Author Topic: iPac wiring problem  (Read 1021 times)
brianoneill
  • Last login:January 27, 2017, 04:44:59 pm
iPac wiring problem
« on: January 27, 2007, 07:42:42 pm »
Guys, I rewired my CP this weekend but have run into a snag.
Its a 28 input iPac. I have always needed 32 inputs because of an extra joystick (a 4 way).
This was solved before by doubling up the P1 U/D/L/R inputs with the 8 Way & 4 Way joysticks.
But now I have rewired its not working like that !?
If I double up the J8Way Up with the J4Way .. they don't register anything !?
If I either of them have the iPac to themselves they work fine.
Anyone any ideas why this is ? I am sure I had this working before :(
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: iPac wiring problem
« Reply #1 on: January 27, 2007, 07:49:40 pm »
Ground problem ?
There is no problem running a 4-way and 8-way from the same inputs, but it sounds like you have a grounding issue.
Cheers
Working: Not Enough
Projects: Too Many
Progress: None
needlesmcgirk
  • Last login:September 15, 2009, 10:54:31 pm
« Reply #2 on: January 27, 2007, 08:07:00 pm »
I have the player 1 8-way joystick wired with the dedicated 4-way on my panel into the same inputs on my ipac card, so it does work.  You should just double check the wiring and see if something is missing.
brianoneill
« Reply #3 on: January 29, 2007, 09:03:43 am »
 :tool:
Yes I am indeed !
I had the joysticks cherry switches wired to the NC ! It was dark  :dunno
Thanks guys & sorry for the stupidity !
