Author Topic: 1 1/8 Drill bit throught Metal CP??...  (Read 2584 times)
hayabusa_fmw
  • [Provisionally returned]
  • Last login:December 30, 2014, 03:24:56 pm
« on: March 10, 2007, 09:38:19 pm »
hey guys
here's my story
I got a dedicated Virtua fighter cabinet in good shape.
But i want to make it 6 buttons ...
Cause im getting an other VF 1 dedicated in Better shape.. (yay!) :)
the setup is not that complicated to put extra buttons they would be curved a little but still good
i could wire it to jamma & use it as a 6 button jamma cab
but my concern is I got a 1 1/8 Drill bit
I did CP in Wood...
but im not sure if It can go trhought metal... i never tryed before
since i will have  6 holes to make i wanna be sure.... that it will work....
Im using a electric battery powered drill it's very strong .
thanks!!!
Numbski
  • Last login:November 03, 2020, 01:51:50 pm
    • Numbski
Re: 1 1/8 Drill bit throught Metal CP??...
« Reply #1 on: March 10, 2007, 09:40:21 pm »
Drill a small pilot hole, then use a hole saw to cut the holes, make sure you get a carbide-tipped hole saw, or get a cheap one that you don't care whether it gets destroyed. :)
Build a man a fire, keep him warm for the night.
Set a man on fire, keep him warm for the rest of his life.
hayabusa_fmw
« Reply #2 on: March 10, 2007, 09:54:48 pm »
so with the Drill bit it's useless?.
Havok
« Reply #3 on: March 10, 2007, 10:53:24 pm »
You really should use a Greenlee punch, depending on the thickness of your control panel. Check this out:
Mouser
hayabusa_fmw
« Reply #4 on: March 10, 2007, 11:00:27 pm »
thickness
hmm not sure
it's a original virtua fighter         US cabinet...
It's like drilling any metal base control panel like a streetfighter i presume...
the mouser you showed me Seems pricy a little i won't be doing this anytime soon . it's only for this cab.
Clu
  • Last login:January 10, 2013, 12:34:22 am
  • Watch it, sucker.
« Reply #5 on: March 10, 2007, 11:18:45 pm »
Harbor Freight has a really good punchout kit for $15.  It does a clean job and is a lot easier than trying to drill metal.  It punched through my Galaxian panel fine - somebody already mangled it with a hack saw so I wanted to clean up the edges.  It goes through pretty thick pieces as well, I think around 1/8"  http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=91201
mrserv0n
  • Last login:May 25, 2021, 09:20:06 pm
« Reply #6 on: March 11, 2007, 12:04:12 am »
I used a dremel rotary to cut the metal holes for my CP. Worked great.
  • Last login:November 25, 2025, 07:49:55 pm
« Reply #7 on: March 11, 2007, 12:08:13 am »
I used a 1 1/8" holesaw.
hayabusa_fmw
« Reply #8 on: March 11, 2007, 10:43:05 am »
THanks guys so ill go buy a Hole saw peice
but it works on a drill right?..
let me know
thanks!
« Reply #9 on: March 11, 2007, 11:22:26 am »
yes:
Havok
« Reply #10 on: March 11, 2007, 11:39:17 am »
WHAT?
You mean that i shouldn't be twisting the hole saw by hand?
Awww man - I could have had my cp done way faster!
hayabusa_fmw
« Reply #11 on: March 11, 2007, 11:55:36 am »
HAhahahaha
Damn!!!
now that makes it tooo EASY!
i like things the hard way so i better start twisting!
I hope it won't mess up the Overlay on the cp when the drill twist it i hole it will only do the hole it has to do
thanks guys!
**Question #2 ****
Ahhh! i don't want to start an other topic...
I want to fit a 17 '' monitor in a tiny cabaret cabinet
but there is an angle so i dunno how i should put it still?
should i do a frame? (still it won't be bolted..)
what should i do?
« Reply #12 on: March 11, 2007, 12:06:46 pm »
I wouldn't risk it. The one time I tried drilling a hole out of my overlay, the teeth caught the paper and ripped it. If it's glued down - you might be ok.
« Reply #13 on: March 11, 2007, 12:08:29 pm »
**Question #2 ****
what should i do?
Start another topic.  ;)
You'll want to secure the monitor somehow. I've seen everything from straps (like cargo straps for luggage), to square tube metal cut to fit the monitor.
FrizzleFried
    • Idaho Garagecade
« Reply #14 on: March 11, 2007, 01:15:38 pm »
The Hole Saw is your friend!  Just make sure that you purchase an arbor (the center piece) with a shaft at the max size of your drill.  Do not make the mistake of purchasing a 1/2" arbor only to find your drill will accept 3/8" maximum.
Also,  unless your cordless drill is an 18v,  chances are SLIM it will have enough power to go through the metal...so borrow a corded one or buy one (in which case I highly recommend you buy a 1/2" corded drill as you WILL come across 1/2" shafts from time to time and will be kicking yourself in the ass if you buy a 3/8" drill).
The key to making it through the CP is SPEED.  Attack the CP from the FRONT at a high rpm...slowly giving pressure...it will cut through like butter...
The meta it self takes a bit of pressure...but it's no problem (as long as you get a quality hole saw).  Expect to pay around $30-$40 for the arbor and a QUALITY hole saw (at least in the US).  The ones in Home Depot to look at are the ORANGE colored hole saws...again, make sure you get an arbor that will FIT the hole saw bit because it TOO has different sizes (another mistake I made).
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
« Reply #15 on: March 11, 2007, 06:34:46 pm »
When you buy your holesaw, make sure to get a BI-METAL holesaw. Those are made for cutting metal or wood or whatever...
It's 9am. I'm calling it a nite.
