Author Topic: How do I go about having a front end start when my PC is turned on?  (Read 1940 times)
roadrunnr
  • Last login:December 03, 2007, 08:53:45 am
Forgive me if this is an easy question - but I would like to have power given to my MAME and have it boot XP and then immediately run a front end.
Any ideas?
Thanks.
shardian
  • Trade Count: (+23)
Re: How do I go about having a front end start when my PC is turned on?
« Reply #1 on: January 23, 2007, 09:50:26 am »
You can always just drop a shortcut of your frontend into the startup folder.
The startup folder should be in this vicinity:
C:\Documents and Settings\All Users\Start Menu\Programs\Startup
headkaze
  • 0x2b|~0x2b?
« Reply #2 on: January 23, 2007, 10:27:31 am »
You can also use Instant Sheller to hide your OS and launch your FE on startup.
roadrunnr
« Reply #3 on: January 23, 2007, 10:33:39 am »
I like it.  Thanks!
shardian
« Reply #4 on: January 23, 2007, 11:33:01 am »
If you aren't computer savvy, then you should think twice about messing around with using your FE as a shell.
« Reply #5 on: January 24, 2007, 01:32:48 am »
Any ideas?
Check ou tThe Launcher.. You dont have to mess with windows settings. It can start your front end, then shut down your machine when you are finished.
http://skennys_outpost.tripod.com/thelauncher/index.html
Lilwolf
« Reply #6 on: January 24, 2007, 10:29:44 am »
Start off by putting it in your startup and test it for a while
If you realize that you never need any other functionality, then your golden and can try making it your shell.
But one way is VERY easy... the other makes maintenance / configuration a pain.
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
« Reply #7 on: January 24, 2007, 01:22:22 pm »
totally agreed.
  • Last login:Yesterday at 12:52:28 am
« Reply #8 on: January 25, 2007, 09:07:39 am »
Thirded..
Some fe's have trouble when they are set to the shell anyway. I wouldn't do it unless I really, really knew I could do it.
loadman
    • MaLa
« Reply #9 on: January 25, 2007, 09:10:42 pm »
Thirded..
Forthed:
Question for HC:  What FE's have a problem?  You can PM me if you want to avaoid a FE war.  I just have not heard of any FE's being a problem as a shell before...(when done correctly)
« Reply #10 on: January 26, 2007, 02:02:17 pm »
Well it's not like any of them will crash or anything, but where many of them get their resolution data from the desktop, it can screw up the selected resolution.
