if anyone can help?
Where does one go about finding the mame "patch.exe" used when compiling?
thanks.
Steve
Found it Here at http://gnuwin32.sourceforge.net/packages/patch.htm for those who bump into the same problem.
« Last Edit: March 10, 2009, 07:14:58 pm by kaptainsteve »
